Question about AT&T Blackberry Curve 8300 Smartphone
Help my blackberry bold
My bold cant do anything to turn it off i pull the battery. To turn it on i put the battery back, and all i get is a white screen that says No application Linked(factory05)
  • jrs_shedevil Dec 05, 2008
    i've tried it 5 times now nothing is changing
  • AT&T Master
  • 1,800 Answers
U need to upgrade the firmware of ur device sir
Posted on Dec 05, 2008
My blackberry bold is just on , and the screen stays white saying "JVM error 51?" i don't know what's wrong with it.
Have you ever done a backup with the blackberry desktop manager?
If so, hook up the phone to the PC and restore it.
If not, chances are you installed something that caused this, so try your best to uninstall it.
When in doubt, turn the phone off, pop the battery out and wait 10 seconds before putting it back in and powering it up.
Mar 02, 2011 | RIM BlackBerry Bold 9700 Smartphone
I took this blackberry bold out of a recycle bin at my school and when i plug it into my dads bb charger the red light comes on but after 10 minutes of charging it still wont turn on.I think its a corrupt...
try this:
JUMP STARTING A BLACKBERRY
1. Plug wall charger into wall and then plug into blackberry
2. Take off back cover and pull the battery out (while it is plugged in still)
3. Wait 30 seconds. The red LED may remain on (tech said it didn't matter).
4. Put the battery back in and wait about 5-10 seconds and it'll begin to boot up (white screen with clock icon).
Jan 28, 2011 | Computers & Internet
I put my phone on the charger & the screen went white & displayed the hour glass & has been stuck like that ever since. I even bought a new battery & it's still like that. It won't do...
try doing a battery pull if that doesnt work you'll want to run the application loader. i found steps on www.tmobile.com/forumsIf the LCD screen is white, blank or empty, a soft reset may need to be performed, or there may be an error with the display drivers and the OS will need to be re-loaded onto the device. Please follow these steps:
  1. Remove the battery from the device.
  2. Wait 15 seconds, then replace the battery in the device.
  3. Turn the phone back on.
  4. If the screen is no longer white and functions correctly, the issue is resolved.
  5. If the screen is still white, continue troubleshooting.
  6. Confirm BlackBerry Desktop Manager has been downloaded to the computer.
If BlackBerry Destop Manger is installed, skip to step 2. If not,
  1. Install Desktop Manager
  2. Backup your information using the BlackBerry Desktop Manager (recommended).
  3. Download and install the blackberry handheld software to your computer.
Note: Running the Application Loader will take approximately 15-60 minutes to complete.
***ALTHOUGH THESE STEPS ARE FOR THE BLACKBERRY 9700 BOLD BY TMOBILE, THE PHONE MODEL IS THE EXACT SAME AS THE BLACKBERRY 9000 TOUR, OR BOLD THROUGH AT&T****
thank you!!!
p.s. please also provide feedback that reflects the solution provided i.e. 3 or 4 thumbs! thank you!!!!
Jan 10, 2011 | RIM BlackBerry Bold 9000 Smartphone
I have a blackberry bold 9000 but my display screen is white and i cant see anything.but the phone vibrates and rings when i get my messages and calls. I can speak and hear the call properly only my...
this link will actually show you a video on how and also all the steps with screen shots!!
http://forums.t-mobile.com/t5/BlackBerry-General-All-Devices/HOW-TO-Install-New-Software-and-Update-Application-Loader/ta-p/306005
Dec 24, 2010 | RIM BlackBerry Bold 9000 Smartphone
My smartphone has suddenly turned to white blank screen. Please help
Hi, not sure if it will help but my 9000 did the same thing, I ended up putting it on charge for a while and it finally came back on. when it did, the battery was completely dead(it was fully charged) I replaced the battery and havent had an issue since. hope this helps. also, pull the battery and plug in to a power source and it should try to come back on for you.
Sep 01, 2010 | RIM BlackBerry Bold 9000 Smartphone
Hi my blackberry was working fine havnt dropped it or anything woke up this morning and the alarm clock was upside down, took out the battery and put it back in, the blackberry bar loaded but started to ...
It might sound absurd but the frantic truth is that the LCD screen of your phone is bad which might be as a result of previous shocks and abrasions which it has been subjected to.This is a common feature of the 9700 bold.
The only solution is to replace the LCD screen of your phone,it cots between 40-79 dollars .
Take care..
Aug 23, 2010 | RIM BlackBerry Bold 9700 Smartphone
I cant turn my blackberry on- it is only booting up half way
my blackberry bold 9700 turns on and boots but keeps restarting by itself
Jun 22, 2010 | RIM BlackBerry Bold Smartphone
MY BLACKBERRY BOLD 9000 SOMETIMES DISPLAY WHITE SCREEN WITH MULTIPLE LINES THEN AFTER 15 MINUTES IT BECOMES OK
Did the phone drop from you? anyway, the screen of your Bold 9000 is malfunctioning, i suggest you get a torx 6 screw driver by your side.
Turn off your phone, remove the battery cover and battery.
Turn the fone over and remove the front cover with your screw driver, pull off the front cover and afirm the LCD screen very well to the panel of the phone, recouple back to test, if it is still same thing, i suggest you change the LCD screen of your Bold 9000.
But if you can do all this, i advive you get a technician or somebody who can do it for you.
Best regards.
Feb 07, 2010 | RIM BlackBerry Curve 8310 Smartphone
I dropped my blackberry bold and screen is white with red line
That means no battery, your lucky. Just go to a phone place and try a new battery. I am assuming you already took the battery out and tried reinserting it. Does the battery have red xx's on the bottom, if so it probably fell on grass and the moisture got to the battery some how.
Aug 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry bold suddenly shut down
Lots of battery issues with the Bold. Try taking the battery out, keeping it out and connecting to PC with USB. Do any lights come on? Red light should appear. Put battery in while connected to USB.
Another fix that I found for a friend-leave the battery out of the unit for a day-put it in and plug in power cord or USB. It worked.
Mar 20, 2009 | RIM BlackBerry Bold 9000 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
