Question about HP Compaq Presario 6310US (DA201A#ABA) PC Desktop
Turn on computer-wouldn't boot
I turn on my computer, but screen remain dark and a beepin sound
comes from the motherboard. how do i solve this problem?
  • 51 Answers
The problem is your ram memory.open cpu door and remove ram and clean dust with soft cloth and restore.if problem is not solved then you
remove the currunt ram and resotre another ram if you have.
Posted on Dec 05, 2008
  • 385 Answers
This beeping sound is usually due to the ram, either it is bad or dirty. Get somebody to check it or open the case and remove the ram, clean it with a dry cloth and reseat it back. If you cleaned it and it still is doing the same thing, then the ram may be faulty and will need to be replaced.
Hope you solve this issue.
Thanks for using Fixya,
Lolita
Dark screen and flickering on the laptop computer model pcg 61611L
I would check the GPU by connecting an external monitor before booting it, that will allow the external drive to automatically work.
Jan 02, 2014 | Sony VAIO Computers & Internet
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
Toshiba Portege r200 was working normal (up until yesterday). Today, when I first turned it on, the fan was on and it sounded full blast, but screen remained dark (blank). I held power button until it shut...
The part that supplies the power to the screen is gone. I recall is is called the 'exciter'. They can be replaced, so take it to a computer repair shop. Same thing happened to my Toshiba.
Aug 18, 2017 | Toshiba Portege R200 Notebook
My screen is not working although the computer turns on with all the lights
When you
When you power up your computer and the monitor screen remains dark, the problem can be either be associated with your monitor, or your computer power supply/video card/motherboard or CPU. Perform the following tests to isolate the problem to either the monitor or the computer.
1. Turn off you PC and monitor. Then verify that the 15 pin video data cable connectors are fully inserted into their receptacles on the rear of your PC and on the rear of the monitor and they are tightened down. (on some monitors the data cable is hard-wired to the monitor). Then make sure that both your monitor power cable is securely plugged into a working AC power receptacle. (You can temporarily plug a lamp into your AC power receptacle to make sure you have a good source of AC power).
3. Turn on the power switch on your monitor. The amber colored LED on your monitor should come on. Then turn on your PC. The fans in your PC start to run and continue to run and the LED on your monitor should change from amber to green.
Now if the monitor led remains amber and the screen stays dark you either have a bad monitor or a problem with your video card, motherboard or processor.. Try using a different monitor. If that doesn't solve the problem, you need to have a PC technician test your computer.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 23, 2011 | Computers & Internet
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Dark screen, nothing comes out.
Make sure all connections are tight and secure. Troubleshoot like this.
Can you see the boot screen when it boots up( Before the Windows logo appears.)
1. Check and tighten all connections,
2. Possible monitor went out.
Mar 13, 2009 | HP (D7580-60003) Motherboard
Toshiba A75 Wont Boot up
It sounds like you may not have made a good connection to the motherboard from the screen when you put everything back together.
When you press the power button does the screen come on and then go off or does it not come on at all ?
If it comes on then turns off try to eject the CD-Rom that will be a definitive test of whether your power is still on, assuming your cd-rom is not totally mechanical.
Jan 29, 2009 | Toshiba Satellite A75-S226 Notebook
My screen remain dark when my laptop is turned on.
If you can hear the sound of Windows starting up, your blacklight probably died. If you can't hear the Windows start up sound, Windows may need to be re-installed. Most likely though, it's a faulty backlight.
Please rate, Thanks!
Oct 03, 2008 | Aspire Acer 7520-5324 Laptop
Booting problem and blue screen
Try booting the MAC OS disk. If it boots correctly, it probably is the hard drive. Also, If it boots ok, try the repair utility on the cd.
Jul 28, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
HP Compaq Presario 6310US (DA201A#ABA) PC Desktop Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
