Question about Sewing Machines
Old kenmore machine
I need a place where I can get my machine cleaned up - I have not used it for some time. I also would like to find instructions on how to use the various stitches in my machine.
    Problem Solver:
  • 17 Answers
Just visit our website at www.janomestuff.com
Posted on Sep 24, 2009
Where do I oil Kenmore Model No 385 16221 can't find it in the manual
Page 94 of the manual:
Kenmore 385 16221 Owner Manual Table Of Contents
FWIW, it is important to keep your machine clean and oiled for it to operate properly. Use ONLY good quality sewing machine oil and apply ONLY 1-2 drops every place indicated, approximately every 40 hours of sewing time.
Dec 23, 2016 | Kenmore Sewing Machines
Kenmore sewing machine model 158-17031- motor runs well but think the clutch or something is stuck
Has it been oiled lately? If not, it could be seized. Old oil turns to glue and then varnish unless it is regularly maintained. Make sure to use only fresh, good quality sewing machine oil or liquid Tri Flow Synthetic Lube. Slowly rock the hand wheel and apply a couple drops every place where metal rubs against metal--no oil on belts, rubber, synthetic parts! If it is still resistant, direct hot air from a handheld hairdryer into the internal mechanism and repeat the process until things are loosened and moving smoothly again.
A sewing machine should be cleaned and lubed every 40 hrs of working time or every 6 months if not in use.
Oct 03, 2016 | Kenmore Sewing Machines
Kenmore sewing machine model 158.12260 Manuel
Sears carries many manuals for Kenmore. That's probably the best place to check--unfortunately, they generally are not free.
The sewing machine could probably use a good cleaning and oiling. These old (but great!) mechanicals need 1-2 drops of fresh, good quality sewing machine oil (Tri-Flow Synthetic Oil works great!) every place that metal rubs against metal. NO oil on plastic, nylon, rubber, or belts!!! Simply open the machine's top, left side, and free arm cover (if not a free arm, you'll need to access the underneath of the machine). Gently hand rotate the handwheel toward you and apply a couple drops every place metal rubs metal. Don't forget the lever & dial mechanisms too. Probably, in your case, the bobbin winder mechanism (do NOT oil the rubber tire!). Then you can apply hot air from a handheld hairdryer into the mechanism to help free it up.
Jun 23, 2016 | Kenmore Sewing Machines
Have a Kenmore 1357. Was working perfectly until I began sewing satin ruffle onto fleece. Seems to siege. Needle won't even try to go into material. Just goes to top of presser foot and stops.
Is it a mechanical machine (not computerized)? Did you oil the internal metal parts that rub against other metal parts? With an older mechanical machine, frequently the old oil turns to goo and sticks things rather than lubricates. Use only fresh good quality sewing machine oil. Hand rotate the wheel and place 2 drops of oil every place metal rubs metal (including the bobbin area). To help loosen things, direct hot air from a handheld hairdryer into the interior of the machine.
This process was used on an older Kenmore that had totally frozen, but it was working again within 15 minutes.
Dec 11, 2015 | Kenmore Sewing Machines
Kenmore sewing machine keeps squeaking how to stop it?
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
Oct 23, 2015 | Kenmore Sewing Machines
My Sears Kenmore 158.14002 won't zigzag. All the setting are correct.
Have you cleaned and oiled it recently? If it is mechanical (NOT computerized), it needs to be cleaned and oiled regularly to keep it working properly. In your case, the needle bar movement is probably stuck. Consult the owner's manual in the Maintenance section, use only good quality sewing machine oil (fresh, not old stale oil), apply 1-2 drops each place indicated in the instructions. To speed things up, you can direct hot air from a handheld hairdryer into the area.
In the future, clean and oil every time you change a bobbin, every 8 hours of constant sewing, or every 6 months if not in regular use.
Sep 19, 2015 | Kenmore Sewing Machines
I HAVE A KENMORE SEWING MACHINE 1641. I can't get the bobbin to wind. I have the manual and have followed all the instructions. Any suggestions?
When you push the empty bobbin over to engage the winding mechanism, do you hear it click into place, or maybe feel it click into place ? I am wondering if perhaps it's not quite engaged and that's why it won't wind. How old is the machine ?
Oct 02, 2014 | Kenmore Sewing Machines
Do I need a receipt to use the warranty?
you have to contact the place you bought the sewing machine at and ask them if you need your receipt for the warrenty.
Aug 22, 2013 | Kenmore Sewing Machines
Need manual: Kenmore sewing machine 158.9
Those books are long since out of print. Try contacting sewing machine stores who stock old instruction books. Many shops do this. Or try eBay.
http://shop.ebay.com/i.html?_nkw=instruction+book+kenmore+sewing&_sacat=0&_trksid=p3286.m270.l1313&_odkw=instruction+book+sears+kenmore+sewing&_osacat=0
Jan 24, 2010 | Sewing Machines
I have an old kenmore 12 stitch sewing machine that the needle sometimes looks like it wants to more and other times it just sits there. the shaft that runs across the inside under the top cover will not...
Sounds like your machine is in need of a good cleaning and oiling. If you aren't handy with taking apart things and getting them back together I suggest taking it to a sewing machine repair place. In the meantime you can try oiling any spots you can access. Use sewing machine oil, found at any sewing/fabric store and even most Wal-Marts.
Nov 23, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
