When i start my computer the cmos restarts to 2004 and i have to press f1 to resume
  • 837 Answers
Try replacing the battery on the mohterboard
Most common is the CR2032
Posted on Dec 05, 2008
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
When computer is on cmos give error press f1 for entering cmos setting or press f2 to load default setting .so any buddy give me solution
Please press F2 then try to restart the system. if you still getting the above message on start up, please change the CMOS battery. Then save the cmos changes. it will not ask again..
Hope this works.
Jul 11, 2011 | Computers & Internet
How to restart the computer to factory settings model type 8215-95u serial number lkndy93
to resotore the computer to factory setting is done by clearing cmos to clear cmos you need to remove the cover of the computer and search for the battery in the motherboard remove the battery and also remove the power of the hard disk then start your computer then after the post you will see boot error then shutdown the computer remove the plug from the back of the computer then insert the battery and connect the hpower to hard disk and plug in back the power supply and restart your computer when restarted you will the message cmos rested pres del to enter bios and f1 to install defult option press del and change the date and time and press F10
Jul 04, 2011 | Lenovo ThinkCentre® M52 (821595U) PC...
My computer is having start up issues. When I turn it on it'll act like it's loading normally and then it'll beep twice. It'll go to a screen that will have several ERRORs on it and ask me to press either...
It may happen when CMOS Checksom error i.e error may happen due to keyboard failure. Please follow the steps to short the BIOS
> Open the Laptop back panel. Locate the CMOS battery, remove it & then with the
help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a
screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Now, restart the computer in normal mode. If still facing issues then I would suggest a full system recovery.
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Nov 28, 2010 | Acer Aspire 5100 Notebook
Cannot get into 'Setup'
when upower up press
"del"
F2
F8
F12
F10
try above
then u can able to enter in bios
Apr 09, 2009 | Computers & Internet
Problem with American Megatrend
u have to change cmos cell in motherbord.
open cpu and check on motherbord there is 1 cmos cell then set bios setup.
Mar 26, 2009 | Computers & Internet
Press F1 to resume at start up?
When you go into you setup screen,choose the setting that you want,then tell it to save the settings. If irt is loosing the setting then likely  the cmos battery is bad and needs to be replaced.
Mar 01, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Press F1 to resume
Try changing the CMOS battery (leave the battery out for 5mins then replace with new 1) if that does not work flash the BIOS
Let me know how you get on...
Matt
Dec 08, 2008 | MSI K9VGM-V Motherboard
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
1. New hardware has been recently installed.
2. Error or confliction with settings in CMOS.
3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS.
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Not starting up Compaq V2000
may be
but you try this methods
remove the cpu cover and remove the cmos battery then ,remove the hdd cable and replug ,make sure all input devices like keyboard,cd rom drive conneced properly,then run the pc,F1 appears -click F1,after os load ,turn off the computer and insert the cmos battery ,again F1 is appears u press F10 and again press F10 or save buttens ,
it is a possible solution not sure,but try it
thanks
Feb 28, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
