Question about Kenmore 63102 Electric Dryer
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help?
    President:
  • 878 Answers
A few things could be going on here. If you are hearing metal on metal sound I would start with the blower wheel itself. Sounds like it either came loose from the motor shaft or it's broke. Other things could be a bad drum roller that has frozen up causing the rubber smell. Your idler pulley could be frozen up and the belt is slipping on the drum. Go to this link http://www3.sears.com/ and post your model number to get a breakdown of your dryer. It wil show the areas I mentioned. Catriver..post back.
Posted on Feb 11, 2007
What is the bruning rubber odor - new dryer!
Im not familier with that particular machine but it sounds as though bits of the rubber backing you talk about has flaked into tiny bits and moved beyond the drum and into the workings of the dryer moter and heater. Contact with these will produce the smell and slight risk of fire.
The back of the applience will need to come off and cleaned out.How you accomplise this is up to you!!. If you have some one who is very handy at this sort of thing then grt.otherwise leave it to a proffesional. Obviosly compressed air gun is the way to do it.
Oct 15, 2013 | Maytag MEDE201YW Electric Dryers
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
There is a burned odor when drying my clothes. How do I get lint from inside the dryer out if this is a problem
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 20, 2011 | Miele Novotronic T1515A Electric Dryer
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
My whirlpool gas dryer is taking twice as long to dry clothes. I cleaned all vents and filter and also ran it with the exhaust vent disconnected and dryer still did not dry any faster, but there was a...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 25, 2010 | Whirlpool Dryers
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help? Lg washung machine/dryer combo(front...
Sounds like drive belt or drum supports, if the drier is gas I would check it out, could cause a fire, if it is electric still check to make sure it is not rubbing on the electric heat element, or it could be full of lint which is catching fire during normal operation and melting or burning the belt or drum supports.
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore 63102 Electric Dryer Logo
113 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
