Question about Toshiba 62HMX84 62" Rear Projection HDTV
No picture I just bought an 62in DLP projection television it has good sound but no picture is showing the lamp is not shattered or blown do you know what could be the problem?
  • devildogpi2 Dec 04, 2007
    I have a toshiba model 52mhx84.I get audio but no vidio and the unit turns off and on can someone give me an idea??
    Problem Solver:
  • 5 Answers
The lamp (23311083A) would be the most likely problem. I found the lamp on PartStore.com for about $180.
Posted on Nov 16, 2007
    Sergeant:
  • 308 Answers
If the red light stays steady, and the green light blinks 9 times then repeats, it is most likely the lamp #23311083A about $200. Otherwise, if a cooling fan is not working, it could possibly cause a shutdown problem. You can't always tell a bulb is bad by looking at it. Another possibility is the lamp ballast, but I would try a new bulb first.
Posted on Feb 11, 2007
Heard a loud pop and picture went out. When tv turned on their is still sound but no picture.
I would first remove the lamp and look to see it is intact and not shattered inside.
Dec 02, 2012 | Mitsubishi WD65737 65" DLP TV
SOUND BUT NO PICTURE
Look to see if lamp is shattered inside or if it even comes on for a few moments at turn on.
Suspects are:
Lamp
Lamp Ballast
Dirty fans and dirt on air channels in the set.
May 16, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
We have a samsung DLP tv model number HLP 4663W tv. The picture went so we replaced the bulb. Still no picture and the tv makes a noise that sounds like a fan and the tv cycles on and off by itself. ...
Yes, almost certainly a bad color wheel, see attached photo.
If you remove the lamp and look in the direction it faces you should be able to see the wheel, look for it to be missing pieces or shattered.
You Tube has detailed video instructions for replacement in most of the Samsung sets; I have replaced dozens of the wheels.
Before you rate my solution let me know if you have any questions by commenting here.
SD TECH
Jul 08, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
MY AKAI 50" DLP MAKES A LOUD RATTLING NOISE LIKE WHEN U SHAKE A LIGHT BULB THAT'S BLOWN OUT AND NEVER POWERS ON
Hi,it could be that the filement inside the bulb shattered and that's why you hear that rattling noise.But it could also be the color wheel which is a disc looking that has a gamma of colors and spins and very high rpm.When its bad or shattered you will hear a high pitch sound or crackling sound.I will recommend to take out the lamp and look at it to see if its blown,if its not the next step will be to take a look at the color wheel.Here's how : http://guides.fixyourdlp.com/samsung/bp96-01579a.php Good luck and God bless your house!
Jan 05, 2010 | Akai PT50DL24 Television
No picture, lamp checks out as good.
You can not look at a lamp and tell that it is good or bad, unless of course it is shattered, some of them look just fine but are blown. If your lamp light is on I would suggest you change it and see what happens.
Oct 30, 2009 | Mitsubishi WD-57731 57" Projection HDTV
No sound or picture
the most likely cause would be the lamp, you can pull it out and check. most of the time when the lamp blows the center of the lamp will shatter
Feb 20, 2009 | Samsung HL-R4264W 42" DLP HDTV
I own a 52" Philips DLP television and have sound but no picture
I would check to see if the lamp door is properly seated.These units will not operate without the lamp door in place or improperly seated.
Jan 11, 2009 | Philips Magnavox 51MP392H Rear Projection...
Loud pop and picture went out.I have sound but no picture.
I had this happen a few months ago. More than likely the color wheel died. I opened up the back of my Samsung DLP expecting to find a blown lamp, but came to find out that only the color wheel was in need of replacement.
Sep 26, 2008 | Samsung HLN5065W 50" Rear Projection...
RCA DLP 50" NO PICTURE
hoping it's just the lamp - removed it, and it had blown, broken glass and all!
Jul 11, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Toshiba 62HMX84 62" Rear Projection HDTV Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
