Question about Zanussi WJS1265W Front Load Washer/Dryer
Power but nothing happens
Although my washing machine is on and the indicator light lights up the rest of the controle panel lights up. Is there a way of getting the electronics to restart? Or is the circuit board completely broken? Thanks Hightrees
  • Andrew Beint Feb 10, 2007
    I can't seem to edit the text once submitted! Anyway what I meant was that the rest of the panel doesn't come on although the power is on.
  • 1,294 Answers
Check your washer's plug. Set the wash programme & then press 'start'.
Posted on May 10, 2008
My candy lights are on but it will not start washing
Sometimes I think that those machines have a mind of their own. This certainly applies to my Candy washing machine and my computer.
  • What I do when the lights are on but nothing happens, is that I turn the machine off and wait 3-5 minutes
  • Choose another programme and push the button
  • Usually it starts washing but if not
  • I disconnect the electricity and wait 3-5 minutes
  • If nothing happens then, I give the machine a rest for ca 24 hours and hope for the best.
  • which usually happens
Jul 25, 2015 | Candy Washing Machines
Smart drive washing machine 608
Try Ebay. But be prepared these Control panel modules are very expensive
Jan 19, 2014 | Washing Machines
Dell studio 1735 direct media lights flash nothing else
it shows power section issue of motherboard
Jan 07, 2013 | Computers & Internet
Control locked red light is on so nothing I can do to power it up and use. I turned the breaker off and on but nothing happened. What can I do to fix this?
If you are holding in Auto Dry Level for 3-4 seconds this should unlock the controls. If not, this usually indicates a stuck button on the control panel. Feel the push-in action of the Auto Dry Level button to see if it feels stuck or hanging up in any way. If the button feels right then this indicates that the user interface (touchpad) is at fault.
Oct 20, 2012 | Kenmore 6.7 cu. ft. Electric Dryer
Amana front loading washer won't run after power outage. Panle does light up.
Possible that the program controller unit has failed if there is no display or power in the indication. You will need to remove panel to check on the fuse and if the new fuse fails it is possible there are error or hardware failure within the board.
Please remove and check the power panel for shorted drive, rectifier or capacitor, if not the panel must be replaced.
Jul 04, 2012 | Amana Washing Machines
The only button on the panel that will light up is the 4 hr delay nothing else happens
This type of diagnosis will require taking voltage readings at the control board with a meter to find the root cause of the failure. Please see the rest of the information provided & the images below for the accessing, testing & replacement instructions.
1). Put the washer into the Diagnostic Test Mode per the Tech Sheet. 2). Did the Right Hand Interface light up? 3). IF the Right Hand Interface did not light up in Step 2 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). 4). IF you do not have the 5 VDC then remove the MI3 connector from the Machine Control board. IF the display lights; replace the Motor Control board. IF the display does not light; replace the Machine Control Board. 5). IF you do have the 5 VDC then replace the Right Hand User Interface. 6). IF the Right Hand Interface does light up. Lock the controls by pressing the control lock button for 3 seconds. 7). Once the control has been locked press the power pad. IF the control lock light blinks when the power button is pressed it tells us the power button is sending the output from being pressed to the right hand interface but the right hand interface is not responding and will need to be replaced. 8). IF the control lock light does not blink when the power button is pressed replace the center user interface.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My duet washing machine is saying control panel lock out and nothing will come on. Any suggestions
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Front Load Washer on the blitz
remove bottom panel and ck pump for obstruction especially if water is still in tub
Jul 21, 2008 | Kenmore 43142 Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
147 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
