Question about Microwave Ovens
Kitchenaid microwave oven
When any button on keypad is pressed, work "lock" comes on, goes off immediaqtely and no function works.
  • Microwave Ovens Master
  • 9,098 Answers
Either the child lock is activated or the unit needs a reset by unplugging it.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download Kitchenaid owner's manuals and installation instructions here to find out how to turn off the child lock.
Posted on Dec 07, 2008
How to reset clock the clock on my KitchenAid Microwave Convection Oven
Usually push click button than set time and push click button again (some will have you push the "start" button)
Feb 03, 2015 | KitchenAid KHMS155LSS 1000 Watts Microwave...
HOW CAN I UNLOCK MY MICROWAVE? IT IS ASKING ME FOR A CODE
Press and hold unlock button for about 3 seconds. Look carefully on keypad, one of the touch buttons also says lock or something similar along with its normal function.
Nov 22, 2014 | Hamilton Beach Hb-P90d23al-Dj Microwave...
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
The microwave is blocked and you press the buttons and it wont work and it says -se-
The microwave oven is showing a systems error, which means there is a short keypad membrane. The solution is to change the keypad to get it functioning.
Mar 16, 2011 | Maytag MMV1163DB Microwave Oven
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Jan 26, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Why does my microwave display a lock? I am unable to perform any other functions. It is plugged in properly and no circuit breakers have been tripped.
your keypad has a control lock, usually you press 1 or 2 buttons for a few seconds and it will lock your control, check your keypad for a small picture of a lock and hold that button until the icon on your display goes away or just read your owners manual or download one from the manufacters website
Aug 24, 2010 | Kenmore Microwave Ovens
Kitchenaid microwave model KBMC140HSS03 will not start, sounds 3 tones when any key is pressed. If circuit breaker is turned off and back on it works for awhile, but goes back to 3 tones, sometimes whil...
Your membrane keypad is shorting.
It comes as an assembly, so it's pretty easy to replace yourself. It is part number 4453420 and you can get it here for $235.33 plus shipping.
You can also find helpful exploded views at that link.
The picture below shows you how to unlock a typical membrane keypad connector.
Jan 09, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave is beeping, lock comes on, F2, just keeps beeping by itself
F2 on a KitchenAid mike usually means a Keypad short. Beware if it is a KHMS155LSS, it can self start on its own with a KeyPad short. A real stunning defect.
Sep 08, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KEYPAD STICKING AND STOPS WORKING
Obtain a replacment keypad and replace it. The non serviceable contacts inside of the key pad or going bad.
Dec 31, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave/Convection Oven has mind of its own: turns to Crisp mode on its own.
Yes this is a touchpad issue. As you have noted the crisp button is stuck and this is the cause of this. You can try removing the keypad and push up the pressed button. If its jammed then replacing it is the only way.
Sep 02, 2008 | KitchenAid KBHC109J Convection/Microwave...
Microwave Ovens Logo
125 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
