Question about GE Security Simon 3 Wireless Home Security System
Hi i need to know that how to programmed the timer test
  • Brian Hankins
    Brian Hankins May 11, 2010
    I am not sure what you are refering to, I might be able to help with a little more information...
  • 80 Answers
You should have your company program this. howerver her is the infor if you know hoe to get into programing.
Option 16: Auto Phone Test (Default = off)
Determines whether the panel automatically performs a periodic
phone test (on) or not (off).
The test interval can be from 001 - 254 days. Entries must be
3 digits. The time of day the panel performs the test is determined
by Option 72: Supervisory Time, which must be
turned on for this feature to work.
Note
For UL 1635 listed systems, Auto Phone Test must be set to 001
days.
 To set Auto Phone Test, press:
1. Add
2. Option #
3. 16
4. Use the numbered keys to enter the number of
days 001 - 254 (all entries must be 3 digits).
5. DONE
 To turn off Auto Phone Test, press:
1. Delete
2. Option #
3. 16
4. DONE
mj
Posted on Sep 01, 2009
Problem with Grasslin Towerchron QE2
1) Contact Grasslin UK for warranty coverage:
http://www.grasslin-controls.co.uk/contact.html
2) Reset timer and reprogram.
Move slide switch to to right 'set own program'
Then when times are programmed, move slide switch fully right to 'run own program'
http://www.tfc-group.co.uk/assets/graphics/static/QE1-QE2_GB%20instructions.pdf
3) Test that unit is receiving at least 80% rated voltage 240V x 80% = 192V
4) Buy another unit
Jan 29, 2013 | Hardware & Accessories
I have read about problems with the cycle not advancing or getting stuck on an SHU303 Bosh dishwasher. I have this problem intermittently. Usually when the dial is at the 6pm position, and lately during...
Hello Brien, First let me start by apologizing for the difficulty you've had here at FixYa. It is unfortunate the assistance (or lack of) was not helpful or specific to your inquiry, but I'd like to attempt to make amends. I am quite familiar with your model and in fact have serviced Bosch for around 15yrs. When you receive the timer (It is very rare to need one in a Bosch, more likely stat on the inside door panel) I'd be more than willing to guide you through the process and I will even send you a complimentary service manual if you provide an email address. I will understand if you have closed the door on any further input from "experts" here at FixYa but will do what I can to help if you're open. Sorry once again and good luck going forward. Regards, Macmarkus :)
May 20, 2011 | Bosch 23 in. SHU303 Built-in Dishwasher
0192773 installed a week ago, started but didn't complete timing. (1) today the face is blank, responds to no attempts. (2) lost my insruction sheet.
Utilitec 0192773 instructions appear on link below:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
I have tested this timer.
But there is no certain way to know what problem your timer is having.
1) Instructions say to reset timer when you have problem: This is true for most timers.
Simply press reset button for 3-4 seconds.
Screen should display. If not, timer has probably gone bad.
Reset clears all programming, and you need to reprogram timer.
2) If timer worked correctly at one time, then your wiring is good, so wiring is not suspect.
3) When electronic timers malfunction, suspect #1 is line interference.
Buy cheap circuit analyzer from home center and plug into outlet on same circuit breaker.
If line is not clean, then track problem back to light fixture or fan or defective switch, defective outlet. Use process of elimination by disconnecting light fixture, and then outlet, etc.
4) Another suspect is timer programming. If programs overlap or conflict, then timer will not operate as expected. Review timer programs: Press PROG button to scroll through on-off settings. To delete program, hold down RESUME button. Make program schedule before starting, and review programming steps shown on link above.
5) I burned up a 0192773 on purpose by adding 240V to see what would happen. The first time, reset restored timer display. Second time, the timer was bad. I bought another from Lowes and then returned bad timer.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Hardware & Accessories
My DVR receiver is recording programs that i originally did not put on the schedule. My receiver is also showing the programs in the guide and my daily schedule as "No Info Available". I have...
Hello! For these issues, here are a few simple steps:
First, for the DVR recording shows, you just need to delete those timers. They may have accidentally been set up.
1. Menu, 7-Daily Schedule
2. Timers
3. Edit list
4. Select any timers that you did not create, or want deleted. This will stop them from recording!
For the program guide:
You just need to download the program guide. Here's a couple easy ways:
First way:
1. Pull up the Guide
2. Press 999 then the right arrow button (Browse) until the guide prompts a download,
Second way:
1. Pull up a menu. Press 6 (Sys setup) -1(Installation) - 1( Point dish)
2. Highlight and select Check Switch on the upper right
3. Select test at the bottom left. (If a message comes up between steps 2 and 3, select yes. )
4. Press VIew live tv, and allow the Acquiring signal message and the guide download to go through.
I hope these steps help!!!
Becki Barned
DISH Network Customer Service
Jan 13, 2011 | DISH Network DISH-2800 DTV Receiver
Do not know how to set timer DT300 for Lights
Hi
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Thanks.
Dec 27, 2010 | Audio Players & Recorders
Intermatic Timer HB88RC unable to program it following instructions. Will not turn on in Automatic mode. Works fine in manual On mode.
HB88RC manual online:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
These timers are frustrating sometimes, fortunately this timer can be unplugged to set programs under good lighting.
When I have problems, I set it down for a while and then go back to it later.
Right now I own 25-30 different Intermatic, Woods, GE, Utilitec timers for testing and programming difficulties. Each one offers different points that are confusing.
