Question about Car Audio & Video
Amp not working properly
Bought amp on e-bay Elevation DX 2000.1 ,  hookup to single woofer CVX 15 , 2 ohm.  turned on HU , heard pop and mmmm sound , woofer cone pulling down with force and will not release than smell of burning .hook up to different woofer and woofer pulling down again and smokes coming  out. Now that woofer don't work Contact  seller and he said this is a competition amp and I damage it cause I wired sub in series and also claims I wired  amp wrong the way the cone moved inward and denied me a refund. Volume, settings and gain set low.  Was this cause.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
You damaged youre unit
Posted on Mar 15, 2019
  • 712 Answers
Without knowing how you hooked everything up, I can’t help you figure out what went wrong. I found an owners manual. I am including the link below. https://preview.manual.guru/preview-manual-for-free-371641/not-specified-elevation-audio-dx20001/page-6.html
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
Posted on Mar 13, 2019
  • 109 Answers
Yes that is the cause sorry..i have done it before when i was younger a few times thats how i know..sorry man
Posted on Dec 05, 2008
How to wire a 6 ohm audiobahn ALUM10N subwooferto reduce ohms to a single chanel amp
unfortunately if you only have the one woofer there isn't really any safe way to do so but if you had a pair of woofers you could in theory wire them in parallel thus creating only a 3 ohm load but your amp must be able to work at such low ohms otherwise you WILL blow up your amp.
Jun 03, 2018 | AudioBahn Car Audio & Video
How do you wire 2 15 inch kicker cvx dvc 4 ohm subs to a 1700.1D hifonixs mono amp so i can get the most power
Wire both hot wires together and both ground wires together then wire them to the amp with the hot on one speaker output and the ground on the other speaker ground. This puts them in the bridged position. Pulls the maximum watts out the amp and unbelievable sound.
Feb 20, 2015 | Kicker Car Audio & Video
What's the best way to hook up my jl audio 13" w 7 sub to my jl audio 1000/1 amp
the best way? hmm. i would start off with some wire. Keep in mind that you will need to separate the positive (usually red or has a stripe or marking on it) from the negative (Black usually is the common color for this wire) and hook the up according to your amps positive and negative hook ups / terminals following your sub-woofers terminals. then depending on your sub woofers Voice coils (Duel or single voice coils) yours are duel or quad coils but i\'m sure they are duel (2 of each positive and negative equaling a total of 4 posts on each sub-woofer). figure out your amps ohm load handling and does your amp run hot (1,2 or 4 ohm stable some are even less like 0.5 or lower) i would run at a 1 or 2 ohm load as that is usually standard on 1 channel amps. make sure to check your wiring and if your not sure about ohm loads just Google wiring for sub-woofer ohm loads such as 0.5 ohm, 1 ohm, 2 ohm or 4 ohm loads. also make sure your box is not sealed do to the fact they are siht and cant produce sound like a vented / ported enclosure keep the size as big as you can fit in your car or truck the bigger the better. i had one 8\'\' sony sub pounding like a 15\'\' sub real loud . Also MDF particle board is garbage it causes port noise and absorbs water
Apr 28, 2014 | Car Audio & Video
How should i hook up a visonik class D vxd709 to my dual voice coil 12" Treo subwoofer?
if your amp is a monoblock 2 ohm stable amp wire the coils positive to positive and negative to negative into a single channel that will create a 2 ohm load turn your amp down and adjust by ear till it sounds good if your amp is a 2 channel amp 4 ohm per channel wire each coil one per channel turn amp down and adjust by ear till sounds good hope i was helpful
Feb 17, 2013 | Car Audio & Video
I have a single 15" sub woofer in a box it was
Simply put, burned voice coil. Either too much power can do this or not enough power with distortion. solution- if the sound is clear then its too much power- turn the amp down. If the sound is distorted and raspy- its not enough power and your getting distortion-get bigger amp.
Jan 07, 2013 | Car Audio & Video
I have 2 15'' CVRs and a 1200w amp
1 OHM...ONE... sheesh now thats a low resistance for anything... If they are only 500 watts and they are in parallel, series well NO.. your amp puts out wayyyy too much for those speakers.. 1200w versus 500 watts by 2... srill NOT enough "Head room" for it to be safe... about half is all you could expect before Pop.. sound is heard.
Mar 05, 2010 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
I have two dvc cvx andbrutus 1608d mono need help
Both Positives on both subs ultimately to + on amplifier
Both Negtives on both subs ultimately to - on amplifier
This will net a 1 ohm mono load for your amplifier.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 20, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
I wonder if i get two kicker cvx 10 can be push by jl audio 500.1
It can but it'd be a waste for your subs. 1 of those by itself will handle that amp. it'll push them just not really hard, i'd recommend an upgrade to a 1100-1200 watt rms amp if you're gonna run 2 cvx's. if you only run one sub that amp'll work well...
Oct 08, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Amps on woofers are fine just won't hit
your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Aug 29, 2009 | Pioneer GM-7200M Car Audio Amplifier
I cant sem to wire it to 4 ohms because the terminals are right next to each other and i have no clue which 1 is which voice coil?
test with a digital multimeter set to ohms. if you don't have one of those laying around grab a 9 volt battery and run wires from the 2 terminals on the battery to 2 of the terminals on the woofer. if the woofer pops out you are said to be "in phase" (even though it has more to do with polarity that phasing but regardless) which means the positive from the battery is on the positive of the woofer and the negative is to the negative. those 2 terminals on the woofer are a single coil and obviously the other 2 terminals are the 2nd coil. now depending on what impedance each coil is will determine how you have to wire it to be 4 ohms unless they are 4 ohm coils which means you just use one coil and it will be 4 ohms on that woofer.
Aug 18, 2009 | AudioBahn AW1205N Car Subwoofer
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
