I have a peavey crossover model cex-4l. It's a digital crossover. When it powers up it reads" host dsp comm error. Then when I turn the data wheel it reads "num of errors 060708 data lines 090a0b. I replaced the memory battery already. I don't know what else to do from here.
  • 4234 Answers
SOURCE: Blown crossover in a Peavey
Yes it can be repaired. Your best bet is to locate an authorized Peavey service center and order the crossover from there. Most will sell the replacement crossover directly. The cost of the individual parts will not be significantly less than the entire module. Are you sure that it is the crossover that is smoked? It is unusual for the crossovers to go bad. What is the symtom of the speaker failure?
Dan
Posted on Aug 18, 2008
keshy
  • 77 Answers
SOURCE: ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Posted on Oct 10, 2008
  • 979 Answers
SOURCE: how do i link two
Please tell us what you're trying to do..
Posted on Nov 22, 2008
SOURCE: hp laserjet m2727nf mfp -
Check if you have the latest firmware for this multifunctional on www.hp.com, installing newer firmware fixed communication problem for us.
Posted on Jan 30, 2009
  • 51 Answers
SOURCE: Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
Posted on May 20, 2009
Peavey instructions
I would put the crossover just before the amp(s). The kosmos v2 just after the signal source. Always turn the levels down before powering it up.
Aug 10, 2014 | Peavey Kosmos V2 Generator-processor...
How can i reset my password in my new dsp 7500 ipr 2 peavey amp
I think you should search for a reset button, beware you loose probably all settings
May 27, 2014 | Peavey IPR 7500 DSP 7500 Watts D-Class...
How can i download software for my laptop that doesnt have the same cable plug in as the processor?
you need a usb to serial port adapter...cex 5 was a 2 by 4 digital crossover with some simple eq and processing, all the features were accessible from the front panel, I do not remember a GUI being available for this unit for control.
Apr 30, 2014 | Peavey Processor Sound Reiforcement cex 5
Peavey IPR 1600 amplifier will not turn on
are you the original owner, with a receipt? This amp has a 5 year warranty. If not take it to a shop, we can fix them, they are damn complicated for an amp...black magic inside.
Sep 30, 2013 | Peavey Ipr-dsp-1600 Power Amplifier - Used
Enter password access denied. power amp new.
Try 6505. if that does not work then Contact customer service 601-483-5365
Sep 22, 2013 | Peavey Ipr-dsp-1600 Power Amplifier - Used
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Error - 8403 on cdj 200 not reed the cd
Can't find Error 8403 in the service manual. Please advise the correct error code and I'll see what I can find out for you.
E-7201 TOC READ ERROR 26: TOC data could not be read.
E-6002 DSP PROGRAM
DOWNLOAD ERROR
62: The program cannot be written in the DSP.
E-8301
PLAYER ERROR
(Startup error)
12: The desired address could not be searched.
15: Address data could not be read.
22: The Focus Servo could not be closed.
91: The pickup could not be returned to the inner track.
E-8302 PLAYER ERROR
(Abnormality in playback)
E-8303
PLAYER ERROR
(Abnormality in writing to the buffer)
99: Abnormality in writing in the buffer
E-8304
MP3 DECODE ERROR
(Abnormality in decoding)
Abnormality in decoding ∗∗
E-8305
DATA FORMAT ERROR
(Inappropriate data format)
A data format other than MP3 was used. ∗∗
E-9101 MECHANICAL TIME OUT 90: Abnormality in the disc-loading mechanism (TIMEOUT)
Feb 24, 2009 | Pioneer CDJ-1000 CD Player
I have a peavey pro-fex 2 preamp/FX ver 1.3 controller and when powereing up, get DSP interface error. Do you know what this means or how to fix it?
Your Profex likely has a dead NiCD battery. You are getting this error because this battery maintains your personal effect settings on an SRAM chip that requires constant power to "live". You can try reinitializing the SRAM on your unit by doing the following:
1. Power off your Profex.
2. Press and Hold the "PLAY" and "GLOBAL" buttons while powering the unit on.
3. You should see a message on the display that reads "MEMORY INITIALIZED". Afterwards the Profex should act normal.
4. If your internal battery is getting low or is already dead, it is going to start leaking (if it hasn't already). YOU NEED TO GET THAT BATTERY CHANGED NOW!!!!! If enough battery acid leaks onto the circuit board, it will ruin your Profex forever.
Aug 03, 2008 | Audio Players & Recorders
Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
Feb 13, 2008 | Peavey CROSSOVER, STEREO 2-WAY/MONO 3-WAY,...
54 people viewed this question
 Grubhead
Grubhead
