Question about Pioneer PDP-4350HD 43 in. Plasma Television
I am trying to mount a plasma television, and i need to see if it is safe to run my data cables from my receiver to the television behind the wall. 1. Will it pass an inspection when I sell the house and 2. Will it do anything to my homeowner's insurance
    Sniper:
  • 50 Answers
You are correct in having concerns. Many articles on the web say cut two holes, run the wiring and you're done. This is incorrect, unsafe, and can void your insurance policy in case of a fire.
Many local building codes are based on the National Electrical Code (NEC).
First, the NEC does not allow flexible power cords (or extension cords) to be mounted inside of walls. This means you can't run the TV power cord inside the wall. So a new AC wall socket will have to be installed where it will be hidden by the plasma when mounted.
Second, all wiring run inside a wall must be rated by Underwriters Laboratories (UL) as Class 3, or CL-3. This means the cables between your cable box, DVD player, etc. must all be UL CL-3 rated. Fortunately, CL-3 rated HDMI, Component, Coax, and other cables are available. They are just a little harder to find and will cost a little more.
Third, make sure the wall mount you purchase can handle the weight of your plasma and is securely bolted into the wall studs.
If you follow this advice, you will pass inspection by even the most picky home inspectors and insurance companies.
Posted on Dec 05, 2008
Panasonic plasma flashing red light
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 11, 2013 | Panasonic Silver Tilt/Tilting Wall Mount...
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
I have a Akai PDP4225M 42" Plasma and I want to mount it on the wall, what type of wall hanger do I need. Thanks Pat
I found the wall mount for your Akai. check link.
http://www.dealtime.com/xDN-tv_accessories--akai
Apr 20, 2010 | Akai PDP4225M 42 in. Plasma Television
Loss of red color using video component cables.
Direct plug the component cables between the plasma to component you are using and see if you get the same problem.
If you dont, add in the receiver. Still dont..its the inwall wiring. :)
Mar 16, 2009 | Samsung LN-T4665F 46 in. LCD Television
Wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Jun 28, 2008 | Televison & Video
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Advise on how to wire tv home entertainmet dvd hdi cable together
hdmi is the least amount of cables you'd need to run, 1 cable for audio & video for each device, assuming they have hdmi outputs on them and you have enough inputs on your tv.
Dec 22, 2007 | Televison & Video
Pioneer PDP-4350HD 43 in. Plasma Television Logo
100 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
