Question about Cell Phones
Cannot connect generic bluetooth headset to nokia 35555
When my Nokia looks for paired devices it finds none even though I have my Bluetooth headset ''Cellular Innovations'' model # HFBLU-LT100 turned on and ready.
2 Suggested Answers
SOURCE: need pin number for Cellular Innovations Hfblu-1k 5-Piece Bluetoo
The oin number is 0000
Posted on Oct 16, 2009
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
I am trying to pair Nokia E63 with Bluetooth Headset BH-213 but my Nokia E63 is not able to search Bluetooth Headset device. I have already turned on Bluetooth of both devices. Please guide me.
Please follow the proper instructions given below to successfully pair your Nokia E63 with the Nokia BH-213 Bluetooth Headset.
1.Ensure that your phone is ON and headset is OFF.
2.Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly.
3.Activate the Bluetooth feature on your phone, and set it to search for Bluetooth devices.
4.Select the headset from the list of found devices.
5.Enter the passcode 0000 to pair and connect the headset to your phone.In some phones,you may need to make the connection separately after pairing.
6.When the headset is connected to your phone and is ready for use,the green indicator light flashes slowly.
However if you are having problem with the Bluetooth connectivity of your phone the most probable cause may be a malware attack.It can be solved by cleaning your phone memory by entering *#7370# on your phone and restoring the default settings when prompted.Make sure you back up your contacts to the memory card or copy it to the SIM directory.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 24, 2011 | Nokia Bluetooth-Headset BH-213 2600...
Hi, i have bought a new Nokia bluetooth headset BH503, but it is not able to pair with my mobile phone Nokia E71, apparently my phone is not able to detect the bluetooth headset.It shows " No...
Hi ttc81,
Please make sure that your phone's bluetooth is in shown to all mode and not in hidden mode.
Also check if there are any particular instructions in your bluetooth headset's manual for pairing a device.
If the above procedure does not work , try to pair the bluetooth with another mobile phone and if it gets paired , then it means that your bluetooth is not compatible with Nokia E71.
Hope this helps ...:) Let me know in case you have any queries.
Jun 18, 2011 | Audio Players & Recorders
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
May 03, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Bluetooth connection
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
How to connect LG cookie with Nokia Bluetooth BH 101
Put your Nokia Bluetooth BH 101 into pairing mode - this is normally done by pressing and holding the power key for several seconds. An alternate bleep will sound with a flash light to indicate that you are in pairing mode.
Now using your Cookie, press Menu > Settings > Bluetooth > Search
Your Cookie will find the Nokia BH101 bluetooth headset and then it will ask for a pass code. This is usually four zeros (0000).
You should now be connected!
Apr 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Reprogramming bluetooth
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Mar 15, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Can not remember how to pair my nokia bh208 headst
Try this:
Pair the headset
1. Ensure that your phone is switched on and the headset is
switched off.
2. Press and hold the power key until the green indicator light
3. Activate the Bluetooth feature on the phone, and set the phone
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing.
You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the
phone menu where you can view the currently paired Bluetooth
devices. The headset is now ready to use.
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-208_APAC_UG_EN.pdf
Mar 03, 2009 | Nokia Bluetooth Headset Headset
How do I connect my h350 motorola bluetooth with my nokia 6275cel
Try video instructions on connecting Bluetooth headset to Nokia phones on www.HandBookLive.com under Electronics category (Motorola H710 headset). It should be pretty much the same for all headsets. Watch chapter on Pairing phone to headset (Nokia example) It shows you the steps and what the phone screen will look like on your phone as you go through the steps (activating Bluetooth option on the phone, then searching for devices (headset) and finally pairing the headset with your phone.
Dec 17, 2008 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Cell Phones Logo
88 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
