DVD Menu selection not available from Setup Menu
Trying to format new DVD+RW
Pg 27 of Manual says to go to Setup Menu/DVD Menu
Only General Settings and Timer Programming menus are available.
Title List and DVD Menu are grayed out
Does auto-format when inserted, but trying to record gets This Program is not recordable in +VR mode
If I use a DVD-R, I get This Program is not recordable in Video mode. Both issues say to change formatting in DVD menu.
Trying to record movie off DVR from HBO.
  • sue_mclean Dec 17, 2008
    I did resolve the first issue. The DVD menu is only available when there is no DVD in the tray.
    Still need help on the 2nd.
  • sue_mclean Jan 14, 2009
    Thanks, but from what I can see, this DVD recorder has a record-once restriction which the error does not reflect. It will not record anything to DVD from the DVR or tapes recorded on its own VCR, yet it will record to the VCR multiple times. It will record to DVD from tapes recorded on another VCR.
    I have yet to try recording direct bypassing the DVR, but I'm betting it will. I just get so aggrivated with every test, and wasting DVD's that I give up.
    Secure technology at it's finest! Shoot!
I don't have movies from premium channels, but do have cable HD channels. When I got the message re not recording in +VR, I copied from DVR to HD in PhilipsDVD-R and then dubbed to DVD.
Posted on Jan 14, 2009
No option to finalize disc
Either the disc is already finalized or there isn't enough space on the disc for finalization. Check if you have Auto-finalize enabled. Press Setup and go to the line "General Settings" with the up/down arrows. Press Enter. Then select Recording and Enter. Go to the Auto Finalize line and press Enter. Check both Disc Full and End of Timer Rec and see if these are set to On or Off. This option is explained on page 27 of the manual (page 29 of the PDF available from Funai Service http://www.funaiservice.com/manuals/SYLVANIA/ZC320SL8/ZC320SL8.PDF ). Remember that the finalization takes 20-50 MB on the disc.
I hope this helps.
Sep 07, 2014 | Sylvania ZC320SL8
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
How do i rewrite over a disc that is full
If you are using a DVD-RW or DVD+RW, you can format the disc by performing "Format". You can format DVD-RW for either video mode recording or VR mode recording. DVD+RW can be format in order to erase all content of the disc.
You may not be able to reformat a disc that is not previously formatted by your recorder an example would be a. DVD disc formatted by PC or another recorder.
Follow these steps to re-write:
Insert a recordable disc.
1 Press [SETUP].
2 Select "DVD Menu",
then press [ENTER].
3 Then select "Format", and
press [ENTER].
4 select "Start", then
press [ENTER].
5 Confirm by selecting "Yes", then press
[ENTER].
Formatting will start.
6 Formatting is completed.
When the disc is ready for you to rewrite to "100%" is indicated.
Formatting 100%
Mar 29, 2010 | Toshiba DR420 DVD Recorder
New DVD+RW in 6400 Dell not recognized
1.buy cd/dvd Rewritable disk
2. you can format this cd's/dvd's through your writing software
3.format option is available in your writing software,explore it, hope you can get rid from this problem.
Jun 28, 2009 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Disc will not finalize error comes up as e19 can not record to the disc. the show is actually recorded and will play back just not finalize. have tried -r/ +r and + rw and get the same message. unit being...
You don't need to delete timer rec programs to Finalize, Format or Erase discs!
Set the Mag 2160A (mfgd in 2009) to Source L3 (DV) using the Source button on the remote.
To Format a RW disc, set unit on L3 BEFORE inserting a new disc cuz the Formatting op is automatic and starts right away. It's also so short on a +RW (longer on a -RW) that you could think it had been Formatted.
Finalizing requires you to select it from the Disc Edit menu, so you can set the unit on L3 after inserting a disc for this op.
More into on all aspects of setup and op are here:
http://www.avsforum.com/avs-vb/showthread.php?t=940657
Apr 29, 2009 | Televison & Video
I can format dvds or record what is wrong
make sure that when trying to format dvd's you are using the bottom portion of the controls. i know it sounds silly, but the center arrows are for dvd playing and control....ff...rw....play, and the lower controls are more functional.
i'm not sure, but if you put in a blank dvd-r disk, it will allow you to format after going to the "setup" then using the lower arrow moving the selection over DVD. format is allowed in that selection. If you have already recorded on the DVD-R i don't believe it allows you to format, it only allows you to edit or finish.
i'm not sure how the dvd-rw works as i haven't used one in a long time. in theory, you should be able to format a DVD-rw.
hope it helps.
Jan 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Cant finalize dvd on a magnavox zc320mw8
you have to push stop from the title menu, then push setup. Then go to disc edit and finalize is there
Jan 11, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Setting the time on my iLO DVDR05 Recorder
1 Press Setup to enter the setup menu.
2 Press the up/down keys to select GENERAL, press enter, Use up/down keys to selet clock setting. press enter.
3 Move to the field to be edited using the up/down keys
4 use up/down keys to increase or decrease the value of the field.
5 To exit a field using the right/left keys
6 Press return to exit the clock settings menu.
Select time format from the menu and press the right arrow key. Use the up.down key to pick hour mode(12hr or 24 hr).
Thats the instructions from my manual.
Mar 18, 2008 | iLO DVDR05 DVD Recorder
Curtis DVD 2100 DVD Player
page 1 in the set up menu will allow u to reset to the factory settings.
Oct 11, 2007 | Curtis DVD1045 DVD Player
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Televison & Video Logo
697 people viewed this question
Top Televison & Video Experts
