Question about Octave Copy Master II Supreme Burner
What is the solution of the problem "Error, M Code Mixed!"
I have used your copy master, OCTAVE for 2 years.
There was no problem by last week.
But today, I saw the sentence "Error, M code Mixed" on the screen.
I don't understand its meaning and don;t know how to solve.
Please give me the way of solution.
2 Suggested Answers
  • 193 Answers
SOURCE: my octave copy master has a hard disk problem
Ok, first, "reformat" means you have done a format before, **** your question (about the format disk), explains that you havint?
..so have you?
OK, second, if you have a hard disk problem, you must to know what is the problem first, to solve it. (the solution might be a lot easier than it appears)
THE problem might be, a phisical problem , where your here sound comming from the disk, or a hardware/software problem, were your disk Master Boot Record (MBR) is damaged , this can cause booting problems, and even alot more.
SO u need to locate the problem, when doing this, you will find a lot of solutions, and alternatives for solving your problem....
CHECK if your hard disk is beeing recognised at startup, or in bios.
if it is, then problem one, can be bypassed, and you can continue to the next problem were you have alot of solutions.
Well this is not a solution for your problem since the discription is not enough to identify it, **** i think this can give an idea and a basic knowleg on whats MIGHT be going on.
and Finally, yes you do need a format tool, the simplest way is to insert the setup disk of any operating system (beside linux if your not familiar with it), and format it, i recomend the windows xp setup disk its the easier!
gd luck and lett me know what have you done.
Posted on Jan 01, 2010
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
Tip
Codes of 5130
<b> Nokia 5130 Mobile Unlock <br /></b> <br /><br />*#06# for checking the IMEI (International Mobile Equipment Identity) for Nokia 5130 To view Week and Year of manufacture enter *#3283# [*# D A T E #] <br />The last two digits are the year. If the year is 95, the first two digits are the month. For 96 the first two digits are the week of the year. <br /><br />To view the software version on Nokia 5130 enter *#170602112302# or *#9999# <br />On newer phones, the code has been changed to *#682371158412125# <br /><br />All Nokia phones (Nokia 5130 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) <br /><br />The main code used in Nokia 5130 phones is : <br />#pw+(master code)+Y# <br />This code is able to check, activate or remove Sim card restriction (SP-lock). <br />Use the * key to get the p, + and w chars. <br />'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with. <br /><br />#pw+1234567890+1# for Provider-Lock status <br />#pw+1234567890+2# for Network-Lock status <br />#pw+1234567890+3# for Country-Lock status <br />#pw+1234567890+4# for SimCard-Lock status <br /><br /># = DOUBLE-CROSS <br />W = PRESS "*" THREE TIMES <br />P = PRESS "*" FOUR TIMES <br />+ = PRESS "*" TWO TIMES <br />MASTERCODE = 1234567890 <br />Y = NUMBER 1 TO 4 <br /><br />(master code) is a 10 digit code, based on the phones IMEI number. <br /><br />Eg. To remove restriction on lock 1 type following code: <br />#pw+(master code)+1# <br />If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code) <br />eg. To check if phone if restricted on lock 1 type the following code: <br />#pw+1234567890+1# <br /><br />Bypass the SP lock With a Nokia 16xx/21xx/31xx/51xx/81xx <br /><br />1. Insert SIM card of different provider. <br />2. Turn on the phone and press the UP VOLUME key for 3 sec. <br />Then release it and the phone says PIN CODE? <br />3. Press the "C" key. <br />4. Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#<br /><span></span>
on Dec 19, 2010 | Cell Phones
Tip
Tips and Tricks for Nokia 2110i Secrets
To view the software version on 2110e / 2110i enter *#170602112302# or *#9999#
All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1)
The main code used in Nokia phones is :
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
#pw+1234567890+1#
Thanks and Regards
Dilip Bagdi
johny_inmexico@yahoo.co.in
on May 11, 2008 | Nokia 3310 Cellular Phone
I have an Octave CopyMaster II Plexwriter Premium and I need instructions in how to mix tracks and use it
Manual (found using a google search)
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&ved=0CCUQFjAB&url=http%3A%2F%2Fwww.octave.com%2Fpdf%2Fmanuals%2Fduplicators%2Fcopymaster%2FCM_II_III_manual.pdf&ei=9HhnUIvHGu2DyAGclYHQCQ&usg=AFQjCNHvdBGpeOkTn2GP_5at9_Vx0JZvYQ&sig2=SSdaRM0vM6ASyYEIIoE2ag
Sep 29, 2012 | Octave Copy Master II Burner
The master code is nt working plsss help..:((((
*#06# for checking the IMEI (International Mobile Equipment Identity) for Nokia 7210 To view Week and Year of manufacture enter *#3283# [*# D A T E #]
To view the software version on Nokia 7210 enter *#170602112302# or *#9999#
All Nokia phones (Nokia 7210 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1)
The main code used in Nokia 7210 phones is :
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
#pw+1234567890+1#
(please help me as I helped you)
Oct 15, 2010 | Nokia 7210
We have a 7 bay burner and most of the bays do not copy
Have you tried moving bays around to see if its the connections or the hardware itself?
Dec 02, 2009 | Octave Copy Master II Burner
What is the fuel/oil mix ration for a 345 Husqvarna Chainsaw?
Page 19 of a 2007 Operator's Manual 50:1
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Nov 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have an old model 1975 , what miks petrol/oil is right.
Fuel/Oil Mixture
Lou
Nov 09, 2009 | Homelite ZR10926 16" Chain Saw
What is the ratio of oil and gas mixture for husqvarna 460 rancher
Find an Operators and an IPL here:
HusqvarnaUSA.com
06 1500198
Fuel ratio 50:1 = 1gal premium/2.6oz quality 2-cycle engine oil
Fuel/Oil Mixture
Lou
Nov 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
McCulloch chain-saw fuel-oil ratio 3200
Fuel/Oil Mixture
Lou
Nov 07, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Octave Copy Master II Supreme Burner Logo
137 people viewed this question
Top Octave Computers & Internet Experts
David Payne
David Payne
Are you an Octave Computer and Internet Expert? Answer questions, earn points and help others
