Question about JVC DR-MV7 DVD Recorder/VCR
My JVC DR-M78BU will not play DVDs with a country code of 1. On the back, it has a globe with a 1 in it. It will play Japanese DVDs but not American. I don`t get it. Please help...
  • 8,596 Answers
Somebody changed the country code on that player. BTW, it is illegal to change the country code on a DVD player. I would call JVC and see if they can fix it - usually they wouldn't, but since your player clearly has a 1 on the back, then they may have a solution.
The following is for illustrative purposes - these are NOT the codes/procedures to unlock your JVC - I merely post them to show you how one might go about changing the codes on your JVC player - once again, this is not the right procedure for your particular JVC player:
To select an alternative region for this player:
  • Press the Power button on the player to turn it off.
  • Wait 5 seconds.
  • Press and hold the buttons DVD Menu and On Screen on the player together, and then press the Power button on the player to turn it back on.
  • Release the DVD Menu and On Screen buttons.
  • Press the Standby button on your player, the display should now show either "TEST 2", "TEST 4" or "TEST 6" depending on the player region.
  • Press the DVD Menu button on your player twice in a row, the display should now show "000 5858".
  • By pressing the Up and Down cursors buttons, change the first three digits until they read "02E".
  • By pressing the Right and Left cursors buttons, change the last four digits until they read "0000" for Region Free, "0101" for Region 1, "0202" for Region 2, "0404" for Region 4.
  • If you experience difficulties with Region 4 discs, change the above setting to "0458" and make sure that PAL or NTSC is correctly set on your player.
  • Press the Enter button on your player to confirm the region change.
  • Press the Standby button on the player to turn it off.
  • Wait 5 seconds.
  • Press the Standby button on the player to turn it on.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
  • Corey Knoettgen
    Corey Knoettgen Dec 31, 2008
    One more thought - go to General Settings --> Factory Set (pp.20-21 of your manual), and see if that will change the encoding. It probably won't, but worth a shot.
    -Tha Mp3 Doctor
Pioneer dv320-k = no longer region free??
You maybe able to get a region free code for your player from these WEB sites.
REGION FREE CODES FOR DVD & BLU-RAY
www.dvdexploder.com/ www.videohelp.com/dvdhacks www.download-info.com/dvd/index_new.htm
Feb 24, 2013 | Pioneer DV320K Multiregion DVD Player PAL
I need to play a region 1 DVD on my jvc xvs42 but it is saying wrong region code
this will happen from one of 2 things. either the dvd is not a region 1 or the dvd player is not a region 1. if you purchased the player from ebay resently then i would return it. if the dvd player is old and always worked then your dvd is probably not region 1. sometimes when the dvds are packaged there can be mispackings that happen so even if the dvd cover says region 1 it may not be. try another dvd. if another dvd works then the first dvd is the issue.
Aug 24, 2011 | JVC DR-MV5S DVD Recorder/VCR
Bought a dvd from England.JVC dvd player will not play dvd.it is on stop and will not play.
American DVD players will not play European DVDs because they use different region codes, you can normally play them on computers, but DVD players are normally coded for only one region.
May 04, 2011 | JVC Televison & Video
It is hooked up correctly and i am only able to watch burned dvds. No regular american ones or regular european ones! Why is that? Please help
Check the back of the DVD player. What is the region code on the unit? You will only be able to play dvds with that region code (or a universal code - globe icon).
The manual for the unit is here: http://pdf.crse.com/manuals/4139513111.pdf .
If it isn't playing discs from the region that it should, I'm not show how to fix the problem. If it is under warranty, contact Sony (unless you know someone tried to remove the region code and failed).
Apr 24, 2011 | Sony DVP-NS718H DVD Player
Dvpns355 won't play american dvds
Check at back of player for region 1 code written in globe image, if region code is other then 1, this player wont playback American DVDs
Thanks.
Dec 01, 2009 | Sony DVP-NS355 DVD Player
American DVD discs will not load and play, but overseas discs will
no the coding would not change from using the dvd's from overseas. the ones that you say are american may not be american and that is most likley the problem. try putting in a dvd that you have had for a long time that you bought here in the states and if that works then the dvds you say are american are the problem.
May 31, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Code to unlock zone
Mine says it is a region 4 DVD player, but yours could be different. But referring to mine, i have played DVDs from overseas, e.g USA and KOREA with no problem. Its a fantastic piece of equipment, the JVC DR-MV1S. =)
Sep 09, 2008 | JVC DR-MV1S DVD Recorder/VCR
Japanese Ps3 not playing American games
It's because your trying to play american games on a japanese system. See the japanese system is different because of not only how much Power it needs to function (I'd be wary about that btw) as well that a Japanese PS3 can only play Japanese PS3 games. American games wont work for it.
Jun 07, 2008 | Sony Playstation 3 (PS3) Console
American dvds in a standard uk player?
seach the net for unlock region codes and it will tell you how to do it. good luck
Jan 03, 2008 | JVC XV-S302 DVD Player
JVC DR-MV7 DVD Recorder/VCR Logo
130 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
