Laptop connected to WiFi yesterday but now cannot
Yesterday, I noticed a serious decline in my signal strength from my Linksys Wireless-G router. Normally, I get 3-4 bars in my bedroom but I only had 1 and internet speed was severely reduced. I checked a few settings, although I wasn't sure what I was doing and reset everything back to the way it was, and the signal went up to 2 bars.
I turned it off and went to sleep. Tonight, I come home from work and turn my computer on and I get no signal at all. My computer recognizes I have a WiFi connection but cannot connect because 'Windows did not receive any response from the Wireless Router or Access Point''...
My computer works fine connected with a cable to my router, and my mother's laptop works flawlessly (and did not have the signal problems last night like I did). I've been through a few googles of what to do and nothing. Gateway isn't offering tech support without a hefty toll and I'm stuck being attached to a 5' cable.
I did update the driver on my wireless card and all that jazz. I did spyware/virus scans, about 20 reboots, reinstalled drivers/cards out the wazoo, and I've tried to 'diganose the problem' a thousand times and Windows has nothing.
Please help.
  • 781 Answers
Try rolling back to the previous driver and also uninstalling and reinstalling the last driver update try this last in safe mode (try one thing at a time and test)
check if there's a firmware update for your wireless lynksys router.
although you got an odd problem... because you're mom laptop is fine so it's gotta be on your computer... mmmm.. still worth a try i think.
good luck!! post your findings for follow up!!
Posted on Dec 06, 2008
I have bought linksys wag200g **** its not working properly when i use wifi on my mobile.... and device disconnected after every 1 or 2 minutes.. i have ADSL connection......
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 18, 2012 | Linksys WAG200G Router
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
Have Eee pc with windows7. wifi connection looses connection every few minutes.Network adaptor problem
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
Sep 11, 2012 | ASUS Eee PC 900HA Notebook
I have the DIR-655. Poor coverage/Signal strength
What kind of construction surrounds your router? Weak signal indicates walls reducing signal strength. Try a repeater in weak areas.
Dec 30, 2017 | D-Link Xtreme N DIR-655 Wireless Router
My laptop connects to other wifi signal? how will I prevent it from connecting to other wifi?
you can specify in connection settings which wifi connection you want it to automaticly use. you can also remove unwanted connections from list of available connections.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Laptop driver needed
You dont need a driver for the wireless router. If your laptop can recieve wireless signal(from a wireless router) all you need is an active internet connection, configure the laptop and router to distribute the internet, you're good to go.
If your laptop cant recieve a wireless signal from a wireless router then you might need a USB Wifi Dongle.
Apr 06, 2009 | Linksys Wireless-G VPN router with...
Linksys N router drops signal
Its not dropping you because of the spectrums, it works on line of sight. If you are in a basement and your router is upstairs it has to go thru a floor and the strength is weakened. Go into your router and increase the signal strength. But you have to mod your firmware.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Here is a link to update your firmware.
Jan 24, 2009 | Linksys Wireless-N WRT150N Router
Would a neighbors linksys router interfere with my belkin connection?
do check the signal strength of the wireless connection..you can improve signal by removing any big objects between the compu and the router/access point and/or re positioning the router.also intervening walls will affect signal..the fact that you are getting a linksys signal impilies that your home network signal is weak..hope it helps!
Oct 29, 2008 | Belkin (F5D8231-4) Wireless Router...
Wireless connection to lap top
try opening network connections disable the default connection and enable linksystems
Jul 13, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