Some new timers are simply defective. One guy today had 2 defective Woods timers, which made me suspect electric line needs line analysis. You might try your timer in another plug, for example indoor plug in another part of house to double check line is not interfering with timer electronics.
Reading HB88RC manual, there is not Dusk-dawn option, and programming steps are pretty straightforward compared with other timers.
This leads me to believe there is some small thing missed or line is bad, or timer is defective.
Return it if it's defective.
Here are some trip-up points, and they may not apply to you.
1) Current day has to be set. Hold clock button down while setting current time.
2) When programming, each event requires ON time and OFF time. For example event1 ON has to be set and then event1 OFF has to be set. Then set event2 ON and then event2 OFF.
3) When programming, check screen carefully to make sure 1ON appears, and then 1OFF appears in screen exactly like Fig1 and Fig3 shows.
Now I frequently e-mail Intermatic asking for manual clarification, and they e-mail back ... sometimes their manuals are a little bit off here and there. But this manual looks clean and matches what I see in other timers.
4) Each ON time requires OFF time for same choice of days. For example ON 7pm Tuesday and OFF 9pm All-days-of-week will not work correctly.
5) ON 7pm Tuesday and OFF 7pm Tuesday will not work.
6) Conflicts in programming cause some timers to skip programming: For example event1 says ON
at 7 pm Tuesday and OFF 9pm Tuesday, but event2 says opposite.
7) Since manual override works correctly, we know Load is functioning, and we know plugs on timer are working. Timer load can be lighting or pumps or heaters, but manual does not specifically say florescent. So timer MIGHT not work for compact florescent bulbs. If you have CFL bulb, try another type of Load: for example incandescent table lamp.
And that's everything I know, like Bubba Gump shrimp.
Nov 25, 2010 | Intermatic HB88RC - 7-Day Programmable...
I need to know how to reset the timer. Right now it says DUSK, what does that mean?
You posted under ST01C Intermatic timer.
DUSK is the dusk-to-dawn option available with astronomic timers like the ST01C.
If the ST01C is not your timer, add a comment with your timer brand.
I have tested the ST01C and many other timers.
To diagnose the timer, press manual override (on-off button) to see if timer operates Load.
The ST01C will not operate the Load if battery is bad, or if timer has gone bad.
Replace CR2 battery, and then re-program current time and day.
Current day settings are lost when battery goes bad, but the on-off programming remains indefinitely inside timer memory until the reset button is pushed.
To clear timer memory, hold down on-off button and push tiny round reset button for several seconds.
The following link shows the manual and EZ steps to reset timer:
http://waterheatertimer.org/ST01C-program.html
The link also shows other timers in case you have a different brand.
Nov 11, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hi, I have a Dayton # 2VJ58A Ditital time switch,can I program P1 and P2 with some of the same on and off times during the week. How does the timer know which times to follow when it is put back to the run...
Dayton 2VJ58A is a small, expensive 2 channel timer.
My understanding is that 2 channel timers are made "for the independent control of two circuits." I assume the advantage of multi-channel timers is needing just 1 timer on the control board.
If you are using 2 channels to control one circuit, I don't know the outcome, or if the 2VJ58A is made to do that job. It may ruin the timer!?! Be careful.
The less expensive ST01C timer offers 40 programs per week where overlapping times can exist on same load. These timers advise not to program overlapping times, ST01C troubleshooting says NOTE: Your switch timer automatically skips any conflicting ON event
Dayton timers are made in Japan but I could not locate a web site other than Grainger who sells the product. Probably the timer manual has manufacturing info. Grainger sales might be able to help?
http://www.grainger.com/Grainger/DAYTON-Electronic-Timer-2VJ57
Solution: I would call the seller, or Grainer, or the manufacturer. They might know about the software parameters. I would re-read the instructions carefully, and read up on multi-channel timers before putting power to the timer.
Let us know what you are trying to accomplish with the timer, and maybe we can help from that standpoint
Sep 20, 2010 | Dayton Audio Hardware & Accessories
As to 0912773: the manual leaves out many things that one has to know in order to set and use the switch. As it is, the switch doesn't work at all, except as an ordinary manual on/off switch. $25 and...
Tiny print on the instructions is enough to aggravate ya fierce.
You are replacing switch that has 2 wires with a timer that has 4 wires.
1) 5 minutes to Test wires: If your switch has 3 wires, then you have wrong timer. You need Intermatic ST01C or EJ500C. If your switch has 2 wires, then continue: Disconnect both wires from existing switch. Pull them out where you can test with ordinary tester. Power is on. Test each wire from switch to bare copper wire. When test light comes on, that is the hot wire and it is probably Black.
2) 3 minutes to connect wires:
Timer black wire goes to hot wire which is probably black
Timer red (or blue) wire goes to other wire that was connected to switch
Timer white wire connects with other white wires that are held together with a wire nut and pushed to back of box. [If box does not contain other wires, connect Timer white wire to bare ground wire.]
Timer green wire connects to bare ground wire
3) 5 more hours to program timer
Tiny print shows 5 steps for programming timer. Write the steps out so you can see them clearly. Drink a glass of water. And pull a chair in front of timer to set 7 on and 7 off programs. It will work fine.
Aug 24, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Where is the defrost timer located on ge side bty side model gss25jfmdww
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
GE Security Simon 3 Wireless Home Security System Logo
228 people viewed this question
Top GE Home Security Experts
Sean
Grantec 2000
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a GE Home Security Expert? Answer questions, earn points and help others
