Question about Canon PowerShot S5 IS Digital Camera
Canon s5 is it will not power up
Checked the batteries and still no power
  • 3 more comments
  • drivembig Dec 15, 2008
    camera will not power up at all...
  • sandycovecra Dec 15, 2008
  • kslentz Dec 22, 2008
    Same deal.  Is there anything to the "watch" type battery that is in the battery compartment?
  • Anonymous Jan 06, 2009
    Same problem. Brand new out of the box. I also have the AC power cord. Still no power .
  • srinthout Feb 28, 2009
    My S5 worked fine for a year. Now it's as dead as a door nail. Same issue.
OK, since I'm an engineer I couldnt resist the temptation to open up the beast for more than 5 minutes so I opened it up to see what's inside (I can't recommend this due to the small screws any tiny delicate connectors inside). Along the way I discovered and fixed the problem.
As is typical for broken appliances usually the primary method for succesful repair is: open, vacuum clean, close. And otherwise see what happens along the way.
What I found in my case is very simple: when I close the battery compartment latch you are supposed to hear two sort of "clicking" sounds. The first one is a obvious one which happens when the plastic of the lid snaps into the plastic latches on the camera body, it is a clearly audible plastic-on-plastic like clicking sound. The second clicking sound, which was the missing link to make my camera work, is a higher pitched, lower volume, metal spring like snapping sound. I don't know where that latch occurs but it only happens when I push the plastic lid all the way in even after it seems it is already fully secure. Without that second metal-like click my camera won't power on. I can reproduce the problem by closing the battery lid but not to the point of the second "click".
So my simple solution is, push or jam your battery lid all the way in until you hear the metal-spring like clicking sound. Worked for me, hopefully works for you too.
Posted on Feb 28, 2009
The camera (Powershot S5 IS) suddenly quit working. It will not power on (tried two sets of fresh batteries). Am I overlooking something very simple? Is it related to the small button battery that...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Aug 11, 2011 | Canon PowerShot S5 IS Digital Camera
Tip
Hi guys.. try NiMH rechargable battries with 2500 mAH or 2700 nAH. These...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Aug 20, 2008 | Samsung Digimax D53 Digital Camera
Hi, I have problems with my Canon powershot S5 IS, no matter what I do, my batteries are dead within 30 seconds. I've used a new pack of batteries to make 6 photo's. Anybody got advice?
it looks like the Camera Shortend the batteries
its a problem with the internal power unit one of the components is short and cause this problem
ecrdn@yahoo.com
Jack
Oct 20, 2010 | Canon PowerShot S5 IS Digital Camera
My camera just doesn't turn on.
i dropped my camera it is a samsung 8.2 and only the power light comes on
Sep 13, 2009 | Canon PowerShot S5 IS Digital Camera
I have canon S5 IS camera. When I power it on, it shows lens error and switches off. kindly suggest solution
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 14, 2009 | Canon PowerShot S5 IS Digital Camera
Canon S5 Advance user guide
http://software.canon-europe.com/
Try this page of Canon europes site - It lists all the camera models - follow simple links to find yours
Mar 27, 2009 | Canon PowerShot S5 IS Digital Camera
Brand new Powershot S5 IS
Have you checked the batteries?
This camera should only use Alkaline AA batteries or NiMH batteries.
Are they flat or the wrong type
Also check that your memory card is installed properly and all covers are closed
Jul 01, 2008 | Canon PowerShot S5 IS Digital Camera
How to power up a Minolta Program 3500 xi flash through a Canon S5 IS?
Im sure that model of Flash. Does the minolta flash fit the hot shoe of the Canon?
If it does then I would first try seting the flash to manual mode and adjusting that.
Let me know if the Flash does not fit and I will try to help you from there.
Take Care,
Caleb
Dec 21, 2007 | Canon PowerShot S5 IS Digital Camera
Cannot find out where I can get the advanced user guide (Adobe) for the Canon Powershot S5 IS
Please send me a copy of the advanced user guide for Canon Power shot S3 IS immediately.
Hemanth kUmar
Sep 21, 2007 | Canon PowerShot S5 IS Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
148 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
