Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
  • rose_waldie Dec 05, 2008
    Thank you Aerial Plumber! I shall try your advice tonight!
    Rosemary.
  • 33 Answers
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Posted on Dec 05, 2008
It takes a year for the decreased water flow to develop; I bought a new faucet a year ago. I took the areator off completely as it was plugged with calcium(I'm assuming). I have a tankless water heater, and it needs high flow for the heat to kick in. So I have a problem, and I will follow guidelines in hopes of solving it. Thanks
Posted on Dec 27, 2008
KWC faucet leaking around the main stream of water
Yes, go to HD or Lowe's and buy a new one.
Be sure to take the old one for comparison.
Nov 20, 2017 | Delta Model 470: Signature Kitchen...
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
I have the model 470 signature pull-out Delta faucet in my kitchen sink. It was installed about 5 years ago. I can no longer rotate the faucet without applying an extreme amount of pressure. Is there a fix...
Contact Delta at 800-345-3358 and ask for replacement parts. With the lifetime warranty Delta customer service was awesome and sent out parts I needed to fix this same faucet.
Jan 10, 2011 | Delta Model 470: Signature Kitchen...
Very low pressure on delta 470 faucet
To get full pressure you need to pull the wand away from the base. Then remove the wand from the hose becareful not to loose the washer. When the wand is removed look down the wand you will see a plastic part. That plastic part is a flow restrict-er. You need to put a screw in the restrict-er and pull it out. When it is out put wand back on the hose then you will have full water pressure.
Jan 16, 2010 | Delta Faucet Delta 470-BL-DST Signature...
How do I remove delta 470 kitchen faucet? It won't swivel
If the 470 is typical, there should be two large nylon nuts on the bottom of the faucet tubes that hold the faucet to the sink. First, turn the water off, then open the faucet to drain any pressure. Next, disconnect the feed lines (hot and cold) that connect to the faucet from under the sink (be prepared for some water back flow, so paper towels would be a good idea). After the feed lines are disconnected, you should be able to reach up (usually behind the back of the sink basin) and access the two large nylon nuts (one on the cold and one on the hot). These nuts typically have raised portions so that you can get a grip on them. If you are lucky, you will be able to turn them (lefty loosey, righty tighty) by hand. If not you may have to work for some time with various pliers or other tools getting them to turn. Once you have them off, the faucet will simply lift up from the sink. Installation of another faucet should simply be the reverse procedure.
Good luck.
Oct 03, 2009 | Delta Plumbing
Delta Kitchen Single Faucet 470 suddenly would not give water
Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
Jun 15, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Mar 24, 2009 | Delta Model 470: Signature Kitchen...
Instructions for the installation of a Delta 470
Here is the owners manual and installation instructions for your particular faucet:
Delta 470
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta Model 470: Signature Kitchen...
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
1,156 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
