Question about Motorola Mobility Mobile PhoneTools 3.0 (98654H) for PC
Net monitor or field test mode Motorola
Hi How can I operate field test mode in Motorola N7 mobile? Is it a utility or something in the phone?' Thanks Eyal
  • Anonymous Dec 07, 2008
    Hi. Still trhe same question: it is a L7, not N....Thanks
Tip
Motorola Secret Codes
<span>Motorola L6:<br />-----------------<br />hold * 65512890 for reset<br />hold * 5806 sw version<br />hold * 487989 NS lock menu<br />hold * 482896 CP<br />hold * 574243 NS<br />hold * 967678 SP<br />hold * 362628 IMSI<br />hold * 787090 Lock net level<br />hold * 787292 Lock net level<br /><br /><br /><br />Reset L7 security code without any cable<br />------------------------------------------------<br />press menu button enter 6 time 0 and then press ok<br /><br />*#06# IMEI<br />in permament test mode<br />(* hold 2 sec)<br />***113*1*[OK] net monitor<br />T205/T19x (ACER)<br />*#300# OK List the Software and Hardware version<br />*#301# OK Full Keypads functional Test<br />*#303# OK Set Default Language to English<br />*#304# OK Set OFF engineering mode<br />#304*19980722# OK Set ON engineering mode<br />*#305# OK Location: 1 OK<br />*#307# OK Engineering Test Mode<br />*#311# OK Phone code changed to default code<br />*#400# OK ADC, Cal val*<br />*#402# OK Adjust Display Intensity / Contrast<br />*#403# OK List the Manufacturing Informations<br />19980722 OK Master Unlock code for Phone and Sim Lock<br />*#302# OK Acoustic test*<br />7.1 Greeting<br />7.2 Main VlmGain<br />7.3 Input Cal<br />7.4 Output Cal<br />7.5 Side In Gain<br />7.6 Vox Gain<br />7.7 Min Mic Engy<br />7.8 More<br />(a) In Vlm Gain<br />(b) Aux Vlm Gain<br />(c) Silence Prd<br />(d) Supp Prd<br />(e) In Volume<br />(f) Out Volume<br />(g) Icon<br />(h) Image<br />(i) Animation<br />*3370# EFR ON (enhanced full rate)<br />#3370# ERF OFF<br />*#72837726# OK Confirm ?, Data saver<br />1234 OK Phone code default<br />*#0000# OK Setting saved, restore set phone do default language<br />*#0048# OK Fast change polish langpack<br />*#0007# OK Fast change russian langpack<br /><br /><br /><br />MOTOROLA 3xx<br />------------------------<br />*#06# and quick 'menu-key' and 048263* (Push the key quickly!)<br />and entering at field "OPTCODE" you must try several times.<br />If not working try with MOTO TEST CARD inserted.<br />Security code - 32*118*1*0*0<br />Model - 32*279*1*0*8<br />Flex ver - 32*383*1*0*0<br />Master Reset - 18*0<br />Master Clear - 18*1<br />Set band GSM 900 - 10*0*3<br />Set band DCS 1800 - 10*0*4<br />Set band PCS 1900 - 10*0*5<br />Set dual band GSM 900/1800 - 10*0*6<br />Read band - 10*1*0 =&gt; 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS<br />User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/<br />Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/<br />47*4*1*0*9*081A32547698103254 =&gt; IMEI=123456789012345<br />it is possible to change IMEI<br /><br />ENJOY</span>
on Jul 11, 2011 | Cell Phones
Tip
MOTOROLA CODES
>>All Motorola Secret Code<<
Motorola L6:
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
*#06# IMEI
(* hold 2 sec)
T205/T19x (ACER)
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy
7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
#3370# ERF OFF
MOTOROLA 3xx
Master Reset - 18*0
Master Clear - 18*1
Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS
47*4*1*0*9*081A32547698103254 => IMEI=123456789012345
it is possible to change IMEI.........
on Feb 09, 2008 | Motorola Mobility L6 Cellular Phone
I dialed ##8378<SEND>, then clicked
Typing ##8378 Send brings up the phone test screen. When you select #2 (Field Test) and then select OEM monitor and select "enable" the phone resets and enters test mode.
In test mode you can press the volume up button to bring up the test menu. You can navigate this menu using the 1 and 3 keys on the number pad.
The most notable screen in test mode is found by pressing 3 until you reach SHDR protocol monitor will bring up the screen that displays real time reception and transmission information.
Other screens display other system information, but I caution against "playing around" with these menus too much.
To temporarily hide the test mode screen you can press the volume keys again. To take the phone out of test mode completely follow these steps:
1. dial ##test or ##8378 and press send 2. select 2 (field test) 3. scroll down to and select 10 (OEM monitor) 4. scroll down and select Monitor DISABLE 5. the phone will reset and return to normal mode.
Feb 13, 2011 | Casio G''zOne Type S Cellular Phone
I have got nokia 1208 cellular phone and that phone is showing test mode how to solve that problem its very urgent.
Hi, to exit test mode, turn off phone.
Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
Feb 02, 2011 | Nokia 1208 Cellular Phone
Motorola V3, is on field test. Need to know the steps to take to turn field test off.
open the phone up and enter #073887* this will prompt you for your unlock code enter this and then scroll the menu untill you get to test mode and enter that menu and click disable and your done
Jan 18, 2010 | Motorola Mobility RAZR V3c Cellular Phone
What to do?
hi friend,
Look at these service phone codes of Motorola mobile, may be it will help you in your mobile phone settings
*#06# imei
in permanent test mode
(* hold 2 sec)
T205/T19x (ACER)
*#301#­ OK ­ Full Keypads functional Test
*#403# OK List the Manufacturing Information's
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy 7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
#3370# ERF OFF
MOTOROLA 3xx
Master Reset - 18*0
Master Clear - 18*1
it is possible to change phone's imei
or u can even try last 4 digits of ur mobile number
hope this helps u
thank u for using fixya
regards
sivaranjini
Nov 26, 2009 | Motorola Mobility RAZR V3
My nokia 1208 is stuck in test mode
To exit test mode, turn off phone.
Sep 03, 2009 | Nokia 1100
Unlock motorola w375 net 10 prepaid
just download "Motokit "software.& install it in ur PC.Select Data/fax mode in usb setting of ur mobile.
then open the MOtokit software & connect ur phone..Software will automatically detect ur phone.
then of top left side of the software select " mobile" & then"info"..it will give u the Unlock code & security code of ur mobile...
Nov 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Displays test mode
Jul 03, 2008 | Cell Phones
Motorola Mobility Mobile PhoneTools 3.0 (98654H) for PC Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
