Question about LG DLE5977 Electric Dryer
Lg dryer not drying
I have an electric LG dryer, 5977W, less than 1 year old. It takes 1 1/2 to dry a normal size load, even on manual dry w/o sensor dry. It is not a vent problem, cleaned and checked, even disconnected to rule that out, including cleaning the machine internally. Temps out the back over 200 degrees, which per the repair tech is way over normal. With higher than normal temps, you would think it would dry faster, but it in one full hour the clothes are damp. and no I do not use any fabric sheets. The last tech to look, had another customer on the same day with the asme problem, he thinks there is a defect with this dryer, LG is not admitting they know anything is wrong. This dryer cost 1,000. please help , any solutions. They already replaced a thermostat and drum for noise, altough I didn't htink that as necessary
  • 5 more comments
  • Rebecca Hernandez Feb 10, 2007
    Thanks, but the point was that even at higher temps clothes remain damp for a long time. Why wouldn't normal venting remove steam anyway regardless of temps, thats what it's there for, to expel the hot humid air and lint??
    The drive belt thing was never looked in to, I'll explore that
    Thanks, but thet problem is at any temperature, besides, isn't that what a properly installed venting system is for, removing moisture, heat and lint. I will look into the belt thing, thanks again
  • sewmom Dec 05, 2007
    I have had 2 LG dryers in 2 weeks. The first one never got warm the second one gets warm but takes 2-3 hours to dry a normal load. We put new vent in but it did not help.HELP. MOM
  • Anonymous Dec 15, 2007
    I had the same problem, the motor fell apart, had to pay for service and new motor, service teck said that the heating is hitting a metal wall, and is not alined correctly. Waiting for his return to adjust, will get back to you, when the new motor is replaced.
  • naboohoo Feb 24, 2008
    In the last two weeks, my 1 yr old dryer is having the same issue.
  • ace777b Mar 04, 2008
    I have the same problem with this Model dryer...takes a very long time to dry a load. Own this unit new, within a year had the Drum and roller replaced by LG. Six months after that, had the Blower fan blades replaced. Now it's taking a lot longer to dry clothes.....I thought it was the heating elements but its blowing heat out. Have clean out vents system so there is no obstruction.
    Saw one solution was to replace the belt ?.....I will try that. Does it have to be an LG belt or any dryer belt that matches the dimensions?...
    thanks
  • Anonymous Jan 08, 2009
    I have the same problem....what can I do about it....it takes almost 1.5 hours to dry clothes....
  • 105 Answers
Do not keep it higher temp unless bedsheets are inside.For normal clothes temp must be at normal level.If more steam remains inside then only clothes will remain damp.Look out for correct RPM.This problem comes due to drive belt also. Even it looks tight just replace blindly.Hope this will solve your problem.All the best to you.
Posted on Feb 10, 2007
LG products are absolutely atrocious. I have the same problem and they have done nothing to help..in fact, they don't even know what they're doing. I've had a service tech. out here twice. He diagnosed that it wasn't belt or blower fan, but a faulty computer. LG ordered the wrong computer for the machine twice..finally got the right one and the machine still didn't work. I've filed a complaint with Better Business Bureau. I'm on to the Attorney General next after seeing all of these complaints.
Posted on Jun 25, 2008
The problem is simple but there is not a thing you can do about it. These dryers spin to fast; therefore, the centrifugal force doesn't allow your clothes to tumble. Is that crappy engineering or what?
Posted on Jun 19, 2009
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
We have a LG dryer that is about 2-3 years old. The sensor is completely lit showing an obstruction but we have cleaned the vents out all the way to the roof and the sensor stays fully lit. The clothes...
Check the exhaust vent behind the dryer to make sure it's not kinked.
Take off the dryer vent and run the unit to see if it will dry normally. If it does, you still have a blockage in your exhaust vent in the wall.
Jul 20, 2011 | LG DLE2532W Electric Dryer
New Sensor Dry LG (< 1 month) Squeaks. Is this
No it's not normal for them to squeek. If its only 1 month old, you should call 800-243-0000 and lg will set you up with a warranty call.
Jan 31, 2011 | LG Dryers
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
It takes at least 2 60 minute cycles to dry clothes. Not even 2 years old yet. Not a new problem has always been this way. What is the deal.
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
Apr 14, 2009 | LG DLE3777 Electric Dryer
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Takes a lot longer to dry clothes
belts MUST be ordered by model all belts are different sizes, different witdhs
Mar 04, 2008 | LG DLE5977 Electric Dryer
On sensor dry, dryer remains at 1 minute for hours...will not shut off automatically
I'm sorry to hear of your problem with your LG dryer. I have one as well and it works very well. I found my owners manual. It has a web site WWW.LGSERVICE.com. They also have a toll free number 1-877-714-7486. Perhaps either of these will help you find an answer. Good Luck
Dec 03, 2006 | LG DLE5932W Electric Dryer
LG DLE5977 Electric Dryer Logo
3,546 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
