Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
DVR not playing.
I have some shows recorded on my DVR and none of them will work.
When I play them it won't work, and it says I have the show recorded with the right amount of time.
  • 374 Answers
Try this: Press the power button and hold it for about ten seconds and let the system reboot. Try to use the dvr again. If that was unsucessful try unplugging the receiver from the wall outlet for approxiamately 30 seconds and repower the systen and try again.
If these have not worked You can press menu-6-1-3 and view the system info screen. Go to the details options and select it. Once the details screen loads arrow all the way down until you see the values of which value 9 is the last one. If value 7 is not 4 you need the unit replaced. If all the above did not work the unit will still need replacing as the hard drive has locked up.
Dish has a new receiver called a 222k which has an expansion USB port that will allow you to use an external hard drive to use as the dvr as the 222k is not a DVR unit; it is a HD dual tuner. The external hard drive offers many advantages such as being able to take your recordings on the road, ability to keep recordings if the receiver fails, etc. Another awesome device they have also is called a sling box which will allow remote viewing of your Satellite from a remote location over a laptop, PDA, or cell phone.
I hope this helps you and thanks for using Fix Ya.
Posted on Dec 11, 2008
Bunker hill 67139 dvr hard drive wrong year 2058
The issue may be is that you have a DVD in your dvr , that still shoes that date and time. Just a possibility, not sure,. try to see if you can take DVD out of dvr, and use a new one. I happened to me but, the case was a vcr,and I had a recorded video tape which while playing , was showing a blue screen, with "no data received" which actually it was when no data vcr was receiving from cable at the time it was recording . If the problem still is not solved then there is issue with some circuits, and processors. Also you may want to check if Bunker Hill has any customer support, to check with them.
May 18, 2014 | Televison & Video
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
Ustvnow dvr tv shows unable to watch recorded shows when press play without causing tv screen to flicker twice and not able to watch tv program
It appears it is not your fault. I contacted ustvnow and they said they are "working on it" but currently the DVR service is not available on roku. If you find an answer elsewhere, I'd love to hear it
Dec 01, 2012 | Televison & Video
My smilebox slide show won't record.
My creations preview great but when I press the save to DVD nothing happens, I am not saying is a smilebox problem, but It used to work just fine. I am just wanting to know what to do because I just wasted 40 bucks if I cannot burn it
Jun 21, 2012 | smilebox.com
Dish 625 DVR recorder won't play recorded shows. It gives me an error code (05)
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Sep 05, 2009 | DISH Network DVR-625 DTV Receiver /...
No Sound
cable pin is lloosed then change the cable pin
Jan 22, 2009 | Pioneer DVR-225 DVD Recorder
DVR won't play
I hae a Motorola 6412 that had this problem. I turned it off, then unplugged it for 30 seconds. After turning it on I had to wait 1-2 minutes before I could acces the DVR, but it work now.
Jun 11, 2008 | Arris DCT6200 DTV Receiver
Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Toshiba dvr 160 gig can't play dvd's
While Pressing Easi Navi-Hit the number 2 on the remote control
Jan 01, 2008 | Toshiba 160HD4 160GB HD Digital Video...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
258 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
