Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
Putting back together correctly after installing new heat sensor
Wind tunnel self propelled model U6430-900 the drive part the spring that locks handle positions the two brackets which screws for which I can't remember the order in which I took these out to get to the heat sensor.can someone help me with a diagram or some detailed instructions so I can give my mom a properly working vacuum back thank you
  • jeanniemy60 Dec 05, 2008
    it is not a bagless model
  • 37 Answers
The hoover website does NOT give screw sizes,unfortunately!
cut and paste following info
http://www.fixya.com/support/p40544-hoover_ultra_u6430_900_windtunnel_bagged/manual-4481/page-13
Posted on Feb 27, 2009
Is it necessary to take the vacuum cleaner apart to change the belt on a Hoover Wind Tunnel Self Propelled vacuum cleaner, model UI6460-900? If so, how is that done? If not, how do you get the belt on...
To change the belts, make sure the vacuum is not plugged in. Lay it upside down and remove the screws holding the bottom plate on. Remove the bottom plate, pull the brush roll out noting how the belt goes so you will know how to put it back together. Especially how it goes around the idler pulley. Remove both belts, replace both belts, install the V belt onto the transmission first then around the brush roll and put the brush roll in place. Install the flat belt around the motor shaft and then onto the transmission pulley.
Feb 06, 2011 | Hoover Self-Propelled WindTunnel Bagless...
My hoover wind tunnel self propelled vacuum wont stand up be itself. The locking thing is not working. Thank You. niblick43@yahoo.com
If you look at the foot pedal, see if it is locked in the base, and pivots freely. I have seen some of these that break the base, or break the spring hinge on the back side of the release pedal.
Mar 10, 2010 | Hoover U5753-900 WindTunnel Bagless...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled wind tunnel doesn't self propel going backwards.
Your self propel cable sounds like you need to have an adjustment. reccomend a service shop repair.
Sep 25, 2009 | Hoover Vacuums
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
HOW DO I REPLACE THE DRIVE BELT ON A HOOVER WIND TUNNEL SELF PROPELLED
Take the brush belt and slip it over the pull into the groove. Then take the flat belt and hook onto the motor shaft and then pull belt over pull and push it around the entire pulley. It can be difficult but after the first time it is easy. You have to push the belt up with your thumbs so the belt will wrap all the way around
Apr 06, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Repplacing power cord on Hoover Wind tunnel (not self propelled)
I am thinking that the cord goes in on the back, just below the handle. Remove the handle, then from the front, remove the tool holder(#8), then you can get to where the cord comes in and hooks up.
Feb 12, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hi
This is HARD and you NEED electrical knowledge and IF NOT UP TO IT YOU COULD CAUSE PROBLEMS TO YOUR SELF AND OTHERS.
You do not say what the problem is with the cord.If is it damaged then it needs to be replaced with a new one.and then above applies.
Take Care as to what you do.
SAFETY FIRST---ALWAYS
Hope this helps
Jay
Nov 17, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propelled wind tunnel vacum will notpropell itself
Must be a Hoover, The flat belt may look ok but I am sure it has stretched to the point where under load it won't drive the wheels or the brush roll. Could also be a bad brush roll.
Nov 06, 2007 | Vacuums
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
133 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
