Question about Dryers
Dryer will not start
GE DX4500EE1WW: When I turn the start knob the dryer makes a hum, but does not start. Where do I start in my troubleshooting process?
  • 750 Answers
Faulty Drive Motor
If the motor will not start, it is possible it is defective. The wiring of the motor is different for each brand and you will need to refer to the wiring diagram of your dryer for the specific terminal locations. You will need to use a volt/ohm meter to check for resistance between the run winding and common (may be referred to a neutral). If there is no resistance, the motor is open and will need to be replaced.
The motor bearings can also go bad. A dryer with a motor in this condition can sometimes be started by hand and it will run. However when the motor gets hot the bearings begin to seize and the motor will stop. In this condition you must also replace the motor.
Posted on Dec 05, 2008
My GE dryer knob hums when I turn it on, but it will not stay started?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | GE Dryers
I have a GE DX4500EE1WW electric dryer. Over the weekend it stopped working. If you turn the start dial you can hear it hum so I know it's getting power but the drum won't turn. I've tried it on every...
MOST LIKELY A BAD MOTOR OR SOMETHING CAUGHT IN THE BLOWER WHEEL. UNPLUG UNIT, TAKE TOP PANEL OFF AND THEN FRONT PANEL. PULL THE DRUM AND BELT OUT AND LOOK INTO BLOWER HOUSING FOR RESTRICTION AND SEE IF YOU CAN TURN MOTOR BY HAND.
Oct 06, 2010 | GE Dryers
DI went to start my GE gas dryer DWSR483. Turned the START knob but i just hear a hum....almost like the drum is stuck, but I can turn it by hand?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 11, 2010 | GE Dryers
GE electric dryer; when start knob turned, dryer hums but will not run.
It is probably a faulty capacitor. This component energises the motor on start-up. It is a small white cylinder, usually located next to the motor. it has 4 or 2 connections. Easy to replace it, cost about $30 for the part.
Aug 18, 2010 | GE Dryers
I have a RCA dryer and it makes a humming sound when I try to turn the switch to start the dryer. The dryer will not start.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
Starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
Jan 04, 2010 | General Electric WHDRR418GWW Dryer
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Dryers Logo
191 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
