Question about Nokia 2100 HANDSFREE BOOM MIC Headset
Water rushed into my mobile set
My mobile phone was washed in washing machine with my jeans so water went into my mobile phone, what are the ways through which i can repair my mobile is there any way how can it be repaired will it be repaired ??
Very simple... Great Great Chartered Engineer from delhi rkcec5@rediffmail.com suggests that 1) Remove battery immediately after handset gets water 2) remove all cards 3) put it in Dry Rice container after tying it in a netted fabric so that rice don't enter inside it. Even Nokia will hate to get the solution. Or put Molecular sieves all round- as rice and molecular sieves just absorb moisture. You may have to keep the phone for at least 4-7 days. Have patience. Don't ever try to put batteries meanwhile before completion of at least 4 days. Better 7 days. Send thanks at rkcec5@rediffmail.com
Posted on Jul 29, 2007
I bought a new Maytag washer and I can't figure out what cycle to use for blue jeans. When I put it on normal and had a full load it. The water didn't even cover the blue jeans. What am I doing wrong.
read your operators manual
the machine is not designed to put all of your clothes in at once to start with and second the water level for a full load is high not normal
the normal refers to a normal mix of clothes and not water level
special wash is for delicates ( undies , silk etc ) or heavy wash is for heavy soiled clothes --coveralls , jeans , heavy jackets
Sep 22, 2018 | Maytag Washing Machines
What is the best settings to wash jeans on.
While hand washing and line drying is safest, it's also costly in terms of time and effort. Unless your jeans are particularly dirty, it's best to wash them in cold water, select one of the gentler cycles, and dry them at a low temperature. Special detergents formulated to preserve dark colors really do work.
What temperature do you wash jeans? When to Use Warm Water - For man-made fibers, knits and jeans, use warm water (90°F). Most of your clothes can be washed in warm water. It offers good cleaning without significant fading or shrinking. When to Use Cold Water - For dark, bright colors that bleed or delicate fabrics, use cold water (80°F).
Wash your jeans in the sink or a tub.
  1. Fill a tub with a few inches of cold or lukewarm water. Mix in a gentle, color preserving detergent.
  2. Turn the jeans inside out, then lay flat in the tub. Don't bunch them or wrinkle them. Let them soak for about 45 minutes.
  3. Run them under the water to rinse. Hang up to dry.
  4. Can you put jeans in a tumble dryer?
    According to Good Housekeeping "All fabrics and especially jeans benefit when youtake them out of the dryer slightly damp. ... If, even after tumbling on low heat and a delicate cycle, you see lots of lint on the dryer's filter, you may want to switch to linedrying your jeans to help preserve the fabric.
    hope this helps you out.
Oct 28, 2017 | Washing Machines
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
Water logged mobile repair
you will never get it to work again, sorry, a chemical reaction happens imeadiately upon water contact, this causes catastrophic damage and is not recoverable.
Mar 22, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Hi, Sadly I forgot to take my nikia N95 8GB
The only way to do this.
undo the battery compartment remove the battery, clean battery off .Remove sim and dry.
Now take these pieces to a warm room and leave for 24hrs .Then try to work it.
Hope i`ve been of help, but 2 of mine were consumed by the washing machine ,with no luck
Nov 26, 2009 | Cell Phones
My washing machine does not clean properly.
Let's start with the detergent and the water temperature. If they are the same as what you use at home,
then I have to assume the machine may be overloaded. Back off on the load by about 1/3 and see what happens. In the worst case scenario, you could let the jeans soak in the detergent/water mix over-night
Jun 17, 2009 | Daewoo DW500M Top Load Washer
Front load frigidaire washing machine
it is the rear bearing has went bad which is molded in the rear half of the tub which has a long warenty on the part only you usely half to pay the labor additional parts needed to repair after tear down
Mar 03, 2008 | Frigidaire GSTF1670A Front Load Washer
Water damage
it is best that you have the phone service....take it to a professional mobile repair shop...also do note that when a phone has water damaged......it may or may not work after being water log.
So let's hope it work
Jan 01, 2008 | Samsung SYNC SGH-A707 Cellular Phone
LINT STICKS TO MY CLOTHES IN WASHER
linting is caused by a few things
firstly what sort of soap poweder do you use
i recomend good quality powder
do not wash clothes too long as what you are doing is rubbing all the fibres out of them
good quality washing powder only last about 6 minets in water and after that it looses its qualiteseg
the PH changes in the water
you may be using too little soap powder and this also depends on water quality eg too hard or soft water
is the water levels set corectly
do not mix washing
eg towels with jeans as the lint will come off onto jeans
try using delicate wash on different fabric as the adgitation is different on different cycles
try using warm wash and not cold machine is probable ok but wah times are important
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Help! My phone went through the washing machine
Hope? almost none. But try the instructions on the following thread- http://www.fixya.com/problems-solutions/t102703,p401560/Nokia-6230.aspx Good luck!
May 03, 2006 | Sanyo RL-4920
Radio Communications Logo
114 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Damen Wong
Damen Wong
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
