Question about Toshiba Satellite M35-S320 Notebook
Power up I have a Satellite m35-s320 laptop; it will not start. I have it plugged in to the power and the battery is out; the blue light is on to indicate it is connected to the power source, but when I push the start button nothing happens...any ideas?
    Novelist:
  • 198 Answers
This is probably a power circuit failure (inside the laptop) It will need, in this case, to replace some components on the mainboard. Or the laptop can't send the "power on" signal properly to the charge circuitry due to a short circuit/open circuit in the way of this connector. Either of those are pretty bad things, they need to be solved by a service center. Sorry for I can't assist you in a more usefull way.
Posted on Feb 16, 2007
Cant find jumer that clear bios on my tohiba m35-s320 laptop
I think the only way is to remove the internal batt wait 10 seconds and insert it again
May 04, 2012 | Toshiba Satellite M35-S320 Notebook
How to generate Response Code for challenge code for bios on m35-s320
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen user Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
Apr 23, 2012 | Toshiba Satellite M35-S320 Notebook
How do i bypass the bios password on a toshiba satelite m35-s320
your password is toshiba.. enter that and then you may change it to your desired one..
Aug 21, 2010 | Toshiba Satellite M35-S320 Notebook
Im trying to find how to rebot my laptop back to factory its a toshiba satellite m35-s320
Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
  • 2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
  • 3) When the machine Starts beeping; release the 0 key.
  • 4) When prompted by the warning screen; select Yes to continue with the system recovery.
  • 5) Select Recovery of Factory Default Software; click Next.
  • 6) Select Recover to out-of-box state. Click Next again.
  • 7) Click Next to Start recovery.
May 18, 2010 | Toshiba Satellite M35-S320 Notebook
Toshiba Satellite M35-S359 powers off and occasional crashes
This solution worked for me go to laptop101.com and youwill see the solution to this problem there was a recall on the m35 and there is a electic discharge from the speakers and the mouse pad i fixed mine with foil tape from the local big lots if you can't find the link http://www.ask.com/bar?q=laptop+repair&page=1&qsrc=178&ab=1&u=http%3A%2F%2Fwww.laptoprepair101.com%2Flaptop%2F2006%2F01%2F04%2Ftoshiba-laptop-overheating%2F
Mar 23, 2009 | Toshiba Satellite M35-S320 Notebook
Replacing M35-S359 motherboard with one from S320?
If the M35-S320 case is OK and the M35-S359 screen is OK and will fit the M35-S320 then I would swap the LCD screen lid and inverter over to the M35-S320 including the hard drive from the M35-S359.
It would be less work and with luck it might boot up, if not you might be able to do a system repair, worst case, you will need to reinstall Windows. Plus you have a spare drive from the M35-S320 which you can use as an external hard drive with an USB hard drive adapter case.
Jan 29, 2009 | Toshiba Satellite M35-S320 Notebook
Looking for Toshiba HDD for M35-S320
you can buy the HDD in your laptop at computer shop, but check first if it is SATA or IDE...under your laptop,there are 2 screws remove that and remove the HDD and check what type of HDD you have..here is the idea, with 40pin its indicate IDE with small flat connector its SATA..remove and check and go to computer shop,they will ask you also how many GB you want...80,120,160 whatsover..buy and replace the HDD.
Nov 03, 2008 | Toshiba Satellite M35-S320 Notebook
Toshiba Satellite M35-S320 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
