Question about Toshiba Satellite A100-S8111TD Notebook
Auto shut off
When turn on it will give short beep 5 times cycle then shut off
My Electrolux EDV 605clothes dryer is turning but not heating, heating element is ok possible faulty thermistor, dryer heats up when thermistor is unplugged but has an error code of 5 beeps
I think you're absolutely right exhaust sensor is faulty.
The buzzer will give 5 beeps, all program LEDs will flash for 5 seconds and the dryer will continue with the cycle. The warning beeps and flashing LEDs will occur every 30 seconds.
On Timer Drying programs it will run for the time remaining and in Sensor Drying programs it will run for 90 minutes. As the exhaust air temperature can not be sensed the element will be cycled on and off at a preset amount. The cycling time of the element will vary depending on the amount of time remaining.
NOTE: When this fault exists the dryer can still be used but regardless of the Sensor Drying program selected the dryer will use the 90 minute Timer Drying program, Timer Drying programs will use the selected program, and with both types of programs the element will cycle as above. The buzzer will also still be sounding.
If an exhaust sensor fault is detected the buzzer will beep and the Reminder Clean the Filter LED will flash. The LED flashes at different rates depending what is wrong with the sensor -
Fast (4 per second) = open circuit senor, broken wiring or multi pin plug not correctly fitted to the control board.
Slow (2 per second) = Short circuit in sensor or wiring.
The sensor resistance at different temperatures is as shown below.
Temperature (Celsius) Resistence (Ohms)
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
As you can see this is NTC thermistor with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
Jul 06, 2015 | Electrolux Dryers
Lenovo desktop 3282 beeps twice then 5 times and goes no further
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 01, 2012 | Lenovo Computers & Internet
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
How do shut off the beeping noise when the washing cycle has ended?
I too had this problem and it drove me and my husband crazy! We have the 300 series washer/dryer. You just turn on any cycle on the main dial, and then press both of the Option buttons. A short beep = Off. A long or double beep = On. Try it a couple of times and you will hear the difference.
You can visit the Bosch website, go under service locator, enter your zip and get an 800 number. They will walk you through it on the phone, which is what I finally did.
Mar 19, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Computer won't start. gives an error code of 1 long beep, then 3 short beeps , then shuts off. has phonix bios
I would try the following steps, if these don't work, contact Acer.
1) Remove power cord and battery.
2) Hold down power button for 5 seconds.
3) Replace power cord and battery.
4) Try to turn machine on.
If these didn't fix it, it's a hardware issue. Contact Acer for warranty support.
Mar 01, 2011 | Acer Computers & Internet
Our roomba vacuums, then beeps 5 times and shuts off.
Your cliff sensors aren't working properly. Tap the bumper five or six times to knock out anything caught behind it, then blow out under the bumper with some compressed air, really thoroughly. If that doesn't do it, call customer support at 877-855-8593.
Jul 04, 2009 | iRobot iRoomba 4000 Robotic Vacuum
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Toshiba Satellite A100-S8111TD Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
