Question about HP Computers & Internet
M8357c with composite video in
I have a m8357c and I want to make use of my "composite video in."
Right now I have video streaming into the connection. I confirmed this
by plugging that into another monitor and watching the video.
I have looked at the nVidia Control Panel as well as Windows Media
Center setting and I can not find a place that will let me see the
video being pipped into "composite video in."
HOW CAN I WATCH THE ANALOGUE VIDEO BEING RECEIVED
THROUGH "COMPOSITE VIDEO IN"?
Thank you...
5 Suggested Answers
  • 2427 Answers
SOURCE: Composite Media
Well it can be one of two problems,,
Check your settings for the device, especially your input settings and see if composite is elected or disable. Look on the net for compatable recording software for the composite input as well..
Or
it could be a hardware issue and the device is defective..
Posted on Jan 14, 2008
SOURCE: Diamond One-touch video capture audio doesn't work with s-video
i had the same problem.  it turns out the s-video does not carry audio so you have to hook up a separate audio line.  On my camera there is a mini plug a/v jack...so i run a mini plug out to a rca jack splitter and then run rca cords to the red and white jacks on the one touch....then it works great.
Posted on Jan 05, 2009
  • 400 Answers
SOURCE: I can't get composite video capture to work.
No, just check if there wire are plugged into your computer mother board properly and according to the manual...
Posted on Jul 07, 2009
bhagyavichar
  • 414 Answers
SOURCE: Adobe flashplayer makes buffering downstreaming videos on mediapl
buffering is a normal process..
it depends upon the size/content or connection speed..
In computing, a buffer is a region of memory used to temporarily hold data while it is being moved from one place to another. Typically, the data is stored in a buffer as it is retrieved from an input device (such as a keyboard) or just before it is sent to an output device (such as a printer). However, a buffer may be used when moving data between processes within a computer. This is comparable to buffers in telecommunication. Buffers can be implemented in either hardware or software, but the vast majority of buffers are implemented in software. Buffers are typically used when there is a difference between the rate at which data is received and the rate at which it can be processed, or in the case that these rates are variable
for professional assistance contact ur system admin/vendor....
Posted on Nov 18, 2009
  • 73 Answers
SOURCE: Composite Video input doesnâ??t work, no
try to install the driver
Posted on Oct 30, 2010
I have a gateway 509GE desk top, with no "video out" source on desk top. it has 915g express chipset graphics card.. i alsp have an old SIS 6362 Rev C5 Graphics Card from on old Micron Elect Inc....
If these things are true:
The composite connector on the card is for input.
The computer has a compatible card slot for the graphics card.
The TV has a composite connector for output.
There is a driver for the card that is compatible with your OS.
You have video capture software.
If not, purchase a video capture device/card. I recommend NewEgg.com
I hope this helps.
Jun 16, 2011 | Computers & Internet
Composite connection on Gateway Desktop
They are Video and Audio for connecting device together
  • Yellow = Video
  • White = Audio - left channel
  • Red = Audio - right channel
the connectors on a Desktop PC from the graphics card will be an OUTPUT-possibly labelled TV output, so what ever is displayed on your monitor can also be sent to a TV or recorder etc The connectors on the Xbox are also OUTPUT and designed for connection to a device which has the same connection but for INPUT
Your monitor may have composite inputs and allow you to switch to those Some TVs will have those connections as inputs and you would select one of the AV options to see the signal, often a separate button to choose AV input /HDMI / PC etc Some DVD and Video also have these as an INPUT as video cameras often have that type of connection - to record the signal
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Gateway GT5453E Refurbished AMD Desktop...
I cannot get front composite video jacks to work. I want to capture video from VCR using Pinnacle.
You don't need ATI capture anything. Pinnacle Studio does that. Make sure your composite input is not disabled on your PC. Make sure Pinnacle is setup to capture from that card/device. Make sure your video device is outputting to the composite.
Jul 05, 2009 | Gateway Computers & Internet
How to transmit video from one computer to many ones?
Hi hungvtst,
Depending on what kind of video you would like to "stream" (or transmit) there is a program called VLC Media Player you may download it for free. It will allow you to stream videos to many computers at once. Here's the guide on how to use VLC to start a Streaming Server.
That should put you in the right direction.
Regards,
-SHG
Jan 13, 2009 | Computers & Internet
HI.I was watchinglive streaming but there is a eror sudenly.this eror:rtsp://78.129.143.64/broadcast/pull/81.31.32.47:2030/broadcast/pull/81.19.7.50:3051/stv3.rmvb Can you help me...
Streaming audio/video quality can be affected by connection rate and Internet congestion. Many types of interruptions between your computer, your player, your computer's OS, your local network, your ISP and a streaming server can exist and cause trouble....
When you listen to the live audio/video stream, the sound or video skips, cuts out or buffers if the player doesn't have enough network bandwidth, it will buffer. Try increasing your player's buffering setting.Also:
  • Make sure you are choosing the appropriate bandwidth version of a media stream based on your Internet connection.
  • Make sure you are choosing the appropriate bandwidth settings in an Internet media player or streaming audio/video recorder.
  • Make sure NOT to download applications or files while watching/listening to media streams. Your Internet connection is shared between all open applications including your web-browser, your download manager and your streaming player. Closing applications that use your Internet connection simultaneously with your streaming player may reduce buffering.
  • Close other unnecessary applications that may be open on your computer. Reboot your computer. If you have lots of other programs open, they may be using too much processor time and/or RAM for the player to work properly.
  • Make sure your Internet connection is fast enough to reliably listen to streaming audio and/or watch streaming video online. High speed Internet connection is recommended.
  • Make sure your computer is fast enough. If your computer is old, it might be too slow to play an audio/video stream regardless of what else it's doing.
  • Update your media players and streaming audio/video recorders regularly.
Internet congestion can slow down the delivery of the stream, make it difficult for you to connect or cause buffering. Often the interruption is temporary. Please try to connect a few times at different times of the day, if possible. If you repeatedly have problems connecting, please notify your ISP - there are often quick fixes they can make when they learn about your issue.
Try the above steps you will find a solution to your problem....100% it will work.....
Sep 18, 2008 | Computers & Internet
I INSTALLED MY ATI RAEDEON 128PCI VIDEO CARD AND IT HAS S VIDEO OUT AND COMES WITH THE SVIDEO TO RCA CABLE BUT I CANT GET THE IMAGE TO DISPLAY ON TV
The S-video to Composit adaptor tells me that you wish to connect to the Composit input of the TV
Connect the TV , set the TV to ( Composit input ) Composit 1 , or Composit 2 , NOT A CHANNEL
restart the computer , this will help the video card and software to detect that the TV is now on and connected.
When you come back to windows you should be prompted to perform the television setup wizard
if not
go to your display properties
Advanced tab
and manualy configure the video card for television output.
Selah.
Sep 15, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
