Directv DVR R15-500 problem
I left this morning and all was well. No one touched this all day long. Came home, and only static/snow, and the DVR blue Power light and the orange record light were FLASHING. Tried everything, pressed reset, no response. Turned off and pulled cord out, left it off for a while, still did not fix it. Directv Tech Support had me do the same thing. He also had me try pressing the down arrow below the select button while simultaneously pressing power, and tried reset and power simtaneously. No help. He said it's probably defective or overheating and they are sending me a new one. But I never give up, and I know there's a fix he didn't try - he was reading out of a manual and ran out of ideas! Any solvers out there?
  • 7 more comments
  • catmanjoe720 Dec 18, 2008
    I have the same problem. Was watching TV last night without a problem. Turned off the TV, left the box on as usual, and was woken up in the middle of the night to the clicking as the box flashed as described. Calling customer service tonight, will post any info.
  • Anonymous Dec 23, 2008
    same exact problem
  • Anonymous Jan 01, 2009
    Same deal, woke up and orange and blue lights "flickering".
  • mnvron Jan 16, 2009
    Same problem w/ DTV R15-500. Power light stays on and no others. If I pull the power cord out, wait 60 seconds, then plug back in, blue screen indicates the DVR is powering up, and it makes a series of clicking sounds for approx 30-60 seconds, then goes quiet and the tv screen goes black.
  • Korrie1976 Mar 10, 2009
    Came on an DVR 15-500 would not turn on. Unplugged, pressed all combos of RESET button and other buttons .. the power light and the record light are flickering.
  • grapeabod Mar 10, 2009
    Iam having the same problem as all the other posts. I have also tried all the same fixes to no avail. Please help!
  • vitoman389 Apr 29, 2009
    SAme problem. Lights flash. I think I had a power outage because the clock was also flashing. The hard drive is starting and stoping.
  • Anonymous May 18, 2009
    Same problem. Hard Drive is Gone
  • vitoman389 May 11, 2010
    If it's a software issue why wouldn't direct TV just figure out a fix for it or go back to a prior version???? I've had the unit for 2 years and then the issue recently happened. I ended up buying a new unit.
I had a similar problem the orange record light was on and the unit could not be turned on. I didn't want to replace the unit since all recording would be gone. After some googling I found that the problem was related to the power supply. I found three capacitors with swollen tops 2 1000uf@10V and 1 1200uf@10v. I replaced them and everything works again.
Posted on Jun 11, 2009
  • rcheney600 Feb 10, 2011
    I had the same problem with my DirectTV DVR model R15-500. I took the advice given in previous posts. It was the 3 capacitors mentioned. I bought the Radio Shack caps, but realized what the actual problem was. This is a switching power supply, and it needs low ESR caps. The originals were probably the wrong type (or cheap). If the equivalent series resistance is too high at the high switching frequencies, the caps will overheat ( the Radio Shack units could be worse than the originals). I opened an old PC power supply, and took out 3 of the low ESR caps, a 3300uF,and 2-2200uF all at 10 volts. I put these in and it works perfectly again. Thanks very much for the help!
I also had the same problem on my two DirectTV DVRs model R15 (i.e. power and record lights flashing when unit switched on – unit would not power up). I agree with Novurania findings, this is a power supply board issue, as I was able to swap power supplies when the first unit failed. I took a look at C7 and C8, which were the 1000 uf @ 10v capacitors mentioned by Novurania and in deed the top of the cans were slight bulked. The 1200 uf cap looked ok. Radio Shack sells electronics part and they had some 1000 uf electrolytic caps rated at 35VDC instead of 10 VDC (p/n 2721032 for $1.59 each). They were a little bigger in rating and size, but they worked just fine. I did not need to replace the 1200 uf capacitor, so I would recommend staring with C8 and C7. Both units are now working. Cost $6,97 instead of several hundred $ and another 2 year commitment to DirectTV. Hope this helps if you have the same problem :)
Posted on Sep 06, 2009
My DVR went out also. The record button would blink but that was it would not power up or anything else. On the advise of Novurania I replaced the two capacitors 1000uf@10v and everything works great again. I lost none of my recordings and it only cost $1.65 so I am really thankful for the advice!
