Question about Panasonic SC-HT740 System
Subwoofer not working, blown fuse?
My subwoofer stopped working after the center speaker wires shorted with my metal cable box. The sytem shut down for a moment, but powered back up almost immediately, but now the subwoofer doesnt work..it's the only speaker that doesnt work.
Did I blow a fuse and if so how and where do I check it and replace it??
thank you!!!!!!!!!
5 Suggested Answers
SOURCE: fuse blows.
Please check for shorted diode or condenser at power section.
Posted on May 29, 2006
  • 2296 Answers
SOURCE: Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Posted on Jan 16, 2008
grodenbarg
  • 9 Answers
SOURCE: subwoofer dont work at all
That sounds like defective internal wiring or a loose connection on the amplifier PCB. If you just purchased this audio system. It should still be under warranty for a defect.
Posted on Feb 07, 2009
  • 24 Answers
SOURCE: No power. I changed fuse but microwave blows it immediately.
Be very careful! Standard microwaves have 2100volt capacitors and commercial ones 4000 volt capacitors.
*Decharge your capacitor(s) before doing diagnostics*.
You are now testing the high voltage side (as it works on convection). The main components are a transformer, a capacitor, a diode and a magnetron (havent seen a triac in a panasonic residential). If you have a proper meter that can test uf, decharge the capacitor, then test the capacitor, if it reads 0, you need a new capacitor (10$ used typically, 14$ new from ebay). To test the magnetron, decharge the capacitor first, remove the spade connections, test each leg to the frame of the microwave... if it shows measurable resistance, the magnetron is bad. The transformer is not something you test as I personally dont have a 4000 volt meter. If the diode, the magnetron and capacitor are okay, then the transformer is bad. To eliminate any other function, disconnect the low voltage to the transformer run a micropower cycle and check the fuse.
Hope that helps. My first instinct is the capacitor.
Posted on Dec 19, 2009
MicrowaveSvc
  • 9030 Answers
SOURCE: Internal ceramic fuse repeatly blown.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. See: http://www.microwavedisplay.com/doorsw.txt in this case.
If this unit has an inverter some parts are difficult for the average do it yourselfer to replace, such as parts which are spot welded, not using removable connectors.
In such cases, it's best to replace the entire inverter.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on them.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
You can order Panasonic parts from
Encompass or by calling 866-779-5835.
Posted on Jan 10, 2010
No power. Fuse was blown but replaced fuse and still no power.
If fuses blown there is a case to search for short circuited active parts examples are end-transistors caused by clipping speakers cable shorts leaking or convexed capacitors but any new fuse will blowing again and again also the bridge rectifier to make dc voltage inside the power supply of the subwoofer can caused this problem
Jul 19, 2015 | Polk Audio DSW PRO 500 Subwoofer Speaker
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
I have a Alpine Power-V MRP-M1000. The issue I am having is, it will power on and work at very low sound levels anything higher is shuts down. I shut off the car and turn it on again and it works again.....
What actually is happening is your Alpine amplifier section is reaching its limits and as a result, it triggers the protection circuit for shorts.
Please check your speaker wirings and make sure it is not touching any metal part of the car body or some shorts (check the cable for exposed wires)
You may also check if the amplifier is not overloaded with speakers on each channels (left and right channels)
Please check if the capacity of the amplifer matches it's impedance (8 ohms or 4 ohms), it should match the speaker impedance.
Hope this helps.
Jul 01, 2011 | Car Audio & Video
Subwoofer pushing out problem
it sounds like one channel in your amp had shorted and letting dc go to the speaker...a speaker is an electromagnet and requires ac to make it pulse..the amp has a blown channel and would have to be repaired and a factory service center...there is no quick fix..
May 27, 2009 | Lightning Audio B1.10.4 Car Subwoofer
Hy when hooking up right rear speaker to purlpe wire coming from radio causes radio to shut down?
Pinched wire, metal touching metal, or blown speaker.
Try and move the speaker up and down. If it is hard, or you hear scratching - it is blown.
You can test for continuity to ground on the wire with a multimeter that has continuity capabilities as well to see if there is a problem.
Thank you for using FixYa - A FixYa rating is appreciated!!
Jan 23, 2009 | Car Audio & Video
I have a word titled "PROTECT" on my kdc mp333, how do I get it to function properly again? Pls reply asap.
When the stereo goes into PROTECT mode it is due to a speaker wire having a short circuit or is touching the car chassis somewhere.
Check all speaker wires from the unit to the speakers.
First check that each pair of speaker terminals at the speaker end is not touching. Or, a wire fell of 1 terminal to rest on another.
Best way to check if it's a blown speaker or a wiring short, is to disconnect all speaker connections ( at the speaker end ) making sure the disconnected wires don't touch each other or any metal in the car. press the reset on the unit and power up. If the unit powers up ok, then its a blown speaker.
Otherwise it's a short in the wiring.
If it's a blown speaker, you can connect 1 speaker at a time and the blown 1 will send the unit into protect mode again.
If it's the wiring, disconnect the unit from the wiring and use and ohm meter to check each pair of cables. A reading suggests a short.
If you don't have an ohm meter a battery and bulb will do. This method usually works on a short.
If you have no joy with either method, take each speaker wire in turn and check with a source of earth (anything metal connected directly to the body of the car, cigar lighter main body when pulled slightly out is good)
Regards
Philip
Jul 20, 2008 | Kenwood Car Audio & Video
When i turn on the cd player the sound from the components vuts off but the sound coming through the subwoofer stays on??
The Sub gets it's output from the pre-amp circuit, whereas the components get their output from the main amp circuit in the unit.
Sounds like it could be a short in the speaker wiring or a blown speaker. Check all wiring to the speakers.
Regards
Philip
Jul 20, 2008 | Car Audio & Video
Speaker Failure
search for a short to chassis when you mount the speaker,there's no problem if the magnet touch the chassis. you can test the cables with a multimeter.check if the tiny flexible cables on the speaker touch metal when is in movement. (on sound).
Sep 17, 2007 | Rockford Fosgate (P210D4) Car Subwoofer
Amp just abruptly stopped working (Pioneer GM-5300T)
Apart from the external DC power fuse (I hope you have one in-line), the majority of in-car amps have 2 mini fuses inside the unit to protect the output MOSFETs from overloading due to incorrect speaker connections, ie, if the output impedence is rated at 4ohms, anything less than that is considered to be a short circuit, and will overload the MOSFETs. After performing the tests suggested by KaeZoo, open the unit and look for printed markings on the circuit board, something like F1, F2, the fuses may not look like conventional fuses.
Jun 11, 2007 | Pioneer GM-5300T Car Audio Amplifier
Panasonic SC-HT740 System Logo
62 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
