Question about Maytag Atlantis MAV6451 Top Load Washer
Fills with water, agitates, won't drain
Maytag model LA5910 (about 12 years old) had burnt rubber smell. Is this the belt and maybe the pump. The motor seems to work fine.
where do I get a service manual or diagram?
  • Anonymous Dec 07, 2008
    thanks for the lead to the diagrams
  • 750 Answers
How to replace the Maytag belt at this location
Diagrams and belt orders here
Posted on Dec 05, 2008
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Apr 20, 2011 | Maytag Washing Machines
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
My washer has completely stopped still hums and water goes in but will not drain or agitate. the last few loads made the machine smell like burning rubber. its at least 10 years old and has...
It is not uncommon for the water pump to lock up causing the belt to burn and even melt the drive motor pulley. Tip the machine back and check the pump. It should be easy to turn. The bearing will lock slap up on these type pumps with nary a water leak. To replace the pump you need a 3/8th nutdriver and a pair of channel lock pliers. You remove 2 hoses and 3 bolts.
Jul 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Will not agitate
Bad pump Pump bearing locked up something up in pump brazzierre underwire shoulder suppet thing IN pump. Check pump
Feb 13, 2009 | Kenmore 63942 Dryer
Water not draining
check if anything is blocking the way of the drain pump ...else the drain impellor would have broken...
Dec 05, 2008 | Washing Machines
Washer stopped filled with water, smells like burnt plastic
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE Washer smells like burnt rubber
Hi, timhowarth1
ngafm at your service,
Because it wouldn't agitate or spin at all the belt burned as it tried to spin!
A problem with th coupler or transmission.
You need an experienced and hands on laundry tech or you may make matters worse or spend money replacing parts unnecessarily.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
Thank You
Sep 09, 2008 | Washing Machines
Washer filled with water-then wouldnt agitate and smells like something burning
All Maytags (greater than 2 yrs old) have belts that are prone to wear and slippage. (thus the odor) In all but one model is the belt is visible and replaceable beneath the machine. Simply lift and tip the machine back to gain access. In one model, the front panel will have to be removed in order to replace the belt. This is a good place to start, inexpensive and simple to replace..
Other causes for belts burning are:
1. Failed transmission
2. Failed water pump or debris stuck in water pump....
If I can be of any further assistance, let me know
reg501 the Fixya Team
Jun 18, 2008 | Maytag Washing Machines
Burnt rubber smell
the belt is broken. the machine wont spin or agitate with a broken belt. set the timer to spin and the water should still drain. but not spin. belts are very cheap but replacing on could be tricky if you dont know what your doing
Jan 24, 2007 | Maytag Performa PAV2200
Maytag Atlantis MAV6451 Top Load Washer Logo
994 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