Posted on Jan 12, 2010
I want to thank the participants for the tip on the power supply. My R15 had no power light and the record light blinked on and off with the power supply ticking. I did see that C7 and C8 electrolytic capacitors were both bulging. I replaced them with the 1000uf 35VDC units from Radio Shack and everything is working fine. Easy fix for under $4.00. The solder on the board requires a high heat iron so be aware of that when starting the fix. My stick soldering iron would not melt the solder. Had to go to the gun iron on the highest setting to release the factory solder.
Posted on May 16, 2010
I am yet another user with a bad R15-500 Directv DVR. It stopped working yesterday. When connected to power it was just making a clicking sound: "click-click-click." After taking off the cover to the case, it was obvious that the sound was not coming from the hard drive (I disconnected power to the drive) and was coming from the board mentioned above. I replaced the C7, C8, and C10 capacitors (all were bulging on the top), and this fixed the problem!! My wife now thinks I'm a genius! (thanks to this message board :) ), Ditto on needing a high heat solder iron to melt the manufacturer's solder. I didn't even need to add my own solder, as I just pushed this solder to the side, and pushed it back over the new capacitors. The C7 and C8 capacitors are 1000mF, the C10 is 1200uF. My Radio Shack only had 1000uF 35V capacitors (part #272-1032, cost ~$1.50) with radial leads, which matches C7 and C8. So, I used this to replace all three (C7, C8, and C10), even though the C10 is 1200uF. The diameter of these Radio Shack capacitors are a bit bigger, but they will fit. Here's a helpful link on how to replace capacitors: http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Thanks Again contributors!
Posted on May 23, 2010
  • jda720
    jda720 Aug 04, 2012
    Hello, I have the same problem with my R15. However, I am not able to locate C7 and C8. C10 is off by itself and looks fine. Any suggestions? Thank You
Same problem here -- blue power and amber record LEDs flashing on powerup.
Looked and sounded like a power supply problem, so I opened it up and noticed the bulging caps (C7, C8, C10).
Replaced with parts from RadioShack: C7 and C8 with 1000µF 35VDC, and C10 with a pair of caps in parallel: 1000µF and 220µF 35VDC...I had to enlarge the hole in the PCB with a 1/16" drill bit to get both sets of leads through (drill from the copper side, and be careful!).
All systems go.
Posted on Aug 05, 2010
Replaced the c7 c8 c10 capacitors and everything worked fine
Posted on Mar 10, 2010
My c7, c8 and c10 were also bulging. I replaced with the Radio Shack parts (used 1000 uf cap instead of 1200 for c10) and it didn't work.
Posted on Jun 05, 2010
  • ca_albert Sep 08, 2010
    you need to use the recommended 1200 uF 10V capacitor for c10 or else it wont work properly.
  • 4 Answers
Replaced the C7 and C8 on the power board (C10 appeared okay) C7 was bulging at the top and C 8 had actually popped on top. Reassembled unit hooked it up and worked fine...
Thanks to those that figured this out,,wife is extremely happy now!
Posted on Mar 02, 2012
Thanks for the insite on the bad caps. One of my DVRs (r15-500) stopped working; both power and rec lights flashing. Took it apart and sure enough, both 1000 uf caps mentioned here look bad. I plan to replace them today and see how it works.
Posted on Feb 11, 2010
  • 1 more comment
  • jermat Feb 11, 2010
    Follow up to my prior post...both caps were bad. Replaced with Radio Shack parts and the unit works perfectly now! Thanks for the solution...didn't know it would be so simple.
  • Buckshot451 Sep 21, 2010
    had to use a 1500 uf and two 1000 uf but it works
  • mikeemwse Jan 13, 2011
    Thank you so much! I, too, had the same exact problem - just the C7 and C8 caps... went to Radio Shack and picked up the capacitors and now everything is good as new! As with others, my Radio Shack only had the 1000uF 35V as well, but they work fine. Had never even done any soldering or anything like that before, but after watching the suggested video and other YouTube ones, I felt confident and it was pretty easy. I used a 30 watt soldering iron and let it heat up for a long time before starting and it worked fine on melting the existing solder - probably took a little more time with the tip on the solder than a higher capacity iron, but it worked fine. Whole process took about 10 minutes - only because of lack of experience... experienced solderers probably could do in 2 minutes!
    New Friend:
Sweet fix. I've had two R15's die due to this problem and replacing C7 and C8 did the trick. Thanks for posting this!
