Question about RCA F31317 31" TV
No blue color on screen
RCA mod# F31317 (svc# F31317-YX53), Chassis# CTC203CA6 Unit is approx 6 years old (per prod. date). Lost blue in picture. Picture has a sepia-like appearance. Reds are still good and green is there also. No noises occurred and there was no indication of a failure prior to the loss of blue in picture. Found service mode label inside case. Checked the blue control parameters. No adjustment can be made to the blue switches that have any effect on picture color quality. The red and green can be adjusted. The first 3 parameters are codes and each one shows code 24. I cannot find any info to define these codes. Checked the circuit board attached to the rear of the tube for cracked solder joints. No cracks visible but I touched a solder iron to each to attempt a possible fix to no effect. Checked all plug-in connections for tightness and cleanliness, NPF. I have not removed the main board to check for solder joint integrity. There are no visible damages or failures on the main board. There are 2 resistors on the tube board that have heat discoloring (blackening) around the solder joints on the board but the resistors appear OK. I figure this is just a normal time and miles (as we say in my business) effect. I feel that this TV may not be worth repairing. I need help just to pick this beast up (weighs in at approx. 120 lbs). A good excuse to get a LCD flat panel! Does anyone have any solutions that I could try? I have tried all search terms I can think of but find no similar complaints on the web.
  • 1 more comment
  • Milton Prescott Feb 10, 2007
    NO, I am not looking for help to lift the unit!!
    I did find some info but not much help.
  • Milton Prescott Feb 11, 2007
    Thanks for the quick response. The discolored area was only on the board. The resistors appear OK but I understand that can mean nothing. There are 2 identical resistors at the point I mention. I will pull both and check the resistance. If you would want a photo I can provide that easily.
    Ohm resistance test results on R15101, 102 & 103 resistors.
    R15101 = 9.94k
    R15102 = 9.95k
    R15103 = 10.03k
    I would assume those are good resistors, well within tolerance.
    A closer inspection of the CRT board and best views of the main board reveal no obviously burnt components.
    Sergeant:
  • 308 Answers
Check for an open R15103 on the CRT drive board. It may have been one of those discolored ones you noticed. I think it is a 10,000 ohm 2 watt resistor. You may want to replace R15101 and R15102 at the same time to prevent those from going out as well if the 15103 resistor measures open after you remove it from the neck board.
Posted on Feb 11, 2007
SOURCE:
RCA Tv color problem
try degaussing the picture tube
Jan 31, 2010 | Televison & Video
Rca r52wh74 bowed picture and 3 d color
Your convergence amplifier has failed.
There are a few things that usually cause that in that particular chassis design, the most likely one being that you have lost part of the power supply to the convergence amplifier power supply board.
You may be able to repair it yourself if you're good at soldering, and dis-assembly / re-assembly.
Look for a 400ma fuse that's opened near the FBT, and re-solder all the connections in that area. Also check to see if any diodes have shorted around it too.
Good luck.
Dec 01, 2009 | RCA Televison & Video
Hatachi TV. color saggging. Blue and yellow sagging on picture
I would say that you are having convergance problems need to know the model number of the set which is on the back of the tv then might be able to help better. Is there a bow in the colors. Like the red or blue.
Mar 01, 2009 | Televison & Video
RCA F31317 or picture Tube
Hi
Please tell me if you can see any burned wires or components or can you smell something burning .
Feb 19, 2009 | RCA F31317 31" TV
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
RCA ctc203ca6 model f32649
the front panel assembly is rca part # 237420
I assume your chassis is a CTC203
Un plug the fpa and see if problem still acts up
you may not be able to find one
then try replacing the sticking buttons on it
Jul 26, 2008 | RCA F31317 31" TV
Proscan (RCA) PS52652
Also, the proscan ps52652 has the ctc-169 chassis. This set is a 52" manufactured in 93.
Mar 30, 2008 | RCA P52926 52" Rear Projection Television
RED GREEN BLUE CONVERGENCE IS OUT.
What is your Chassis # ? And convergence problems can be some of the most hard to realign. You may need to replace amps.
Jan 08, 2008 | RCA P52926 52" Rear Projection Television
Need value for part R14109
R14109=750ohms 5% 1/4w (Resistor(750r5%.25W/R14109/179317) There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it. If you need the manual, go to http://www.samswebsite.com/photofact/pf_search.asp and type in "F31317" into the search field, you will several listings. If you decide to replace it yourself, here's some more part numbers in case you need them. Model: RCA\F25422TX41 Symptom: Dead Necessary parts: Transistor(Q14401) Main Voltage regulator Q14101 Resistor R14109 open. Research indicated the flyback transformer most probably bad \\CTC203AC4\HOT/D2578(Q14101/242224)* Flyback(14536119A/T14401/244229)* Main reg(P9NBSO/Q14101/244223) \Reg(MPS8599/Q14102/147665) Resistor(750r5%.25W/R14109/179317) Reg(MPSA06/Q14103/232218) Hope this helps you. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | RCA F31317 31" TV
RCA F31317 lost blue in picture.
this symptom is characterised by the loss of one or two primary colours. this symptom can be classified into three cases: 1) loss of red colour, 2) loss of colour blue,3) loss of green color. this symptom may be caused by a trouble in the colour demodulator, in the color amplifier or in the colour subtraction amplifier circuit. in your case loss of blue colour. this is a very complicated problem that you need some special test equipment like oscilloscope and color pattern generator in order to trace the signal. tune the receiver to a color broadcast station(a colour bar generator can be used to transmit a colour signal to the set). check the Z-axis demodulator, z-axis amplifier and the B-Y output circuit for the chroma signal. observe the signal process with an oscilloscope. if the color signal is not present use a VOM to locate the defective component in any of the above circuits. check the transistors and the resistors in the collector circuit. good luck!
Feb 14, 2007 | RCA F31317 31" TV
RCA F31317 31" TV Logo
152 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
