Stylus for Sharp CD Music System CMS - R70CD
I am looking for the Stylus or just the needle for my Sharp music system CD Music System CMS - R70CD or the one work with it. Any assistance will be greatly appreciated.
Thank you.
NB: Serial # 20203465, if it helps
  • Anonymous Jan 11, 2009
    Man, this needle is almost impossible to find... I sugest you change the capsule, there some models that fit perfect. I've changed mine, and works great.
  • 3 Answers
SOURCE: Doesnt play music
See this "ticking sound" thread; probably the same issue.
Posted on Sep 14, 2008
freetek
  • 5568 Answers
SOURCE: New GPX Home Music System - no sound
Unfortunately, GPX has, in my experience, a poor reputation for quality. I wouldn't delay either exchanging it or filing a warranty claim once you are sure you have done your homework and have things set up correctly.
Posted on Oct 28, 2008
SOURCE: bose acoustic wave music system
I have the same problem: ready to throw it out and get a new one
Posted on Dec 09, 2008
SOURCE: Durabrand CD Home Music System - Volume default
HM3817DTBLK:Default volume
I sent a note to the manufacturer. Communication attached below.
Dear Customer,
We thank you for your interest in GPX and our products. We apologize, but the volume level on the unit is a factory setting that we are not able to override or alter.
Once again, we apologize for any inconvenience this may have caused.
Best Regards,
GPX Consumer Service
>>> "Chris" 12/27/2008 2:02 ">x.x@eds.com> 12/27/2008 2:02 >> PM >>>
The default volume is set way too high on this radio. It is at 17 and we would like to reset it to a much lower level. How do I do this?
Chris
Posted on Jan 05, 2009
  • 15 Answers
SOURCE: my durabrand cd home music system wont come on
If you have no lights or power to the unit, check on the back of the unit to see if there is a twist and pull type knob for a fuse. If so, unplug the unit/player and take the fuse out. If it is damaged/broken/wire element burned/cracked, it will need to be replaced. Take the old fuse with you to make certain of a correct match(volt/amp/slow or fast acting)Most Radio Shack/Walmarts/Ace Hardware stores stock these type of fuses. They are very inexpensive, usually less than a $1 or $2. They are on most home entertainment equipment/t.v.s etc. to prevent some degree of lightning or power spike damage the unit.
Posted on Oct 13, 2009
I just ordered a new needle for the electro brand 9208. Thank you for directing me in the right area. My question is I am tring to remove the old needle and I do not want to break the arm. My directions do...
You're right to want to do this with care.
Put the arm on to it's rest and lock it on with the arm lock.
Delicately, yet firmly (if that makes sense), use you thumb and forefinger to hold the headshell (to prevent stress to it or the arm)
With the other hand, use the thumb and forefinger to pull the stylus (the whole of the red bit) towards you.
If it is the original factory fit, it can feel like its glued on, but it is not. If this is the case, try lightly wiggling the stylus from left to right as you pull it towards you.
Best Of Luck
Feb 09, 2011 | Electro Brand Nostalgic Stereo CD Music...
Tivoli Audio Music System: CD wont eject
We've had the Tivoli Music System for 3 years. A CD became stuck in the player when I pressed the EJECT button before turning the player on. We tried turning it off and back on, unplugging it for a minute, removing the batteries and unplugging, etc. Nothing worked. I finally turned the player upside down in my lap, then turned on the CD player, and it said LOADING! Progress!!! I turned it right-side up and hit EJECT, and it worked like new. The CD loading mechanism had become bound up and simply needed a different "attitude" adjustment. Don't give up too early in attempting to fix these players on your own.
Feb 17, 2010 | Tivoli Audio® Music System Shelf System
Sharp CMS C640 CD player not working right
You can get a brand name lens cleaner for CD players from your local electrical shop etc. If it is dirt on the lens, that should cure it.
Feb 10, 2010 | Sharp CMS-C640 Shelf System
I recorded music on track 3 and a voice on track 4 but when ever I try to record to CD disk I only get music and no singing
You have to bounce your tracks to a sstereo pair of tracks. Have a look at this document:http://cms.rolandus.com/assets/media/pdf/MICRO_BR_Q_A.pdf I hope this helps.
Nov 26, 2009 | Boss Micro BR Digital Recorder
I just got this unit, and tried to put on a record, but the needle just goes strait to the center and wont actually play the record.....any suggestions???
the tone arm need adjustment by a techician or you could try a new needle.
When testing use a record that is in good condition but not one you like.
Sep 16, 2009 | Electro Brand Nostalgic Stereo CD Music...
Stylus info
Usually red is rt channel, white is left,green is rt ground and black is left ground.
Aug 29, 2009 | Teac GF-350 CD Shelf System
ERR-0101
meens fan problem ok thx nick use lens cleaning cd also ok
Feb 11, 2008 | Sharp CD-C2900 Shelf System
253 people viewed this question
 Grubhead
Grubhead
