Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Filters I cleaned the filters, and now I can't remember exactly how to put them back in. Please help~ Thanks
  • 107 Answers
Okay simple. You should have 3 filters. A foam, plastic and a round paperish filter. Foam filter goes around black air filter which goes in the bottom removable tank and then the grey one goes in the upper tank and twists in
Posted on Dec 08, 2008
Dyson DC14 Bar brush and belt replacement.
Try the op manual http://www.dyson.com/customercare/manuals/us/dc14_opmanual_usa.pdf
Aug 30, 2007 | Dyson DC14i Bagless Upright Cyclonic...
I cleaned my filter and forgot how to put it back on, how?
Hi there! To return the air director back into the dirt cup, rotate 1/4 turn clockwise to lock into place. To replace the pleated filter. Return filter cartridge to base of cleaner. Click button on filter cover back into place to lock filter cartridge in base of cleaner. Hope this helps! I have also included a link to the instruction manual for reference if needed. Thanks! http://dirtdevil.com/file/956/
May 20, 2014 | Dirt Devil Easy Lite Quick Vacuum
Red light is on my filter queen
The red light on the filter Queen is on to tell you to empty the canister and change the filter. It is a heat sensor that makes it come on and if it is full it gets hot. Also when you take the motor piece off of the bucket under the nylon cone shaped guard that protects the motor there is a secondary filter in there that needs to be changed from time to time and they are supplied with the cones inside the package of rep[lacement cones there should be a spare or maybe two. It is a round thin filter about 3.5 inches across and it just fits in very easily and there is a plastic ring that holds it in place. So pop out the ring and remove the old one and then replace it with the new one put the ring in to hold it...it just snaps into place.replace the nylon guard and put in a new filter cone. Put the machine back together and away you go the light should turn off and you are good to go. Thanks for your time and please try to remember to click on the yes box if this was any help to you at all.
Oct 10, 2010 | Filter Queen Majestic Canister Vacuum
Kirby sentria shampooing not right
make sure u put the exact/right instructed amount of soap in the tank.....after each room, wash & clean tank filter. open tank all the way.....pull back slowly. if too much foam...adjust tank knob.
May 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Hair on top of washable filter on d14 animal
One way or another, dirty air is by-passing the cyclone. Check that all the seals are undamaged and in place, especially the big black ring at the bottom of the yellow bit inside the clear bin.  Also check that the bin base closes tight after you've emptied it.
If this doesn't help, please post a response and I'll try again.  If it does help, please remember to rate me!
Apr 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a dyson alergy machine, I have emptied it, but I would like to clean the filter. I can't locate where the filter is or how to get to it to clean it. The manuel for this is not with the machine. ...
Greetings Irlawren3,
It all depends on the model you currently have. The filters on some are above the motor and some are on the side housing. Its pretty clear looking at the unit where the filters are located. I would suggest investigating your unit and looking for the filter.
When you do locate the filter, it is to be washed with plain water and allowed to dry for at least 12 hours before being put back into the unit.
One thing that helps determine the model is the color also. What color is it?
Thanks!
Dorothy
Go Ahead. Use Us.
Jul 30, 2008 | Vacuums
Rainbow
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=779655
Rainbow
Posted by Nat51 on Jul 13, 2008
Hi: I took my unit apart to clean it. I was careful to put it back exactly as I took it apart. Now it won't start. I also need a new filter. I rinsed it out but it still stinks.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way is to check your owner’s manual to see the trouble shooting guide of which may help you. It could be a loose wire; or the separator could be on too tight, I am going to give you the Rainbow / RexAir Factory phone # so that you can check with cust serv or their serv tech support. Feel free to contact your local vacuum cleaner dealer in your area also.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 13, 2008 | Rainbow E series Canister Wet/Dry Vacuum
How do you get to the filter?
Well I presume you've removed the clear plastic bin as if you were going to empty it. Looking at where it was on the main machine there is a plastic tab you can push up and the top flips back. I have to admit until I'd done it the first time it wasn't obvious. Just remember the filter is about the size of a dunkin donut at the top. The tab is on the side that the clear dust bucket restsso put you finger at the top and run it down where the bucket laid until you find a bit of the plastic that 'just' juts out enough that you can push it firmly up and voila. And boy once you've cleaned the filter what a difference
Jun 29, 2008 | Dyson DC08 Cylinder Bagless Canister...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
