Question about Samsung PCJ522R 52" Rear Projection Television
Dim picture on samsung model pcj522r
Dim picture
  • 29 Answers
SOURCE: dim picture
The fluid in the picture tubes is probably bad, a common problem with Magnavox. Not something you want to attempt yourself. Call a service shop.
Posted on Sep 06, 2007
SOURCE: 2 new bulbs, still dim picture
It could be a dirty projection lense or the light engine is malfunctioning by a slipped lense in front of the color wheel or the light engine is dirty it self. They are not two hard to take out if the mounts have set marks on them then it is easy to put the engine the way it was.
Posted on Mar 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: Grinding Noise
sounds like the light engine there are alot of problems with the light engines and quite a few have had a grinding noise. The only other possibility would be the color wheel. But I would lean heavier toward the light engine being the fault.
Posted on Apr 09, 2008
  • 1619 Answers
SOURCE: My Samsung DLP rear-projection TV has had a very
How long ago was lamp replaced, also you can try cleaning dust off the lamp. Dust builds up on it and causes pre mature failure. Also moving the TV around can cause the bulb to fail after extended use. The bulb are only as good as any other regular bulb. They start taking longer to warm up then dont get as bright then fail totally. Some Tv's wont allow itself to turn on in some of those states.
Posted on Aug 18, 2009
  • 1121 Answers
SOURCE: mitsubishi tv very dim picture, new lamp already
need to replace the inverter board also
Posted on Feb 18, 2010
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
Apr 04, 2016 | Samsung UN46EH5300 - 46" LED-backlit LCD...
Samsung 20'' use ic LA76941 very dim picture
replace LA76941 with memory or look to grid voltase
Apr 15, 2013 | Samsung Ultra SlimFit 20" Digital TV
Where is the service menu for the bulb in the Samsung HL-S5087W DLP
if picture dim it is most likely the lamp and resetting the lamp timer will not help that.
Oct 14, 2012 | Samsung HL-S5087W DLP TV
Samung LN-T4061F - Dim Picture
Does it look like a dim black swirling cloud with very faint images?
Mar 24, 2012 | Samsung LN-T4061F 40 in. LCD HDTV
I'd like to brighten up the picture kinda dim samsung hl-s5686w what can i do?
Turn up contrast to 95 and turn down brightness accordingly. If it is oddly dim, you may have a problem with the backlight.
Jan 28, 2011 | Samsung HL-S5686W 56" HDTV
Samsung rear Projetion Tv Model No. PCJ522R
I Have A
Samsung rear Projetion Tv Model No. PCJ522R i was cleaninthe inside when i spilled oil on half of the board power supply,when the tv is connected power button is light up but wont turn on,what can i do?
Mar 18, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung PCJ522R 52" Rear Projection Television Logo
42 people viewed this question
Henry  Thomas
Henry Thomas
