Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Liquid behind the screen
My daughter sprayed fruit cleaning spray on the screen and it got behind it. There must be two layers to the screen because there is liquid behind the front screen. When I peak behind the screen I can't clean it and I cant' get the whole thing off. Any ideas on how to fix?
Actually, I had the same thing happen to me. I was considering taking the unit in to have it serviced, however, after a few days the liquid finally evaporated. I live in AZ, where it is dry ... I guess it helps.
Posted on Jan 29, 2008
Put a hair drier on low at the source of the problem, that should fix it.
Posted on Feb 10, 2007
Can I get the screen clear if I have used the wrong cleaner
Short answer is no, if the screen is plastic and the chemical attacks the plastic. If it is too much liquid and it seeps between any layers, it could evaporate over time, but you will likely have a noticeable dry stain forever.
For you and everyone reading this, never spray or apply any liquid to any TV, monitor, laptop, or cell phone screen directly, I think it says that in the owners manual. Always apply a light amount of TV screen cleaner spray to a microfiber cloth and then lightly clean the screen. DO NOT use anything with alcohol, ammonia, glass cleaner types, baby wipes, pre-moistened wipes of any type unless it specifically states it's for LCD monitors and TV's. If you or the manufacturer apply more cleaner to the wipe or cloth than necessary, blot excess cleaner with a dry paper towel so that the liquid doesn't run or drip when applied to the screen during cleaning.
Jan 23, 2016 | Televison & Video
Peach tree with black spots on the fruit.
Use of fungicides from the start of buds popping up to and including fruit growth period should help. Also keep the area clean of dead wood, weeds, dropped fruit. Remove all non fully formed fruit at end of season
Aug 10, 2014 | Video Game Consoles & Games
Sprayed HDTV screen to clean it NOW no picture
First of all vinegar is acidic. You are supposed to use a soft cloth or tissue dampened with the proper cleaning solution for LCD screens. You can also make your own cleaning solution.
Even though you think you used very little, all it takes is a single drop or enough vapors to go down below the screen to the circuit board inside. Once liquid touches one of these boards most often damage will occur.
These boards are multi layered and use very high density SMD technology. They are usually impossible and too costly to service. The normal practice is to change the defective board, and then do any necessary adjustments.
I would suggest you call the service rep for your TV type and inquire about how to go about getting an estimate. I can tell you fixing this type of set will not be low in cost.
Jerry G.
Aug 25, 2012 | LG 42LC2D 42 in. LCD HDTV
My daughter sprayed round up on my lawn. How do I repair it?
Put a light layer of top soil on the dead spots and re-seed the areas. Make sure to water regularly.
Jul 09, 2012 | Roundup "" Weed & Grass Killer
The detegent doesn't completely leave the soap dish. the soap door works appropiately --- but the dishes do not come out clean. We have tried detergent pellet, liquid detegent and the basic cascade...
This model relies on the top spray arm to 'wash' the detergent out of the soap dispenser - and that is the problem. Your top spray arm will not be turning properly. Check the angled jet on the very tip of the arms for blockages with food or fruit pips etc - it's this angle only that makes the arms turn.
if blocked, clean out with a pin or wire, and running water - make sure you get every bit out. If not, buy a new spray arm. If the arm is split, you will need a new one.
Other problems may be low water level or a faulty circulation pump - BUT check the spray arms first.
Remember a dishwasher is NOT a garbage disposal unit, so scrape any food particles of plates etc before putting them in the machine. Run a dishwasher cleaner through with no load once in awhile.
Feb 04, 2018 | Crosley Dishwashers
What should be used to clean the TV viewing screen
Soft cotton cloth would be fine to clean front screen of TV. Do not use any liquid or detergent in cleaning.
Thanks.
Nov 21, 2009 | Sony KDS-60A3000 60" HDTV
What is the best method for cleanig a flatron
Take a clean cloth and spray some windex on the cloth and then wipe down the screen and it should come nice and clean. Never spray it directly on the screen cause if the liquid goes down inside of the screen then it could damage it.
Mar 01, 2009 | LG 22" FLATRON LCD Monitor
Moisture behind screen
It is difficult to clean/remove the screens. Best case senario, it will dry up leaving little to no water mark. There are three screens, liquid gets between them and it sucks it in. Disassembly and cleaning will fix, but the screens are very fragile and cannot be wiped without potential damage. Any dust, dirt between them will show in the picture. Proceed at your own risk.
Sep 04, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv and gum
get a bottle of canned air, about 10 bucks. hold it upside down, and spray the liquid on the gum(despite what the directions tell you to do). gently pell off from one side of the gum, constantly spraying underneath the gum so it stays frozen. follow up with windex, or a normal LCD screen cleaner. Be careful not to get the liquid on your skin, as it can cause 3rd degree burns, and in worst cases, FROSTBITE. Trust me I know(1 Freshmen + 1 bottle canned air X 1 senior = pain for both parties) What this does, is freeze the sugar molecules in the gum from contracting when it is pulled by freezing them to a near sub zero temperature.
Feb 18, 2008 | Televison & Video
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
194 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
