Operating System: Windows XP SP3 Can't access my NEC DVD_RW ND-7550a uninstalled and reinstalled....says it is corrupt...how can I fix it
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Ok if it's not working whatsoever, you can use Firmware to try and reset the drive back to Factory Default Settings.
You'll have to read through the page first, as there is some possible risk of it failing to solve problem, and if it's not already, Kill the drive totally.
Anyway, I've flashed various drives that have had the same problems, and successfully restored the Writer back to it's original state, so if it looks deadish to you, then you may aswell go ahead and try the firmware, as if you send it to get it repaired it would cost you an arm and a leg, just so that some engineer can do the same thing, and you could of ended up buying something like a Pioneer 20x DVD-RW for less then 15 quid Brand New if you know where to look.
Anyway here's the link :-)
http://binflash.cdfreaks.com/
Scroll down to the "Download" Section, then fownload the Win32 GUI  v1.45 release.
Posted on Dec 05, 2008
Nec nd-3550a won't recognize dvd discs. will see and play cd discs. Have checked all registry entries mentioned on multiple web sites. Tried to take it apart to clean the lens. Got the bottom off but...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall hope this helps
Mar 31, 2011 | NEC ND-3550A-KIT DVD±RW Burner
I have a NEC DVD RW ND-3530a and my windows xp service pack 3 stopped recognizing it. it no longer reads as a drive. The device manager has it listed with a yellow !. I have tried uninstalling and...
Remove the drive from your computer, and temporarily connect it to another desktop computer.
If it still does not work, then it's time to responsibly recycle it, and spend $40 to purchase a new CD/DVD reader/writer.
Dec 10, 2010 | NEC ND-3540A DVD RW Dual Layer Burner
: "WRITER ERROR [ILLEGAL REQUEST (LOGICAL BLOCK ADDRESS OUT OF RANGE)]" Burn4free worked before I rewrote the computer(win XP) .what do I need to install?
You could try and uninstall the drive in device manager, then let the pc reinstall the drive.
Try some other software, i use IMGBURN and CDBurnerXP.
Get back if this does not fix your problem
Aug 19, 2010 | NEC ND-2500A DVD±RW Burner
Installed XP SP3 to my Dell 6000 and now NEC 6500a can't be found. Device manager says that the drivers are loaded by cannot find the hardward Code 41
see if its recognised in the Device Manager. Start/My computer/Control Panel/System/Device manager.
if so remove or uninstall the Drive.
Physically remove/eject the drive from the Computer. reboot then shutdown. re-insert the Drive. boot computer and see if it,s detected by the system or ( found new hardware Wizard )
re-install any drivers as requested. Installing SP3 shouldn,t do this. unless the drive was actually Virused Or failing already.
Mike @ compurepair.
Oct 16, 2009 | NEC ND-6500A DVD±RW Dual Layer Burner
ND-6750a not recognized by WinXP SP3
Try the firmware fix and driver installation on this page: http://www.techspot.com/drivers/driver/file/information/9706/
It looks like the "windows updates" outdated your original driver.
Jul 03, 2009 | NEC ND-6750A DVD RW Dual Layer Burner
Have NEC 3550A DVD/rw. re-installed windows XP professional & all else.. DVD will not recognize most dvd discs.Got drivers from NEC.. still problem
Go to:
1. start > run > devmgmt.msc
2. Under DVD/CD Rom drives make sure it's installed (Uninstalled = Yellow icon)
If all drivers are applied correctly this could be a problem with the DVD Region Settings.
Go to:
2. expand
3. find the device
4. right click > properties
5. go to dvd region tab
6. select the desired region
Warning: some drives only allow you to change it up to 5 or 4 times so be careful!
Jun 23, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
DRIVERS CD-ROM NEC DVD RW ND-2500A
WINDOWS CANNOT LOAD THE DEVICE(DVD ROM) FOR THIS HARDWARE MAY BE CORRUPTED OU MISSING (CODE39)
Oct 30, 2008 | NEC ND-2500A DVD±RW Burner
I can't burn anything ...
download this its recommended for sp3 then try to burn again
http://www.divx.com/
Sep 09, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
NEC ND-6500A Cant burn DVD-R
I figured out what was causing the problem with my NEC 6500A on my Dell laptop: The Sony Picture Motion Browser software that I was using to burn DVD's is only compatible up to Service Pack 2 of Windows XP. The day after I installed Service Pack 3, the software stopped burning DVD's. So I uninstalled Service Pack 3, rebooted, unistalled the Sony PMB software, rebooted and re-installed the Sony PMB software and I can now burn DVD's again. So check whether the software you're burning your DVD's with is compatible with whatever version of your operating system you're operating with. Hope this helps someone else!
Dec 16, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