Posted on Mar 12, 2015
My DirecTV R15-500 had no lights and was dead except for a sound that was almost like a heartbeat. I found the three capacitors referenced in the other posts and all of them had bulging tops. I found the exact same rating capacitors at EPO here in Houston and replaced them and now my unit works fine. I had two seasons of Breaking Bad and Fringe and Sons of Anarcny on that machine and was afraid I had lost them. I was planning on finding an identical maching and swapping hard drives but glad I didn't have to as I had read that that won't work. One caveat, I forgot to note the orientation of the two leads as I did not think of polarity. By checking the orientation of the other capacitors, I was able to get all three soldered in correctly. There was a big dot on the motherboard indicating the location of the negative lead. E. Wilson
Posted on Sep 05, 2012
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV Genie® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your Genie® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Feb 08, 2016 | Televison & Video
How do i reset my dvr
If you stuck in CCTV DVR Password Reset process. just visit
CCTV & Networking Technical Support Channel on youtube.
Here is the link:-
CCTV Networking Technical Support
Jan 13, 2016 | Swann Communications Home Security
I have a blue light and an orange but my tv will not come on
If you are referring to an R15 (the big box in the picture with your post), there should be 3 blue lights on the front of the DVR: one to the far left (power), a big circle in the middle, and one on the right indicating the resolution the DVR is currently trying to send to the TV. The orange light indicates that something is being recorded; either a show or something from DTV like channel listings. The orange light has nothing to do with your TV but may indicate that the DVR is downloading setup information.
As for turning your TV on, when you first get DTV, the DVR remote does not know how to talk to your TV set, only the DVR, so you have to teach the remote to talk to your TV. To do that, turn your TV on with the remote that came with it (or the on/off switch on the TV if you're a dinosaur like me) and change the TV input to whatever input the DVR is attached to - usually HDMI or Component. If you see something (a TV show, a guide, a DirecTV logo, etc.) you're in the right place. Now hit the Menu button on the DTV remote and you'll see a menu on the left that includes "Setup". Use the arrow buttons on the DTV remote to move to Setup, press Select, and then select Program Remote. Follow those instructions carefully, step by step, and you should be all set. (Caveat: I am working from memory so the exact wording might not match and I might have missed a menu level. If so, I apologize.)
May 27, 2014 | Directv Plus DVR DTV Receiver / 100-Hours...
Blue light not on / power failure to DirecTV+Plus (Silver Box) April 2010 Recording capacity was at 3% left / no longer power / fan is on and working Want to get recorded movies, tv shows, etc., from...
Well if you have another dvr thats the same,,take cover off and switch hdd/hard drives,,or take ot out of the dvr hook it as a second hdd to your cpu and retrive the movies,,goodluck
Nov 20, 2010 | Televison & Video
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Directv dvr will not power on. The record light
Unplug the DVR for about 20 minutes and then plug it back in. If that doesn't work its probably time to contact DTV for a replacement.
Mar 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
DIRECTV HD DVR REMOTE CODES WILL NOT OPERATE DVR
If you turn off power saver on your tv it should correct the problem...
Mar 02, 2009 | Bose Cinemate Digital Home Theater System...
Connecting my router to my Directv DVR
If you are using an AT&T supplied 2-Wire router - then I have the same setup.
It does work.
First you can check to see if DHCP is doing the job.
Go to your router address:
(something like 192.168.1.254:5000) < they should have given you this on install)
Look at your network and see if the DVR is there.
If so, note the address.
Now go to setup on DVR and see if it has the same address.
If not...
You don't need to change the router to static, but it helps to change the DirecTV dvr to static.
I have the HR-20.
Give an address in the range of those leased by the router.
192.168.2.166 or something.
Make sure your first 3 octects match your router ie: 192.16.1
Just go to setup on the DVR and change it to the hard IP address.
If the router is not uPnP (2-Wire is not), then you may have to open a port or tow to get DirecTV VOD to work (maybe not or I don't remember which ones, googe it.)
The IP Mask should be 255.255.255.0.
Open the screen with the button below the lower DIrection Switch.
It is the you go for
'Find SHows'
"manage Recordings"
If you see a new entry entitled "Pictures, Vedeos and more" then you are online.
If not --- google some more.
Oct 13, 2008 | 2wire (1000-400108-001) Router
DVR Freezing up
Most likely it's your hard drive going bad. You can replace it and not junk the unit.
Nov 28, 2007 | RCA DVR-40 DirecTV DTV Receiver / 35-Hours...
Televison & Video Logo
9,086 people viewed this question
Top Televison & Video Experts
