Question about Unotron Washable Wireless Keyboard (UNOCS5100K)
Wireless keyboard When typing, have to depress keys more than once to get them to appear. sometimes multiples appear. have reset keyboard and modem. have replaced batteries. have run all clean-up/virus programs. have restarted.nothng seems to work
  • Sherry Bircheat Feb 13, 2007
    turns out that this problem is due to poor signal strength. once that was fixed through the wireless keyboard troubleshooting, the problem was solved.
  • 105 Answers
This problem comes due to dust,just open your keyboard remove PCB wash it in water along with keys,but make sure you dry it with blower before fixing it.Even after fixing it dont put batteries inside and use it after one day. It must be totaly dry from inside after washing. All the best.
Posted on Feb 10, 2007
Cannot get ie to connect to web
you may just need to reset your modem and router, turn off both, and cycle the modem on, then the router. once that is done, if you're using windows, hit the windows key and the r key at the same time. type cmd into the dialog box and hit enter. when the black box appears type "ipconfig /release"
then type "ipconfig /renew" no quotes. then see if you are able to access the web. if not type 'ipconfig" and it will give you information about your ip address, come back and tell us what it says you have for an ip
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Dec 31, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
For some reason the light above the WPS button keeps flashing red. I have tried multiple reboots, none of which have worked. when connected to the ethernet modem, the light stays as a solid red color.
You need to reset your Router before setup manually.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 16, 2010 | Belkin Wireless Play Router (F7D4302)
Sometimes my wireless keyboard will type multiples of the same character when I've only hit the key once, and then other times it won't respond and will end up typing the first & last letters of a word...
Try plug it in to another USB port while the PC's switched on. It will force the computer to redect your mouse and keyboard and might fix the problem.
Another test would be on another PC or laptop. If it does the same thing then the keys are probably getting stuck down. Has it had anything spilt on it? Try a vacuum over the keys, you'll be suprised what gets caught under the keys (usally paperclips!!).
Dec 14, 2009 | Computers & Internet
0y 2eyb6ard n6t w6r25ng
Replace the keyboard ? It appears that the Function key (Fn) is "stuck" on. Depressing the Fn key (for keys with a Fn function) will "correct" the typing. How do you reset the Function key ?
Dec 07, 2009 | Computers & Internet
Typing any key on the keyboard produces multiple
hi Jeff.
go to this link should show you how to do a reset of your laptop.
How to Reset Your Computer .
or this link.
laptop basic reset Google Search
Nov 18, 2017 | Toshiba Portege M205-S810 Tablet PC
Keyboard Doesn't Type Correctly
you probably have something (such as food)stuck under your keys, so when you push down it pushes the board further, so it hits multiple keys. otherwise, you bent your keyboard and need to bring it to a store and get it fixed
Jun 04, 2009 | Logitech Wireless Access Duo Optical...
Multiple letters typing at once
Try Uninstalling the Keyboard Device, then re-installing it through the add/remove new hardware section.
Dec 01, 2008 | Computers & Internet
Microsoft Wireless Laser 6000 v2 Keyboard-keeps dropping out character as I type
Normal 0 Are you using Windows Vista? If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Look at each one and you should find the culpert. You can change it or disable it.
Hope this helps. Bud
Nov 01, 2008 | Dell Wireless Keyboard Optical Mouse w0147
goto control panel/keyboard and check the character repeat settings.
Oct 05, 2007 | Computers & Internet
Computers & Internet Logo
Top Unotron Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Unotron Computer and Internet Expert? Answer questions, earn points and help others
