Conection of headphones
When i connect headphones to the compac laptop c785tu its spekers remains ON how to disconnect the speakers while using headphones
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Go to control Panel >> Sounds and Audio Device >> In volume TAB >> Speaker Settings >> Advanced.. >> Speaker Setup >> select “No speakers”then under the Audio TAB >> select “Use only default devices”
Posted on Dec 05, 2008
Connecting earphones to the tv
Use the headphone connector if there is one.
Oct 25, 2016 | Televison & Video
I can not turn the tv spekers
suspect a issue with the socket where the headphones connect to the set---when inserted it should cut speaker sound off---often a loose connection.
Jul 17, 2012 | Mitsubishi Televison & Video
When conect speaker, the original tv speaker sound are off
Hello
You are connecting external speaker from your TVs headphone socket I thinks. It is quite normal that the internal speker will cut off when external a headphone is connected to the headphone socket. OK.
Jan 28, 2011 | Televison & Video
Getting sound from both inbuilt and out speakers spontaneously.
When doing this, you need to adjust your settings in the control panel for the audio. Usually it's defaulted to block sound when you plug in headphones. Make sure you are plugging them into the correct audio output, but it shouldn't play sound from both the headphones as well as the built in speakers.
Aug 21, 2009 | Compaq Notebook 100 Notebook
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
C785TU problem related to sound
When you plug the headphones in what happens is that inside of the jack the internal speakers  are disconnected and the sound goes to the headphones. If both are playing either the jack is not inserted far enough or  female plug is loose or defective.  Replace or repair the female plug.
Dec 18, 2008 | Compaq Presario Notebook
No sound from speakers
Check your sound settings and recording settings once and check if compac has given any sound softwares and modify the settings in that by the way you can get i think..
Thanks
Mohan
Oct 29, 2008 | HP Compaq Presario V2000 Notebook
Drivers for Wi-Fi (drivers for Ethernet Controller and Modem Device on high definition audio bus)
You can try Vista driver for this
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3739733
Sep 26, 2008 | Compaq Presario Notebook
Connection to Laptop
Since the majority of laptops do not have multiple sound outputs you will need to buy a couple of headphone splitters. Plug the first Y splitter into the laptop headphone port and plug one of the input cables going to the speakers in one arm of the Y. Next, plug another Y splitter in the remaining arm of the first Y. This will provide you with the other two inputs that you need. Plug the remaining speaker cables into the other Y arms. From there it is simply controlling the speakers using the laptop volume and/or the speakers volume. You will not have fader control on a 3.1 or 5.1 speaker system but it will give you what you are looking for. I have this same configuration at my office using an IBM laptop and a 5.1 surround sound system. Good luck. JC
Jul 29, 2006 | Compaq PS330 Computer Speakers
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
