Question about Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 power button
The power button has been getting hard to turn on and off on this GPS.  I now can not turn the unit on unless I insert the power adapter to key the unit on.  Once on I can't turn it off.  The battery is fully charged and works well.  Any suggestions?
  • marn499 Dec 09, 2008
    I already found this source through more searching.  It is good to see that the Guru came up with the same solution.  Sent the GPS off for a fix yesterday.  This will cost much less money with a better fix than Garmin offered.  Thanks.
  • marn499 Dec 20, 2008
    I received my GPS back from Jim at SHARNET-USA.  Jim did a great job fixing the power switch. Great communication, fast service, reasonable price and the unit works great.  I highly recommend using SHARNET-USA for this repair.  Thanks Jim!  :)
  • Garmin Master
  • 2,130 Answers
Yes, please read about this problem here:
http://www.sharc.net/nuvi_power_switch_repair.htm
- Jim
Posted on Dec 05, 2008
  • SHARCNET-USA
    SHARCNET-USA Dec 20, 2008
    Thanks Bill. My pleasure :)
    - Jim
    SHARCNET-USA
    Problem Solver:
  • 10 Answers
Hi. Please look us up on EBAY.CO.UK
MGA-TRADING
We offer the best value and quickest repair service around for the Garmin Nuvi
Repairing and modifying the switch is straight forward and can be turned around in a few days!
Regards
MGA-TRADING
Posted on Dec 13, 2008
Nuvi will not turn on
What model Garmin Nuvi ???....
On occasion, your Garmin GPS may experience technical malfunctions, including failing to power up.
When this happens, perform a manual hard reset of the unit.
A soft reset entails holding the power button until the unit powers down, and then pressing the it again to power the device back up.
However, when the unit won't turn on, a soft reset won't work. In this case, a hard reset is the only way to get the device up and running again.
Unplug power and USB cables to disconnect all sources of power to the unit.
Place your thumbnail into the groove located below the Garmin logo on the face of the unit.
Pry the faceplate off using gentle pressure.
Press the reset button and hold for approximately 3 seconds.
When the device is facing you, the reset button is located in the middle of the right-hand side of the front of the device.
Snap the faceplate back into place.
Press the power button.
Your GPS should now turn back on.
Garmin Nuvi With No Power
A Garmin Nuvi is a type of GPS device that can help you find your way around when traveling by motor vehicle.
You can mount the Garmin Nuvi inside the windshield of your vehicle and allow it to acquire the satellite signal.
This tells the device where you're located.
After that, you can find simple directions to get to a new location by entering the address into your Garmin Nuvi.
If you find that your Garmin Nuvi has limited or no power, you will need to do some troubleshooting to get it to work.
Change the fuse within your unit's power cable.
If your Garmin Nuvi has no power, the fuse may be out, meaning the device cannot be charged.
Plug your Garmin Nuvi into the power supply of your vehicle and turn the vehicle on.
The device cannot charge and get power unless the vehicle is running.
Allow the Garmin Nuvi to charge fully.
You might be unplugging it from the power source too soon, which could cause the device to have little or no power.
Regulate the temperature of your Garmin Nuvi.
It may not function properly if the temperature is too cold, below 32 degrees Fahrenheit, or too hot, above 113 degrees Fahrenheit.
Aug 10, 2013 | GPS
I cannot use the GPS unit while in charge mode(NUVI 350)
Are you using a USB cable & charger to operate the GPS?
If so, you should stop and use the supplied cradle / power cord to power the GPS instead. The USB cable is used to transfer data to and from the GPS and on other models (maybe your 350, too) to slow charge the GPS battery when completely discharged. Powering with the USB cable will power up the GPS, but does not allow navigation, mapping, etc.
Oct 12, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 touch screen doesn't work
The touchscreen needs replaced. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Aug 02, 2009 | Garmin nuvi 350 GPS Receiver
Gps 350
Press the Power button on the top right corner of the case.
If unit will not power on, battery may be dead. Try connecting car charger or power adapter to unit.
To charge battery faster, leave unit connected to power adapter or car cord. Press and hold Power button to turn unit off. Screen will show "Going into charge mode."
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
Nuvi 755 said it was receiving GPS update. Now it
Plug the unit in , if the unit turns on, after it turns on do a hard reset, the directions should be in your manual or will be at www.garmin.com.
Jun 23, 2009 | Garmin nuvi 350 GPS Receiver
After trying to install new maps, Garmin nuvi 350 don't start
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 30, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 350 power button doesn't work
buy a tom tom everyone is having trouble with garmin and its not just poert buttons tom tom is much more reliable
Aug 14, 2008 | Garmin nuvi 350 GPS Receiver
Garamin Nuvi 350...blanked out and won't turn back on.
Try the computer USB adapter. After it's been connected for about 20 seconds then try powering on the Nuvi. Even if your unit's battery is dead the USB connection should hold power on the unit so that the computer recognizes it as a Mass Storage Device (Windows). If that doesn't work then use the wall adapter and leave it plugged in for an hour or so. At that point if the unit fails to power on then push the reset button in the back under the antena and hold it in for 10 seconds while the cord is connected to the wall. This will clear any software related issues that would stop it from powering up - any other result indicates most likely a hardware failure. At least rule out your plugs.
Jun 07, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
177 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
