Question about Garmin GPS
Okay, I have the new Nuvi 880 with the built in FM transmitter. To use it of course I try and find the best unused station available which for me is FM 88.1. The problem is I still get some static coming over the speakers, if I put my hand on the nuvi the static goes away. There must be a way to eliminate all the static without the human touch, any ideals? Leo
  • gps man Dec 06, 2008
    Would it help to install an external antenna? There is a hook up for it.
    Leo
  • gps man Dec 08, 2008
    Your right, it is for the GPS antenna. Must be a simple way.
  • Garmin Master
  • 2,130 Answers
The problem is that these units put out a very low level signal on FM. This is mainly due to restrictions and rules established by the FCC. The levels are such, so that they don't interfere with other nearby equipment or radios.
When you go to touch the unit, your arm is acting like an antenna, making the signal from your Nuvi propagate better to your car's radio.
If you are using a window mount, you are somewhat limited in what you can do. The closer you move the Nuvi to the car's antenna or radio, the better. Just for fun, try positioning the unit on the dash (while sitting still). Can you find a spot where it sits right over the radio that sounds the best with minimal noise? If so, you might want to get a friction mount and put your Nuvi on the dash, right over the radio.
Another thing you can try is getting a plug that fits in the headphone jack, like at Radio Shack, and soldering a couple feet of wire to ground lead of the plug. Plug the plug with the wire into the headphone jack. This is what manufacturers of consumer FM transmitters provide as a means to make an external antenna.
- Jim
SHARCNET-USA
Posted on Dec 05, 2008
  • SHARCNET-USA
    SHARCNET-USA Dec 06, 2008
    Are you sure that's for the FM and not an external GPS antenna? If it's a gold circular jack about 1/8" diameter, then thats for an external GPS anetnna.
My old unit stopped working;(worked perfect for many years) so I replaced with a new same model and I have bad interference and FM static. Sometimes the FM station overrides the express radio and all you...
The very first XM radios, (SkyFi2, MyFi, Roady2) up until they were put in red boxes, had a VERY strong FM transmitter, so strong, that when Sirius was their enemy, they complained to the FCC and they made the FM transmitters real weaklings. So unless you have one of the first two batches of XM radios, the FM transmitters now are real junk and you're better off using an AUX input on the radio or a cassette tape adapter. Okay? Thanks.
Mar 26, 2015 | Audio Players & Recorders
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
In my settings there is no fm transmitter selection available
As far as I know, there is no transmitter in a Sirius Radio. I had an XM, and there was no selection for fm stations. They just figure you can tune the car radio to any fm station, in case you want to listen to fm. Hope this helps, but refer to your manual for details about what the unit can do.
Jun 12, 2010 | Sirius Sportster 5 Satellite Radio...
No sound when put on 88.3 fm
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Station to get signal from FM transmitter
I put the transmitter closer to  the antenna and it periodically worked. So, I don't there is a specific station.
May 18, 2009 | Audio Players & Recorders
My Nuvi 750 has stopped talking, still shows the map but no voice
That has happened to me several times. When it happens I go to Tools > Settings > Language. In my case, the Voice field is empty, so I click on the Voice field and then select American English-Jill (TTS) and it's okay afterwards.
May 05, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
How to manual tune the radio to a station and not use the scan
i have the exact same problem. i bought a fm transmitter, so i need to tune to a unused fm station in my region wich i cant do because the audi concert tunes up automatic and skips the unused stations ... HELP !
Nov 23, 2008 | 1997 Audi A4
Using my car speakers with my Garmin Nuvi 350
No, unfortunately ther is no way to get the unit to use your car speakers. To do this, the unit would have to have an FM transmitter or be able to connect to one. It does not have this capability. Sorry.
May 20, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 660 - how do I get FM Transmitter firmware
I believe in your location it comes as an option. transmitter is an optional module. You can browse the user manual at following link (PDF file) http://www8.garmin.com/manuals/1262_OwnersManual.pdf
You can see at 35th page, simple instructions have been given for FM transmitter settings.
If it doesn't work please contact to the Manufacturer. I couldn't find Garmin's Ireland number. However you may call UK number +44-870-8501242. Or simple you call your reseller.
Good Luck
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
129 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
