when i try to make a call after about 20sec when it start to call in comes up with "Called failed" and when i try to send a sms it come up with "message 1:unable to send 1 of 1 but the fone come up with my service provider and say it has signal. i have tried changing the software but it don't fix it
Comments:
Feb 12, 2007
- thanks for the help VANDEMATARAM but i have tried a couple of different sim cards but the fone still just has the same problems
Feb 13, 2007
- thanks for the help but it didn't fix the fone i've been searching the net and found a forum that said the problem might be the Power Amplificator or this chip circled in this picture http://i110.photobucket.com/albums/n86/e... if anyone know more about this problem please help me
-   I had the same problem (but I have the RAZR V3T). I kept on dialing and it gave me a "Call Failed" message. I had to dial the same number about 20 times for it to connect.
I've tried switching the sim card to my old phone and I still had the same problem.
Funny things to say, the phone started to work again when I wiped the sim card clean on the metal side.
Hope this works for all.
-   Guest
Solution #1
posted on Feb 12, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have had this problem (brand new phone, very old sim card) try putting a small piece of card on top of the sim and re-insert - seems to improve the contacts
Put another sim card and see, if it works there is nothing wrong in handset. No need change software.Or try by putting your sim in another phone.I dont think anything wrong in handset
when that happened to me all i did was went to:
menu
settings
network setup
and make sure u are under the right network, cuz it resets itself sometimes or your provider doesnt have a strong signal might have to choose another network.
example: i have tmobile but had to use cingular cuz of a stronger signal.
I think it seems that your SIM Card Board has some failed pins. I think you need to replace your SIM board and it may help to resolve the issue. You may need to take the main board out and if I am not wrong that i have fixed this issue before you need to use the soldering gun to remove the defective one and put the new one back. This isuuse was very common on every V3 models when you used them for a while specially, you keep removing the SIM card in and out. I hope this will help you some ideas. If you have tried all these ways and it is still not solve your problem, I believe, your Main Board has defective and need to be replaced. V3 has these common defective as I have fixed so far bunch of them.
Two function keys and the 7 key have died the past couple days. Phone is in like new condition. Took...
(More)
Two function keys and the 7 key have died the past couple days. Phone is in like new condition. Took battery out and the issue went away but came back day after. Any information on this?
every time when i try to call i got massage "call fail" i have balance on my sim card...
(More)
every time when i try to call i got massage "call fail" i have balance on my sim card batry is full. but i am getting same problem again and again
