Question about Bose Companion 3 Computer Speakers
Bose control pod stuck on green won't play - Bose Companion 3 Computer Speakers
SOURCE:
  • 5 Answers
SOURCE: Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Posted on Jan 02, 2009
  • 10 Answers
SOURCE: Where Can I purchase a bose companion 5 control pod?
you have to call customer service at 1-800-367-4008.Run about $35.
For the broken cable, have you tried to fabricate a new cable for it?
Posted on May 25, 2009
fixyathing
  • 341 Answers
SOURCE: Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Posted on Aug 12, 2009
SOURCE: Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Posted on Jan 26, 2010
SOURCE: Dim Light on Control Pod...very low volume output
I just fixed this exact problem. There is only 1-2 volts feeding the preamp IC's pin 4 JRC 2059. Positive side of C313 should be 12v(B+ to IC's) found shorted transistor just above C313. Collector goes to V+ 15v from power supply, Emitter feeds the preamp IC's. I used a 2sc3904 (NTE123Ap) unit back up and running
Posted on Jul 23, 2011
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
I've had the series 1 companion 3 for almost 4
Hi, This could just be a sign that your Speaker system is wearing out , and done its due...Also have you had any Power Failures or surge's Lately , if so then it could of damaged the Speakers aswell..
Hope you come right bud
Happy new year
Dec 28, 2009 | Bose Companion 3 Computer Speakers
Anyway to use Bose companion 3 system without the control pod?
had the same issue. Trial and error - I tried shorting every pair in the control pod dock with a paper clip. Turns out it is totally possible to bypass. You need two: top row, right side to third row, one from the right (below it by two spaces), and second row (there are only two in the second row, connect them). One tells it to turn on, the other passes audio through. I'm only getting sound from the right channel, so probably need to connect one more pair...
Read more: Can i operate my bose companion 3 without the control pod? - I lost my control pod. can i go around it. :: Ask Me Fast at http://www.askmefast.com/Can_i_operate_my_bose_companion_3_without_the_control_pod-qna6342714.html#q3658086
Jun 29, 2009 | Bose Companion 3 Computer Speakers
I pod nano will play but not take a charge
Well then you cannot charge your i pod on the bose system *******
Mar 01, 2009 | Apple iPod nano 3rd Generation
Jan 29, 2009 | Bose Companion 3 Computer Speakers
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Oct 03, 2008 | Bose Companion 3 Computer Speakers
Sep 14, 2007 | Bose Companion 3 Computer Speakers
Bose Companion 3 Computer Speakers Logo
62 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
