Canon EOS 400D / Rebel XTi Digital Camera Logo
Posted on Dec 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
400D manual mode
I have a canon 400D SLR, the problem i am facing is i cant change the exposur compensation manually when using it in manual mode. is it possible to do this??
old marine
Level 3:
  • Master 2,426 Answers
  • Posted on Dec 05, 2008
old marine
Master
Level 3:
Answers
2426
Questions
0
Helped
951828
Points
10742
You are exposure compensation in manual mode. If you want the shots lighter, either open up the aperture or slow the shutter. The exposure compensation feature is to override the automatic settings determined by the camera in the auto-exposure modes.
I'm trying to find out if the Canon Eos 3000N 35mm SLR camera has manual Aperture, ISO and Shutter speed control's? Can you help?
Although the 3000N relies on batteries for all functions and has various auto exposure and DX film coding modes, you can override and manually select all the exposure functions you have mentioned.
2helpful
I'm doing a project for school and i need to change the aperture for different photos. But my camera refuses to take the photo on any other aperture. Why is there an aperture adjuster if you can't use it....
It depends on the lens.
If you're using a lens with an aperture ring, simply set the exposure mode to Manual or Aperture priority and change the aperture by turning the aperture ring on the lens. In Aperture priority the camera will set the shutter speed appropriately, in Manual you have to determine the appropriate shutter speed. If you want to use such a lens in Shutter priority or one of the Program modes, you must set the aperture to its smallest setting (largest f/number) and lock it.
If you're using a lens without an aperture ring then it's a bit harder. You can only use the camera in Shutter priority or one of the Program modes. You turn the command dial on the camera to change the exposure, and the aperture will change. If you want to use an exposure different than what the meter suggests, you can adjust it by using either exposure compensation or changing the ISO setting (or both).
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n6006af/nikon_n6006af.htm
What type of exposure system does it have?
The N2000 has Program, Program Hi, Aperture-priority, and Manual exposure modes, with exposure lock and exposure compensation capabilities. It can TTL auto and manual with flash. The meter is full-aperture and center-weighted.
The Program mode sets both the shutter speed and aperture for optimum exposure. You can adjust the exposure if you want to emphasize shutter speed or aperture. The Program Hi mode tries to set a higher shutter speed for action and/or long lenses.
You can download a copy of the manual here if you want to know more about this camera.
To change the "exposure compensation" it's saying
When you change the exposure compensation setting, the camera will change the aperture, the shutter speed, or the ISO depending on the mode you're in and the shooting situation. That's what "compensation" means.
How do i set the AEB in my canon EOS 50D?
manual mode (M) > set the camera to "high speed continuous" shooting> exposure compensation / AEB setting> turn dial on top (used for shutter speed setting in manual mode) for desired setting.
4helpful
How do I change the shutter speed on a Nikon EM film SLR
The EM doesn't really have a manual shutter speed setting. It does have a Bulb setting for long exposures and a 1/90 second manual for flash, but otherwise the camera automatically sets the shutter speed to go with the currently selected aperture.
Normally you would set the aperture and let the camera set the shutter speed. You can adjust the shutter speed by pressing the exposure compensation button for +2 stops. You can also adjust the exposure by changing the ASA/ISO setting.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_em/nikon_em.htm
I can't change the aperture setting or time value in all (tv, av, M) modes - turning the wheel only changes the exposure compensation (-2 to 2) scale. Nothing else changes. I've read the manual a million...
Try this.
Turn the command dial on the top of the camera to [AV]
Use the [main dial] next to the shutter button to adjust the aperture.
The rear button that is round that is marked 'Av +/-' is the shift button. This controls the exposure compensation.
Could you be turning the wrong wheel?
Hope this helps.
Flash not firing properly
Could be the metering mode you are in. Could be the subject is too far away. Could be ISO is set wrong. Could be the lens aperture can't open up enough. Could be the exposure compensation isn't set correctly. Could be FE Lock is still on and the composition has changed. Does the <flash> icon continue to blink? Then you are too far away.
1helpful
Digital slr camera
You'll need to use your camera in manual mode.
If you want the subject sharp, but the background blurred, use a large aperture and high speed exposure. This will reduce the focal length.
Remember that a large apertures are often used for night shots because they allow more light through the lense. A fast exposure will prevent the shot from being over exposed if you are taking it in daylight.
Flash photography is not recommended for the effect you are after.
Manual exposure trouble in studio
exposure compensation can be dialed through the '+' and '-' keys in the upper right hand side of the camera body. The shutter speed should alone take care of the exposure meter if the aperture is more or less good...
ps: sometimes when we increase the shutter speed to 1/2000 th of a sec..it takes a while to reach the zero mark in the exposure bar since you need to dial more to reach an acceptable shutter speed like say 1/10th ...or 1"...
Regards,
Gaurav
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
