Question about Tower Ceramic 1500 Heater
Heater My heater has been in use for about a year and is shutting off by itself after running for a short while, all the way off like there is a reset tripping or something but I see no reset button on it.
0 characters
1 Points
I have model NO cz798 , it keeps runing this morning it was 82 O" F
my space heater power light come on but the fan has stop moving.i
brought this heater less than 30 days ago
Nov 12, 2012 | Comfort Zone CZ792 Electric Utility Heater
My Dimplex model #6901470100 (purchased new in 2007) just stopped working. It was on then just turned off by itself. Both lightbulbs are OK. What would cause this?
It probably overheated and the overheat module shut the heater down. It may reset itself once it cools down. Or the heating element has burned out. There are a host of issues with these electric fireplaces (not just Dimplex). They are sold as a decorative, supplemental heat source, but in fact, if you get more than a years use out of it without a problem, you're probably the exception. The heaters just aren't meant to run for a long period of time. It's like turning on a blow drier and letting it run for an hour. Nine times out of ten the blower driver will overheat and burn out.
I really wish I had better news for you (I answer this type of question at least 5 to 6 times a week), but I don't.
The only good news would be, if it's still under warranty (one year), have your Proof of Purchase and contact Dimplex USA. Technical Service: 1- 888-346-7539. Customer Service: 800-668-6663
Feb 23, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Runs for short period and then shuts off and has to be reset
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
Feb 13, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I have a OM-22 and the high limit switch shorted out. Do you know where i can get one? And I have no lights on the control panel, is this normal or is there more damage?
When your heater overheats the high limit should open (ie. infinite resistance). This shuts down the heater and gives an EE12 code. When the heater cools, the limit should reset itself (no resistance). Then if you haven't already turned the heater off, turn it off and then turn it back on and it should go. If the high limit doesn't reset, you can google Toyostove dealers and they should be able to get you one. I have also sent you an email. You should also make sure the fan cage is clear and that nothing else is blocking the air flow.
Oct 08, 2010 | Heaters
I have a dyno glo rmc-fa100dlx forced air heater. It will light and work for a few minutes, up to about 5, then it will stop heating and the fan will keep blowing. any ideas? thanks!
If the unit comes on and runs but then shuts down, that sounds like an indication of a high limit trip.
Most, if not all, furnaces have high limit switches that keep a constant check on the temp inside the furnace or air handler. On most systems, once this high limit switch has been made (got to hot), the limit switch breaks control voltage to the heating device (strips, gas, fuel, etc.etc..). The blower motor continues to run until the high limit has dropped in temp and reset itself.
On some models, the high limit is a manual reset, meaning you need to reset the switch yourself or shut the unit off and then back on to reset it.
Check all filters and replace as necessary. Check the coils and fan blades for dirt build-up and cleanliness. Check motor belt (if applicable). If all these fail to solve the problem, then your issue either lies within the blower motor itself not moving enough air for proper heat transfer. Or the high limit switch itself is failing.
Jan 09, 2010 | Heaters
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton 3E227A Heating Cycle
The sensor for the thermostat is probably going bad or has bad connections. It is (or thinks it is) heating up fast and therefore shuts of the heater.
Dec 30, 2007 | Dayton (3E386) Heater
Unit shuts itself off within a few minutes.
. Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
The heater should function properly once the dust is blown off the sensor.
Mar 06, 2007 | Lasko 5365 Ceramic Compact Heater
Tower Ceramic 1500 Heater Logo
16 people viewed this question
Top Tower Heaters Experts
Dan Webster
Dan Webster
Are you a Tower Heater Expert? Answer questions, earn points and help others
