Question about Winco Electrical Supplies
Lose of residual magnatism
HP6000 Winco.39hr on unit. After shutdown gen has to be rexicted
to work again.
    President:
  • Winco Master
  • 1,388 Answers
I have not worked on this model, however other Wenco generators have a capacitor the retains a charge to aid in the beginning of the power cycle. Also diodes could be leaking. Simple check with meter but parts must be removed or isolated to properly test. Be sure to short leads of cap before testing. More information is available at WWW.wencogen.com.
Posted on Dec 05, 2008
I hooked up. it dont produce power. It has set for a long time. why
If the generator doesn't have a auto field field flasher it possibe it has lost its residual magnetism. If also it is a manual pull stater the same thing can happen.
Simply reflash the rotor field and it should again generate power. The procedure varies from manufacture to manufacture.
Apr 13, 2015 | Winco 15 kW PTO Generators - W15PTOS
Generator's motor continues to run butb generator stops supplying power after 10 minutes.
this model has an electronic voltage regulator this might be your problem sometimes when gen sets are left outside the little critters and such get in there and build there homes on top of something and that makes it get hot when we finnaly use the gen set , this overheats the part and hence we need to replace the part , if left outside I take fine mesh screen and cover all the air gaps in my stuff cus this has got me in past more than once
May 19, 2014 | Winco WC5500H - 4500 Watt Portable...
My friend has a problem with his alternater. Its becomming magnatized.
Alternators have no residual magnetism so they need a current from the battery before the field windings make the stator a magnet . If the case is acting like a magnet then there is current flowing through the stator windings . . I would be having the alternator bench tested to find the short or the reason for the current flow.
Apr 30, 2014 | Cars & Trucks
No ac output on a winco 9000 multi fuel home power genarator
How long has the unit sat?
After long periods the rotor loses it's residual magnetism and may have to be field flashed for a few seconds. Also check that the rotor slip rings are clean and shiney
Nov 01, 2013 | Winco Electrical Supplies
Power loss
950 watt is very small. Most electrical appliances need 1000watt to operate so if the vacuum cleaner is 1000watt then the gen set will trip. Check the drill as it is possibly 850watt which the gen set can handle. It all has to do with the wattage of the equipment you intend to run from the gen set
May 09, 2013 | Winco 5500 Watt TriFuel Power System w/...
Used generator after katrena worked fine but now wont generate any etric power
If its been sitting a long time you may have to flash the rotating fields. ( residual magnatism is to low or gone ),Try plugging a drill in the receptacle while generator is running and turn the chuck as fast as you can in the direction where you can feel resistance.If this doesn't work. put 12vdc( car battery works fine) to your collector rings for 1 second or so. be sure to observe polarity. you put positive to pos. and negative to neg.
Aug 15, 2010 | Coleman Powermate Premium Plus 6250W...
Media error 0 shut down displays when unit is
while the machine is off mode, hold down track edit and shutdown buttons. then power on while holding these buttons. an option to to reset will come up, let go of the buttons and select "yes".
This will reformat your entire hard drive, and you will lose any music you were working on, but it becomes operational again. Or you can send it in to Tascam and let them try to bring it back, if you don't want to lose any material.
Hope this helps :)
-Chenoa Desiree
May 03, 2010 | Tascam X9 DJ Mixer System
Have sony 36 trinitron about 5 years or older..the picture just shakes. never lose the picture or the sound. just cant get it to stop shaking.
U have magnatic degausing coil problem.Take the tv aparts,there a solid back coil all around inside the front frame of ur tv.That the cause,unplug that coil,should not effect the tv pic if have no magnatics problems.
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Electrical Supplies Logo
327 people viewed this question
Top Winco Electrical Supplies Experts
John Trevino
J.D. Browning
J.D. Browning
Tom Chichester
Are you a Winco Electrical Supply Expert? Answer questions, earn points and help others
