Question about VeriFone 250 Matrix Printer
Credit Card Printer P250 prints too small
This printer is printing the numbers too small to read.
Can anyone solve this problem?
Thanks,
Rob Roy
I had a similar problem ... printer printing receipt just like when printer test conducted. I turned printer off, pressed/held paper feed button, turned on, let test run, then shut off. This didn't work ... so I disconnected terminal cable from printer (printer turned off) and reconnected. Printer now works fine.
Posted on Jan 16, 2009
Spent a while on tech support with my cc processor. unplugged everything lots of times. waited 30 second. ran test page (power off...hold feed switch when turning power back on) Held machine upside down while powering off and on to clear crud. flipped the dip switches back and forth... (1 was on, 2, 3,4 were off) Nothing worked.
In looking at the printout, it was obvious that the width was unchanged...just the height. Problem started when I changed paper...They said feed mechanism was not working right and needed a replacement printer. I had another available and it solved the problem immediately.
Posted on May 16, 2009
Printer displays 10.002 error
10.000x Supply error E-label cannot be read or print cartridge is
not properly installed.
10.0000 = Black print cartridge
10.0001 = Cyan print cartridge
10.0002 = Magenta print cartridge
10.0003 = Yellow print cartridge
1 Reinstall print cartridge.
2 Turn on the printer.
3 If the problem is not solved, replace the
cartridge.
Dec 24, 2010 | HP Color LaserJet 2600n Printer
Need the printer to only print the last 4 digits
To solve last 4 digit issue.
It need to reprogram Tranz 330.
Not buying Printer
this model is not compatible with PCI compliance.
contact your processing company and let them reprogram this.
http://www.gorillapaper.com/verifone-printer-p-250.html
Mar 09, 2010 | VeriFone 250 Matrix Printer
Intern page counter for hp deskjet 3650
Turn the printer on, Press and hold down the POWER button while holding down the power button Open and close the top cover four times and then release the POWER button
It will print a page and in that page just look for Line Number 21 which will say like - PX = XXX
XXX is the number of pages this printer has printed till date
Oct 16, 2009 | HP DeskJet 3650 InkJet Printer
Multiple probs w/ HP 5150
Try `driverguide` on the net.
Update your printer driver, this should solve your problem.
Also check the printer lead is ok
Feb 02, 2009 | HP DeskJet 5150 InkJet Printer
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark printer p250
http://downloads.lexmark.com/perl/downloads/downloads.cgi
After going to www.lexmark.com and searching, I finally put in "Lexmark P250" ....someplace and it sent me to the download area. You will have to run the program. Don't save it. For some reason, even though it's suppose to be a .exe file, my XP OS won't open it.
Aug 20, 2008 | Office Equipment & Supplies
Omni 3200 Printing Half of Receipt
The printer needs to be replaced. I do have the printer mechs for the Omni 3200s which I sell for $50.
Jul 17, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
Using a Verifone P250 Printer with a PC Credit Card Program
which one ? i have tried all also the cable i have is a serial 25 pin female so i got a adapter to serial male still wont print can anyone help ?p250 to pc windows xp
Dec 19, 2007 | VeriFone 250 Matrix Printer
Hp 920c
Do you have the print cartridge that you replace from this printer. Put it back in and see if you print you may have purchased a bad cartage
Oct 21, 2007 | HP DeskJet 920c InkJet Printer
Canon MP160 all in one
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Jun 12, 2007 | Canon PIXMA MP160 All-In-One InkJet...
VeriFone 250 Matrix Printer Logo
432 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
