Question about Pantech Duo Smartphone
Screen MY screen is really scratched up with a few major scratches. Where can i get a new screen to replace the scratched one
    Problem Solver:
  • 8 Answers
Dont know about replacement but someone I know had a bottle of CD scratch remover and tried it one day, it worked wonders. They also confirmed that McGuiers plastic polish does an amazing job. Take your time, apply multiple times, and use a lint free sunglass wipe to apply and buff with.
Posted on Dec 16, 2008
How to remove deep scratches from tv screen
if it's really deep, then you need to replace the screen. if it's not as much, then get your tv makers scatch remover!
Aug 03, 2012 | Televison & Video
N70 body clear plastic (flips up and down) has major scratch. Doesn't affect photo, but makes composition difficult when looking through the eyepiece.
Is the focusing screen scratched, or is it the mirror? You can buy a replacement focusing screen for about $25 on eBay. Removing and installing the screen is an easy task that you can do without any tools.
Feb 14, 2011 | Nikon N70 35mm SLR Camera
My old ds has major scratches because my friend used a pencil on it once now the touch screen barely works
Wuts the DS got to do with mother boards?
Oki, you could replace that scratched TOUCH SCREEN only!
No needf to buy the LCD itself!
An expert on DS techman must do the job!
Nov 06, 2010 | Computers & Internet
My touchscreen on my new sony tx7 camera got scratched in my handbag, and the indent is interfering with anything i try to do...is there anything i can do? is it possible to replace the screen?
I'm sorry to hear that the new DSC-TX7 Camera screen got scratched. You can get the screen replaced with the help of a service technician. Changing the LCD screen of the Camera is bit expensive. Contact the Service Technician to check if the screen requires a replacement or the entire LCD screen. I suggest you to use a screen protector (scratch guard) which is available with the SonyStore. This will help you in avaoiding scratches on the screen.
Oct 23, 2010 | Cameras
Scratched computor screen
How deep of a scratch is it on the screen? Just on the plastic/glass protective coating over the monitor?
If it is not in the LCD then you could just remove the plastic/glass and replace it if you want.
If the scratch is deep then your LCD is probably scratched. Sadly the cost of replacing the LCD screen within an LCD monitor is more expensive than buying an entirely new screen. Your best bet is either dealing with the scratch or getting an entirely new monitor. I would recommend visiting www.newegg.com where there are many cheap monitors there.
please rate my solution
Jul 20, 2010 | Acer AL2016W 20" LCD Monitor
My DS lite has really bad scratches on the touch screen. I bought a new touch screen off ebay, but when i went to replace it, I found that all I needed was a little panel that sits on top of the tough...
yeah they should come with screen protectors.. =( I scratched mine to hell before i realized what a screen protector was, and ended up trading it in at gamestop and buying a new one. I know it's not an answer to what you're looking for, but that's what i did.. =(
Dec 02, 2009 | Nintendo DS Lite Console
My Mitsubishi WD65731 65" 1080p DLP HDTV has scratches.
ive never seen a tv with a plastic cover on the screen (unless it just got unpacked) even if its just the screen rubbing polish into it wont hurt it! unless it has a hole in it down the the liquid crystal it could get in there and cause major problems but if that part is still working fine then buff away! the liquid crystal in all LCD's is between the two glass plates..then theres a thicker glass over the top.
hope this helps,ben
Aug 13, 2009 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Small scratches on tv screen, can I fix it?
The only way to completely get rid of the scratches is to replace the screen. If you want to get a new replacement protective screen for this model, here is a link from a major parts distributor:
RCA P61927 Replacement Part Protective Screen / Super Shield
Jan 15, 2009 | RCA P61927 61" Rear Projection Television
My screen on my lg kg800 is scratched how can i replace it with a new one
is the actual screen inside scratched or is the outer phone housing screen cover scratched? There is a difference. The actual LCD screen is inside the phone housing and is protected by the phones housing. If the actual LCD screen somehow was scratched it can be replaced very easily and usually inexpensively. Try Ebay for the LCD. If the phones outer clear housing is scratched you can also replace the housing either by purchasing the same phone used and using its housing or some "dummy" phones can be used for there housings also. If the scratch is not really bad I have used rubbing compound to remove fine scratches, good luck!
Sep 03, 2008 | Cell Phones
Polaroid FLM-2601 flat screen
It has a protective outer screen and depending on the depth of the scratch you might be able to restore it. You'll need to look on-line at a few aircraft site for a kit that is meant to polish scratches from the plexi in an aircraft windshield. There is a company in Oregon http://www.chiefaircraft.com/airsec/Aircraft/Windshields/ScratchRemoval.html
that sells the kit for 34.95....
It is time consuming but I have restored many this way!
Bill
Mar 27, 2008 | Polaroid FLM-2601 Television
Pantech Duo Smartphone Logo
133 people viewed this question
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
