Question about Soyo Computers & Internet
Connection Antec Case Audio Connectors to SY-K7VME Motherboard
Antec PC Case has one connector"HDA" and Other Connector "AC'97".
SY-K7VME Motherboard has AUDIO1 connector with two installed jumpers.
How to connect correctly in this case please?
  • terioki2003 Dec 05, 2008
    Thank You.
    Jumpers from the motherboard "AUDIO1" should be put off and "AC'97" from the case put to "AUDIO1".
    Genius:
  • 1,061 Answers
AC'97 IS YOUR SOUND/AUDIO. THE HDA IS HIGH DEFINITION AUDIO. RICHARDM69
Posted on Dec 05, 2008
Manual reset motherboard: Soyo SY-K7VME
Bios settings are retained by the Motherboard Battery in the CMOS. Disconnecting the battery clears CMOS and returns the settings to their original state. Typically this can be done by simply removing the CMOS battery and waiting about 15 seconds before reinserting and booting PC. Nowadays most Motherboard manufacturers supply a jumper to not only disconnect the battery but also ground the CMOS to effectively drain any residual power.
The instructions for your MB are found below. JP5 is located to the left of the battery and next to the PCI 2 slot on your MB. There is a Manual for your MB on this site and the MB layout can be found at
http://www.fixya.com/support/p281070-soyo_sy_k7vme_motherboard/manual-35533/page-5
Follow the steps below to clear the CMOS memory.
1. Clear the CMOS memory by momentarily shorting pin 2-3 on jumper JP5. Its white cap can easily identify this jumper.
2. Put the jumper back to 1-2 to allow writing of new data into the CMOS memory.
Jan 07, 2010 | Soyo SY-K7VME Motherboard
The audio does not work
There should be a disable option in the bios on the motherboard setup, instead of doing the jumper.
Nov 11, 2009 | Soyo SY-K7VME Motherboard
I removed the power supply to install motherboard and did not pay attention to the 3 wires attached to the case. what is the order of the wires? They are green/yellow, blue and brown.
All the wires from the power supply are power connectors, depending upon the motherboard not all power connectors from the power supply maybe required. If there are no matching sockets on the motherboard, then that power connector is not required.
Nov 07, 2009 | Antec AR300 300-Watt Power Supply
Replacing a failed soyo MB. need to know what the various wiring colors are - power, restart, etc. SY-K7VME
Are you sure this is not a SY-K7VEM? I did not see a VME.
Here is a link to the manual:
http://www.motherboards.org/files/manuals/107/mk7vem10.pdf
The Front Panel pinout can be seen on the motherboard layout on Page 5. Although this does not give wire colors, the small connectors should have abbreviated labels such as HDDLED or PWRLED.
Thanks for using Fixya.
Aug 25, 2009 | Soyo Computers & Internet
Hp pavilion 764c wire diagrams
Take a picture of the inside of your computer and put it up on the website with the wire connectors that need to be connected. The connecting wires should be in four groups. 1. The power supply connectors. These connectors will supply power to to all the power using components not supplied power by the motherboard itself. 2 The connections to the other components in your system like the dvd/cd player and the harddrive and floppy drive.3. The motherboard connections for the case. The power switch connector andreset switchconnector. The power led and theharddrive activity light.The USB connector and the audio connector.The fan connections like the cpu fan and other fan only connectors found on the motherboard.The external fans ( Fans that need to be connected to the power supply).Most of these connections are labeled on the motherboard. The case connectors also should be labeled for the correct connection. The best way to find the answers to this hook-up, may be to call HP pavilion with your computer make and model number,motherboard model number including revisions number. Computer made by big manufacturers tend to have may revisions and the only way to make sure your are getting a correct hook-up to the motherboard is call them for assistance.Especially if the motherboard and case labels are not present or so small that they cannot be read.Hope this helps you with your problem.
May 16, 2009 | HP Computers & Internet
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
P/S replacement in Gateway 2000 model year Tower
Gateway may have a unique non standard pinout for its P/S. I would match up the colors in sequence on the new PS and see if the old harness had the 6 pin connector and graft them into the new harness. The colors are standard for voltage.
Feb 11, 2008 | Antec TruePower Trio 550 (TP3550) 550-Watt...
Computers & Internet Logo
337 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
