Is there an adapter to connect your SD memory card to your laptop?
    President:
  • 2,110 Answers
Yes
there is adapter to connect micro sd card to laptop....
Posted on Dec 05, 2008
Tip
How to Transfer Files from Cellphone to Laptop and Vice Versa
<span>There are three ways that you can use enable for you to transfer files from your cellphone to your laptop or vice versa.<br /><br /><span style="font-weight: bold;">1. </span> <span style="font-weight: bold;">By using a connectivity cable</span>. <br /><br />It is a cable which you can buy from any cellphone stores. Just plug the other end to your computer and the other to your cellphone. You can then access the pictures in your cellphone.<br /><br />A connectivity cable looks like this.<br /><br /><img src="carloadrian_2.jpg" /><br /><span style="font-weight: bold;">2. Bluetooth</span>. <br /><br />Click the link below so that you will be directed to the procedure on you to connect your cellphone to your laptop by using bluetooth. <br /><br /><a href="/../support/t8013435-connect_laptop">CLICK HERE</a><br /><br /><br /><span style="font-weight: bold;">3. Memory Card<br /><br /></span><img src="carloadrian_4.jpg" /><br /> <a><br /></a> <span style="font-style: italic;">SD cards are used in many cell phones</span>.<br /><br /> Many cell phones come with removable memory chips, which can be used to expand the available storage on the cell phone, or to transfer files (such as music and pictures) between the cell phone and other devices. Once you identify the kind of expandable memory in use on your phone, an adapter can usually allow you to connect it to a laptop as if it were a USB drive. <br /><br /><span style="text-decoration: underline;">INSTRUCTIONS</span><br /><br />1. Determine what kind of two-gigabyte memory chip your cell phone uses. You can do this by checking the specifications of your cell phone in the manual or on the manufacturer's website, or by removing the card and examining it. As of April 2010, the most common kind of memory card used in cell phones is the SD format, which comes in standard, mini, and micro sizes. Your phone may also use the Memory Stick Pro or Pro Mini format. The format type will be printed on the side of the card. <br /><br /> 2. Purchase a USB adapter for the card you are using, which is available from many different vendors. If your card is in a mini or micro format, make sure that the adapter comes with a sleeve for the card of your size; this allows you to insert a mini or micro card into the sleeve, and changes the card into a standard size for use with the adapter. <br /><br /> 3. Insert the card into the sleeve, if necessary, then into the adapter. Connect the adapter to a USB port on your laptop. The card will appear on your laptop as if it were a USB drive. When you are finished working with the card on your laptop, you can move it back to your cell phone.<br /><br /><br /> </span>
on Jan 28, 2011 | Cell Phones
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
How do you transfer a photo from computer to sanDisk
Please keep the sandisk in to the USB port of system/laptop,
select the files what you want to send to sandisk, then rightclick on the selection. Then goto "Send to" option. In that you will find your sandisk. Select the drive of sandisk.
System will send the fiels to memory card.
Jun 08, 2011 | SanDisk 4GB microSDHC Memory Card
How to transfer music or pictures from my loptop to micro memory card
Many laptops have an SD card reader. If you do have one, you will need an SD adapter to plug the card in and then to put it in the laptop's card reader. If you do not have one on your laptop you will need to buy an SD card reader and an SD adapter.
Alternatively, you can try putting the microSD card into your phone or digital camera (if it does support one) and connect your phone/camera to the computer to access the data on the card.
Jan 04, 2011 | PNY 2GB microSD Memory Card
4gb sd card not format problam format uncomplet
I'm assuming you are having a problem formatting the memory card?
The soultion would be to connect it to a PC or laptop that has a card reader installed, then format the card via Windows.
If it is a micro SD card, you may need an adapter to convert it to a SD card.
Thanks,
Aug 11, 2010 | SanDisk 4GB microSD High Capacity Memory...
Hi this is sanjay , i'm having 1 GB micro sd memory card for my mobile nokia 5300 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in...
The password is there to prevent a thief from accessing the memory card, after stealing either the card or stealing the entire mobile telephone.
Keep trying different passwords.
Oct 22, 2009 | Microsoft Sony VAIO VGN-AR760U/B-Intel...
The m2 adapter i have does not fit my acer aspire laptop yet my laptop card reader says it reads m2 memory cards. is there a certain way of putting the card in to the memory card reader.
I think that with smaller memory cards like m2 and t-flash(micro SD) you would have to use their adapter(a card with a slot that normally converts it to SD) before you can slot it in.
Nov 06, 2008 | Computers & Internet
Help : Can I access Memorysticks on AXIM
Since a SD memory card is about the same size [width and thickness] as a Memory Stick, I doubt there will ever be an adapter available between these two formats. There just isn't any room unless they came up with a very large adapter which would stick out and be unwieldly. You can get Compact Flash adapters (which are much larger) from a company called Pretec for about US$59.00, plus I'm sure there are others. I use a full sized PC Card adapter on my laptop to convert between the SD Memory card for my Axim X5 and the SmartMedia card for my digital camera and MP3 player.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Computers & Internet Logo
David Payne
David Payne
